Question about Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum
Need switch for a shop vac modle qpl650
The switch is a rocker on off switch. looking for a place to buy one.
Ok - heres my story - QPL650 crapped out mid job, checked this post, ordered the switch on the link here, didn't work.
Called Shop Vac, priced a power unit assembley ($82), took the motor apart and traced the orange wires into small junction box, replaced the little rod connecting the contacts with a 1/2" of coat hanger (white paint scaped off first) and I am back in business.
Now I am thinking $82 invested in an index fund at 6% per annum for 20 years is...................
Posted on May 04, 2010
  • bcmc Oct 31, 2010
    switch on qpl650 would not turn off. I called and was advised that i needed to replace power head. I removed the switch and pried the rocker off the top. I found two very small copper contacts deep in the switch had jambed. I pulled the contacts out and made sure that they were free to move when i put the rocker back on and the switch has been working with no problems. I think I will invest the $80 myself.
  • dond429 Jan 03, 2011
    Thanks for the help. The switch on my QPL625 also would not turn off. I pried open the back of it and also saw one of the two movable contact sets was stuck (mildly welded together). Using a small screwdriver was able to un-stick them. The other contact set look ok. I cleaned up the contacts with a small file and re-assembled the switch. I reversed the wires to the switch so the wires going to the once stuck contact set now go to the other contact set that was less warn. Seems like the switch contacts are under rated for the job. Also pretty chessy of shop vac to not sell just the switch.
I was able to find the exploded part list view for this model on the following link to help in determining the part number for the switch.
http://www.shopvacint.com/parts006.asp
The part number for the switch is 8231900 and I was able to find a number of sites that carried it ranging from $0.88 to $4.99. Then they tack on shipping which cost 10-15$ which is a rack it, however I had to get it so I ordered two switches using the following supplier.
https://www.alexgs.com/_search.php?page=1&q=8231900
Posted on Sep 09, 2010
    New Friend:
MY QPL60 had a switch problem also, and thoroughly cleaning the contacts seems to have done the trick.
A small (1/8 +/-) flathead screwdriver will serve to do most of the removal & disassembly of the switch itself, and a small brass or steel brush will shine up the two internal contacts nicely, once they've been freed from the plastic enclosure.
Take your time, sketch the wiring hookups, and keep in mind that (on mine, anyway) the plastic rocker gizmo itself protudes further on its bottom surface one side than the other, and that longer side should be reassembled to bear on the non-humped end of the contacts.
Posted on Jun 15, 2013
  • Lindsey
    Lindsey Apr 23, 2014
    A replacement switch can be ordered from DigiKey (P/N 1091-1062-ND). Same 15A rating as the original. Costs about $2.80 + another $2.00 or so shipping. DigiKey is great and shipping via USPS is fast.
Http://www.fixya.com/support/t520183-shop_vac_qpl625_off
Posted on Jan 28, 2009
I need a rocker switch for a Shop Vac 86798-53 (LB550B)
Amazon is your best bet. Type in 120 volt rocker switch
Apr 28, 2016 | Shop Vac Vacuums
Sucking and blowing
Shop-Vac® Brand. The Original Wet/Dry Vac™
https://www.shopvac.com/
Shop-Vac® is proud to be an American-based company. ... When we say the Shop-Vac® is powerful, we're talking debris cleaning, leaf-blowing, heavy-duty, wet or ... Many of our vacs are backed with a 3 to 5 year warranty, but we've seen ... I had just gotten back from work, so my arm was hurting, and I really didn't want to ...
My ShopVac Blows - WOOD Community
community.woodmagazine.com > Forums > Tools and Tool Buying
Nov 23, 2009 - My ShopVac suddenly started blowing dust out the exhaust ports. I don't mean a little dust, it blows almost as much dust as it sucks in!!!! ... ... I'd look it over very carefully looking for tears or splits. Might be a good idea just .... A few months ago I purchased a Dust Deputy and hooked it up to my shop vacuum.
10 Shop-Vac Vacuum Hacks For Around The House - Thrillist
https://www.thrillist.com/.../10-shop-vac-vacuum-hacks-for-around-the-...
Sep 14, 2015 - Simply flip the switch from suck to blow and blow leaves to your heart's... you really need to get your act together if you're using a Shop-Vac for ...
Shop Vacs...and dust control? - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Cleaning Tips
Jan 09, 2016 | Shop Vac Vacuums
On off switch stopped working 3rd one to do so this one cannot be returned to old ? model QPV10.5b nothing on shop vac site and nothing comes up on Digi-key site really do not want to buy 150.00 vac...
Hi Ashley,
This website has one for the 12/14/16 gallon vacs:
http://www.vacsrus.com/CartGenie/prod-1165.htm
If yours is a different size, write back and I'll see if I can find it for you. Hope the 4th one lasts a bit longer.....
