Question about Microsoft Xbox 360 Console
Cant play games
Every time i try to play a game new or old all my xbox does is say disc unreadable peases take disc out and wipe with a soft cloth and restart console that doesnt waor
  • bahl33ted
    bahl33ted May 11, 2010
    Is your system on the internet so that it may receive the newest updates/patches?
    Have you tried using a laser lens cleaning disc (look like a regular cd-dvd but has tiny brushes on the bottom to clean the laser lens)?
    You can get one at Walmart, Best Buy, etc... for about $15
  • 29 Answers
If its not doing anythng you may have a hard disk problem? I cant guarante this as you have not given enough information. Do you get an error message? or any message at all other than cant read disk? you are obviously using the internet...take a look at the microsoft.com website....put into the search 'XBOX360' see what is comes up with..you may find your answer there.
Posted on Dec 12, 2008
How do I fix my xbox game the xbox keeps saying unreadable disc clean with a soft cloth and restart the console.
If you get the error with just one game, but not others, unfortunately it is likely damage to the disc. If it is under warranty, or if you bought it at a return-friendly place, maybe you can get a replacement. If the system is giving you this error with several games, it is likely the disc reader in your Xbox. The Xbox 360 has a well-known issue with DVD drive failure over time. If your system is still under warranty, or sometimes even if not (because this was such a big problem for Xbox), Microsoft may repair it. Try calling them and patiently discussing it. If it is not under warranty, and you are good with repair work, try this: http://hardandsoftgaming.wordpress.com/2011/03/12/replacing-a-faulty-xbox-360-dvd-drive-firmware-flash-or-circuit-board-transplant/
Jul 25, 2014 | Video Game Consoles & Games
My new xbox will no longer play black opps. i have tried 3 different disc's and they all say disc unreadable, wipe with a soft cloth. its the only game that does this. i even just went and bought a brand...
I had the exact same problem, it is a problem with the xbox. Since it is only three months old it is under warranty, go to xbox.com/support and file a claim describing the problem. They then will have you send in your xbox and you should get a new one in about three weeks, best of luck.
Mar 10, 2011 | Video Game Consoles & Games
Just purchased Dance Central game for xmas. Played it and it worked fine for one session, then switched to a different game disc. After playing the second disc for a little while, tried to go back to Dance...
We had the exact same issue. It worked fine the first time, we switched games and when we tried to play it again it gave us the unreadable disc error. I cleaned it multiple times and called tech support with no luck... they actually suggested returning it. In a last attempt I took it to a game store in town and they cleaned it for $1. He said we had a lazer burn which is common with the xbox... even if the console is barely bumped it can burn a circle into the disc. Sure enough, our Dance Central is working 100% now. Hope that helps!!
Dec 26, 2010 | Microsoft Dance Central for Xbox 360 with...
I cant play call of duty modern warfare 2 because if i do play it an error apears on the screen and says 'this disc is unreadable' and it ells me to clean the disc with a soft cloth and restart the...
Has the been played without a problem before??
The disk may be damaged. Try to use a "disk docter" if you know somebody with one. If you dont have try to put a little windex on a soft towel and clean the disk inside to out.
Are other game disk working ok with the 360? If no game or dvd disk are working then the dvd drive has failed and will have to be replaced. If you have any questions give me a comment.
Hope this helped!
Apr 08, 2010 | Microsoft Xbox 360 Console
"The disc is Unreadable"
check around the disk tray for dust and use a vaccum cleaner to clean it, then use a wet cd lens cleaner with cleaning fluid a few time.
This should cure the problem but it might be that your drive is on its way out
Nov 01, 2009 | Microsoft Xbox 360 Console
Clean the disc with a soft cloth FFXI xbox360
this is caused by the n November update in the MS xbox360 dashboard. This is a problem with the xbox communicating with the hard drive. This usually occurs in xboxs that are not using the HD shipped with the console. According to square the only solution to this common problem is that you reformat your hd and intsall the game again. yes, you have have to wait for that dl to finish. square also states that there is a possiblity that this may re-occur after the second install, though rare.
Apr 14, 2009 | Microsoft Xbox 360 Console
Xbox 360 is acting strangely
This is a known issue with the 360, most likely the cause is that the spindle that holds the disc is loose or completely broken off. As the way the cap for the spindle was made, microsoft used a magnet to hold it in place instead of glue or soldering as most drives would have. This is just another instance of inferior workmanship on their part to save money.
Contact 1-800-4MY-XBOX to get an RMA issued.
Sep 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
