Question about Bose Lifestyle SA-3 2-Channel Amplifier
Best way to use US-Bose SA3 amp in Europe ?
I moved back to Europe, and having a brand new SA3, I wonder what to do ?
=> the SA3 delivered in USA is compatible with 220 Volts/50Hz supply ; just the connector/plug to change ?!
or
=> I need to contact Bose to upgrade my SA3
or
=> I may use a voltage transformer without risk for sound quality or continuous use (thermal risk of the transformer) ?
Thanks for assistance.
Bose say you should pay to get it converted because over time the slightly different power cycles can effect it, however it will still works fine if you change the voltage with an adapter - like I did!!!
Posted on Jul 16, 2009
My Bose SA3 2 channel amp keeps blowing when I raise the volume with non-bose speakers, why is this happening?
Could be the impedence of the speakers that you're connecting. The bose amp was designed to drive 8 ohm speakers.
Aug 31, 2016 | Bose Lifestyle SA-3 2-Channel Amplifier
Where is the fuse on a bose sa3 amp?
It will be on the inside of the amp, located on the power supply board. The are many types of fuses, so it may may not like like you expect.
May 19, 2014 | Bose Lifestyle SA-3 2-Channel Amplifier
How to install a bose sa3 to a bose v35
How to install a bose sa3 to a bose v35....http://m.topix.com/forum/who/bose/TOH8RAETEKGB8966I/p2. See the link above . Sometimes audio cable quality n the ohm makes a difference . 12_27_2013_11_17_29_pm.png
Dec 12, 2013 | Audio Players & Recorders
Sa3 bose not sound from boselink but external input yes
It depends on the Bose system you connected with the amp and the type of Bose remote you are using?Does the indicator LED at the rear of the amplifier stay solid green when you press the ON button on the remote?If not,check that your room code setting on the remote correspond with the micro switches setting at the rear of your amplifier.
Feb 08, 2013 | Bose SA3
Bose sa3 amp, blew a fuse in it, replaced it and now it won't power up. Nice little amp, would like to find out how to test out what is wrong and fix it
If you can,check with your multimeter to see if the two voltage rectifiers are good.If they are OK,you may need to replace the 2 audio amplifiers.This will require proper tools and good experience.
Jan 06, 2013 | Bose SA3
How do I connect 2 jbl ct 26 speakers in a series to Bose sa3
I don't know the impedance of these speakers but the Bose SA3 amplifier is 100watts per channel.A higher wattage speaker may damage the audio amplifiers.
Aug 28, 2012 | Bose SA3
SA3 amplifier to move to Europe : capability of the transformer ?
While living in the States I purchased a Bose Acoustimass 10 system but have now moved back to the UAE. As the system operates on 115 volts ONLY I would like to get it work on 240V without having to use a step-down transformer. By changing out the transformer form 115v to 240v will it work or will I have to change any other components within the system. Can anyone help me??
Dec 12, 2008 | Bose Lifestyle SA-3 2-Channel Amplifier
Converter needed
If your unit is from the USA, 120 volt/ 300 watts.
EU is 220-240V / 300 Watts. Best choice is to go to Bose service center in EU and have your transformer inside your box replaced with 220-240V for EU operation. That way you don't have to worry about a converter. If not, 2nd choice is buy a step-down transformer 220-240V input and 120 Volt output that can handle 300Watts.
Good Luck.
Dec 22, 2007 | Bose 3 2 1 GSX System
Bose SA3
while hooking up the RCA'S? I wouldnt think so
Dec 12, 2007 | Audio Players & Recorders
Bose Lifestyle SA-3 2-Channel Amplifier Logo
619 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