Hope this helps. If it does, please place a vote for me. Thanks,
Handie Andie
Mar 30, 2011 | Vacuums
Vacuum shut off and will not turn on again. What could be wrong?.
Your switch died, it happens a lot with this brand of shopvac. Just extract the little switch behind the big rocker switch and replace it with one from radio shack, or replace it with a toggle switch. Cheap and easy to do.
Mar 15, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Need to know how to open the canister of my Electrolux Ambassador vacuum to replace the switch
If you switch still"clicks" you need a switch rocker, if it no longer clicks you will need a new switch button. You will get best results with the genuine button from an AERUS Electrolux repair shop
There are a set of body keys under the bumpers on this vac which slide forward to the front door with a set of pliers. They are locking one way so reinstall same direction . Examine the front hinge are before opening the vac. Once removed the panels will open like a **** shell from back to front. You will need to be careful realign all pieces in their tracks.
The switch is best accessed by removing only the bag cage. The housing will lif up without detaching wiring and the rocker and switch button will snap out as separate pieces. Test before reassembling and when done if the entire body does not assemble easily stop and check your alignment. It will click together like Lego pieces when you have it right.
Post back to advise how you make out
Nov 03, 2009 | Vacuums
I have a shopvac model#86776-24. The toggle switch went bad and I'm looking for a replacement switch
I got a replacement switch at a local electronic supply store: Philmore Miniature Rocker Switch part number 30-043. Shop vac changed the switch recently to two push buttons from the old rocker style. This update works a lot better.
Oct 25, 2009 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Replace switch on electrolux 2100
The 2100 is an older model which is prone to rocker switch failure. What you see outside is only a switch button. Underneath is a plastic rocker which sits in a grove and pivots back and forth to activate the on off switch.
If you push the switch down and there is no audible "click" you Likely need the rocker itself, especially if you tip the vac upside down and shake it and hear a piece rattling inside or find a broken narrow plastic finger about 1/2" inch long when opened.
However if it clicks and works every 3-5 times,the rocker is fine and you will need the spring mechanism and switch button which you can see form outside.
To remove either the process is the same.
Separate the body by opening the bag cage and pulling the two bumpers forward with a set of pliers. They are locking keys. Once removed, the rear housing will drop off allowing the vac to hinge open back to front. Do this with the vac laying upside down and observe the hinge section of the front bag door .DO NOT REMOVE THE MOTOR. You will need to clip all these componnets back together to reassemble and slide the bag chamber back to seat against the motor with the motor housing engage in the ribbing of the vac side walls.
With the vac open you will only need to remove the spring loaded bag lockout switch and the bag housing it sits on, not the motor or rewind..
Once removed there will be 6 chrome philips screws visible. These hold the top trim on the front of the vac and the front ones hold the on off switch into its housing. At the very front will be two screws going through a black or whitish switch housing. That housing will lift out with wires attached to reveal the switch rocker, etc,. This portion will lift back and out at about 45 degrees of the inner housing, as a unit. The switch button sits atop the rocker via two end tabs and will pop off the housing to reveal if the rocker itself has a broken "finger" or if the button has a weak spring.
The suspect spring is not the coil rocker spring but the thin U shaped spring on the underside of the switch button. Remove the rocker spring with a pair of needle nose pliers.and examine the rocker comparing to your new one.Use more vaseline on the new rocker and if you have it reinsert the clear flex plastic into the coil spring. If not disregard.
Re-installation is the reverse order, tuck switch back in at 45 degrees from back to front.
Pay special attention the the rubber seal at the back of the bag cage.
If anything is misaligned in this body you will fight to reassemble. Don't fight it , back up and look at your work. When and ONLY when it is perfect it will realign and click together like a lego set and the keys will slide in perfectly
You can and should test the vac before reassembling the whole body, simpley slide your hand under neath and activate the switch, with a bag inside the vac.
See now, wasn't that EASY???????
Please post back to advise how you make out. Its a 7 minute process worth $25 for a good tech. A bad tech will spend half a day trying to figure this one out but just go slow and follow the instructions and you will do fine.
Oct 17, 2009 | Electrolux UltraLux 2000 Bagged Canister...
The on/off switch won't click in either direction.
If this is the switch on the hose the switch can pop out the front for inspection. If it is the switch on the vac the rear housing of the vac needs to be removed to access the actual rocker switch underneath the switch pad. Both are inexpensive. If the vac is in good shape check the switch and replace if necessary.
Sep 01, 2009 | Kenmore Vacuums
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Shop vac QPL625 on off switch stays on.
Contact Digi-Key 1-800-344-4539 or 218-681-6674 ask for part number EG1505-ND.
Cost is about $2.00 plus shipping.
See http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=EG1505-ND for part details.
You want a D.P.S.T (On/Off) mini-rocker switch.
Apr 16, 2008 | Vacuums
Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum Logo
3,281 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
