I've been told I need a new "Picture tube" for my Sony KDP65XBR2 rear
projection HDTV, however it was recommended that I replace all three RGB tubes for accurate color balance, this suggestion from the authorized Sony repair center (TOPS) electronics. I contacted the MFG of the Tubes, who tell me that I DO NOT need all three to get an accurate representation of color), the repair center tells me that the Blue tube is not longer available (HDTV is 6 Years old) I paid $6000.00 for it, a thousand a year sounds a little iffy. The manufacturer of the tubes (for most projection TV's) Says they are all available for $152.00 each. Is it worth repairing, and if so do you recommend buying spare tubes before they are really discontinued??
KDP65XBR2 TV, When turned on, no picture and there is a red light which blinks times.it has sound ....
(More)
KDP65XBR2 TV, When turned on, no picture and there is a red light which blinks times.it has sound . somebody help me please
I have a Sony KDP-65XBR2. It powers up fine, then shuts off after 5 steady red blinks on the...
(More)
I have a Sony KDP-65XBR2. It powers up fine, then shuts off after 5 steady red blinks on the standby light. It has good sound in the speakers, and the picture displays fine, old bulbs will probably need to be replaced. The unit will stayed powered up for about 5 seconds until it shuts off. While the unit is powered off (with the power button pushed to the ON position) the TV will then give 6 very fast blinks. I noticed that when I first plugged the TV in powered it up, I got 11 red blinks from the standby light. Any suggestions???
I have a Sony KDP-65XBR2 tv that i am trying to fix.The tv will turn on with just a color display on...
(More)
I have a Sony KDP-65XBR2 tv that i am trying to fix.The tv will turn on with just a color display on the screen but then turns right back off.The green tube is not coming on at all and i have redone all solder joints on all 3 tube boards...Found resister #3935 burnt on the CB board..Replaced it only to have it blow time i turned set back on.I have checked and there is high voltage to all three tubes as well as the heater voltage..
My ? is why is r3935 blowing and why is green tube not even coming on...anyway to test to see if the tube is bad??
We have a TV with this problem: http://www.fixya.com/support/t1673203-sony_kdp65xbr2 I located both...
(More)
We have a TV with this problem: http://www.fixya.com/support/t1673203-sony_kdp65xbr2 I located both of these PC boards "G" and "D" but the Caps are all C follow by a 4 digit number so I can locate the components you refer to. Can you help any further.
