How do I get at the thermostat housing bolts to change thermostat on 1990 Buick Century LE. It looks like I have to remove half the components on the side of the engine. The air breather hookup is in the way. The car has power everything. The only plus is I can see the thermostat housing but will have to fight to get at the bolts, any suggestions?
Most thermostats are located in or near the intake manifold area. Locate your upper radiator hose, then from the hose/radiator connection, follow the hose backwards to where it connects to. The goose neck or mating part, has to be removed. The thermostat is usually located inside the port. You may have to remove other covers and or parts to gain access to the goose neck assembly. You also have to let the car cool and drain the coolant before performing this task.
how do you change the thermostat in a 1991 nissan pathfinder
I have the same issue, take it to the shop or else sellit
