Question about Philips GOGEAR SA6045 MP3 Player
I have a terrific problem / Tengo un terrible problema
The problem is the next:
2 days ago it was listening to music in the reproducer before going me to the school, and when I returned of the school, I turn it on the reproducer, and I noticed that the reproducer doesn´t turn on. So I connected the the reproducer to the computer, and open Philips Device Mananger and it appeared to me an error in the reproducer, and said “REPAIR”, and I pressed it, and then, when it finished said “REPAIRED, NOW IT CAN DISCONNECT” and that we did. The problem was that it didn´t turn on, now, the problem is that turn it on, but soon it turn it off. What I can do?
El problema es el siguiente:
Hace 2 días estaba escuchando en el reproductor antes de irme a la escuela, y cuando regresé de la escuela, encendí el reproductor y noté que no encendía, entonces lo conecté a la computadora, abrí el PHILIPS DEVIDE MANANGER y me aparecía un error, y le dí en "REPARAR", y cuando terminó decía "REPARADO, PUEDE DESCONECTAR", y eso hicimos, y el problema ahora es que prende pero luego se apaga. ¿Que puedo hacer?
  • 8,596 Answers
Run a repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Mi camara canon powershot A3100 IS se apaga automaticamente y aparece en la pantalla se ha detectado un error. debe reiniciar la camara y yo no se como solucionar eso porque no he podido reiniciarla. como...
TENGO UN PROBLEMA CON MI CAMARA POWER SHOT A 3100 IS LA MISMA PONE EN LA PANTALLA SE HA DETECTADO UN ERROR DEBE REINICIAR LA CAMARA DIGAME COMO SOLUCIONAR ESTE PROBLEMA MI CORREO ES josemm22@yaho.com
Aug 28, 2011 | Canon PowerShot A3100 IS Digital Camera
Tengo un mp3 marca vios ke no reproduce solo sale en la pantalla txt y una lupa y una hoja de papel..como lo arreglo
HOLA QUE TAL YO TAMBIEN TENGO UNO CON EL MISMO PROBLEMA ESPERO YA TENGAS LA SOLUCION PARA QUE ME LA PASES
May 12, 2011 | XO Vision X120AUD1GB MP3 Player
Tengo un daewoo lanos 2002 1.6 motor el problema es que se queda sin fuerza con un fallo terrible,y la gasolina no la qema bien por el olor que despide.sera el cam sansor o el crank sensor.
Que codigo de fallo le arroja la computadora del vehiculo? SOund like a faulty Fuel Injectors or Fuel Line Leaking, Fuel Filter (Leaking Fuel Filter.) or Fuel Pump (Incorrectly Installed Fuel Pump).
Feb 16, 2011 | 2002 Daewoo Lanos
Tengu una camioneta saturn vue 2003, tengo problemas me en peso a tenblar y sevajan las revoluciones , cuando ago un alto sejalonea
hola trata de hacerle una lavada alos inyectores y cambio de aceite y bujias si sigue la falla escanealo para ver que no sea un sensor
Jan 07, 2011 | Saturn Vue Cars & Trucks
Tengo un problema con la impresora kyocera fs-4000dn, que me sale el mensaje llamar servicio 7410:0052827, me gustaria saber a que se deve el problema. saludos...
tengo un Problema con mi empresora Kyocera FS-4000DN Laser Printe. me aparece comprobar caja de toner y no me deja imprimir les ruego q me colaboren muchas gracias por los servicios
Sep 23, 2010 | Kyocera FS-4000DN Laser Printer
Tengo un pontiac grand prix 98 los indicadors ABS y TRAC OFF se mantinen constantemente encendidos que sera? gracias por su ayuda
Llo tengo un97 y tengo un problema similar pero lo q el mio ace cuando las luses d abs y trac off prenden el sistema d aire acondisionado osea AC se apaga por completo y el problema d todo es el el balero d las llantas
Aug 21, 2010 | 1998 Pontiac Grand Prix
Codigo del dvd sungale 2026 para control universal motorola
hola tengo un problema tengo un dvd marca sungale y no tengo control le compre uno universal marca lax-max y quiero saber cual es el codigo para este dvd
Dec 11, 2009 | Sungale DVD-2026 DVD Player
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Problema con el audio
Usted necesita saber el código del producto de su Cmedia .. Prueba enlace a continuación para obtener más detalles
http://etech.maiila.com/c-media-audio-device-drivers
May 07, 2009 | Computers & Internet
Philips GOGEAR SA6045 MP3 Player Logo
118 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
