Question about Friedrich Digital PTAC PDH12K35B Central Air Conditioner
Fans wont turn without manual start
Once fan is started by pushing the button, rotation does not occur until manually started, then fans work fine until motor is turned off then it will not restart the fans rotation
  • 96 Answers
You have a bad start capasitor
Posted on Dec 12, 2008
Why is my fan not spinning on start up?
You need to replace that fan motor, the bearings are shot for the shaft.
Oct 27, 2016 | Office Equipment & Supplies
Air conditioner fan wont start
change run capacirotor of outdoor fan motor.
Jan 07, 2014 | LG LSC121PMA Split System Air Conditioner
Toshiba M305D S4830 laptop wont start
"I have M305D S4830 laptop. I put it to sleep in the night. In the morning when i tried to turn it on, it wouldnt start. The light on the switch turns on and it charges the battery fine, but no HDD activity(but it does spin up and stay), no screen, nothing. The fan turns on and then turns off in 1 sec and then just the power indicator lights stay on... i also checked cmos battery, removed it and put it back.its voltage is also fine..."
Hello PPL! Maybe this WILL HELP you! I HAD absolutely the same problem >> 3 months of god **** stress, didn't find any solution, till one day i found on my Recovery CDs one note!! >> It sounds like:
"BEFORE pressing power button, HOLD 'C' button and while Holding 'C' button push POWER Button ONCE!! to start Laptop, KEEP Holding 'C' button!!! untill appears TOSHIBA screen!" then release 'C'. After that, it will appear "Operating System not Found">>then just do a restart by pushing Power Button and Start again! For me, It Worked!! and i'm god **** happy now)...let me know if it Helped you, Good Luck!
Feb 04, 2010 | Toshiba Satellite Laptop with AMD Turion...
Fan won't reverse to counter clockwise
I had a hampton bay fan that absolutely did not have a revers switch on the fan anywhere! MOST fans bought today will reverse. I was not about to give up. I scoured the net for an answer and could not find anything to help. I did however find a comment somewhere that said it could be done internally. After about six months I decided to search again (now). Nothing... so I started playing with the remote and the wall switch and Shazaam! I figured it out on my hampton bay fan. Turn the fan on high... Turn the wall switch off.... wait until the fan is pretty slow in rotation... hold the HI button on the remote.... Turn the switch back on. IT Worked for me! Hope this helps someone. SparqMark
Aug 10, 2009 | Hampton Bay 24750 Huntington III Ceiling...
A/C not working, outside fan not turning without assistance
is fan spinning fast enough it has to have alot of velocity to cool condensor coils if you haft to push fan to get going its probably shot and get new motor the ac is a sealed system and hardly ever will leak freon!!!Best of Luck to You!!! :)
Jul 02, 2009 | Bryant 462AJC021BA Air Conditioner
Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Jan 24, 2009 | Casablanca Fan Stealth 3211T Ceiling
Whirlpool Ultimate care ii Dryer wont tumble
If your dryer doesn't tumble, check these:
Belt,
Motor,
Door switch.
Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
Remove the belt,
Check for obstructions in the blower fan housing,
Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
Go here to see a diagram for your model:
one of two types. "H" or "J"
http://www.repairclinic.com/0079.asp#DiagramH
Nov 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My dryer will not start. It is not locked. I've turned it off and unplugged it for 30 minutes. All the buttons work fine, but the timer just flashes when I push the start button. Help!
If dryer does not spin it is usually a problem with the belt or the motor. Check also door switch.
See also following indications from Repairclinic:
It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Aug 27, 2008 | Whirlpool Dryers
No start up , button lites up - cd-rom wont open , noticed no fans on for 3d card or big one on mother board
If the cpu/heatsink fan isn't turning then most pc's will shut down to avoid further damage to cpu & board. I would first replace the fan if it's the one over your cpu. Try replacing power supply. If your board has the 4 pin plug, you must have that plugged in. But keep in mind if that fan isn't running a new power supply isn't going to make it start working. You have to have that fan working. Then go from there. If once it is working & other devices like video and/or roms aren't, check your memory. The best way to troubleshoot devices are to plug one at a time in and power up until the problem starts. Hopefully you won't have to go to that step.
Aug 14, 2008 | E-Machines eMachines Desktop PC
FAN!!!
Oh, it turns out the the microwave was over heated and the fan was cooling it. The fan will automatically turn on and stay on until your microwave reaches normal temp. just unplug your microwave and let it cool off. then plug it in and everything should be just fine.
May 25, 2008 | Frigidaire GLMB209D Microwave Oven
Heating & Cooling Logo
167 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
