I have a 55" projection TV from Mitsubishi
It has a convergence issue - that if we bang it, it'll go back to being ok. Any idea how much this is to repair... ballpark? We're in NJ.
  • cpayne818 Dec 12, 2008
    awesome! thanks so much for the info!
    President:
  • 2,992 Answers
Sounds like bad solder connections to the convergence output integrated circuits. Very common, and that's why whacking the set gets it going okay again. I have no idea what road technicians are charging for the trip and labor these days, but when I was on the road several years ago our charge was $82 total trip and labor. You should be able to get a ballpark estimate over the phone since it should be a pretty straightforward repair.
Posted on Dec 12, 2008
I have a mitsubishi 55 inch tv model ws-55313 i can hit power it will come on for a 20sec then powers back off what is the cause of this?
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the convergence ICs replaced.
A repairman would charge about $350 to replace them
Voltage checks and a visual would be needed to determine exactly what is bad in your TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 20, 2009 | Mitsubishi WS-55313 55" Rear Projection...
Double image looks like a convergence issue
This is a Convergence issue, bad solder connections on the convergence IC's.
Nov 20, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Convergence issue with WS 555111
Good Day;
Sounds like the Convergence IC has failed. Replace > STK393-110 > part # 267P155010 > TV uses one IC. Good Luck, big IRISH.
Sep 18, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi Ws 55511
Good Day;
My opion is that the TV"s convergence Ic has failed > STK393-110 > 267P155010.
Aug 10, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Green screen when powering on
HELLO. I KNOW WHAT YOUR PROBLEM IS .!!! YOUR (CTR GUN'S) HAVE A SHORT .IN THEM.!!! AND THAT'S WHY IT IS GREEN.!!! BECOUSE THE (CTR. GUN'S ) AND CLOG UP .!!! THERE IS A WAY IT CAN BE FIXED .!!! AND IT COST'S AROUND $65.00 TO $125.00 . A GUN.!!! IF CALL AROUND AND ASK TO TALK TO THE TECH. AND TELL HEM THAT YOUR( CTR. GUN'S ) NEED TO BE ,!!! BELLTRONED.!!! & IF THEY HAVE A BELLTRON .!!! AT THER SHOP.? AND ASK HOW MUCH THEY WOULD CHARGE U .!!! TO BELLTRON . YOUR SET. !!! & IF THEY COME THERE . TO DO IT .!!! OR IF YOU HAVE TO TAKE IT TO THE SHOP TO HAVE IT DONE.!!! GET BACK TO ME AND LET ME KNOW . BEFORE YOU OK THE WORK.!!! AND HOW MUCH.!! THEY WANT TO CHARGE U TO IT !!! OK .!!! LET KNOW ASAP OK "GOOD LUCK"
May 03, 2008 | Mitsubishi WS-55819 55" Rear Projection...
WS-55819 Mitsubishi Rear projection TV Picture goes blurry
Convergence ICs are bad need to be replaced. You will need to replace both of them also check the resistors right next to the IC often 1 or 2 of them burn out when the IC goes.
Feb 26, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Convergence
have you replace the convergence IC's?
Dec 03, 2007 | Mitsubishi WS-55613 55" Rear Projection...
Convergence Problems
GREEN-YOU HAVE TWO STK392570 CONVERGENCE ICS' GETTING READY TO FAIL.SOME FOLKS HAVE REPLACED THEM ON THEIR OWN,OR YOU CAN GET A REPAIR TECH TO DO IT FOR AROUND 300.00$.JOE TV
Oct 29, 2007 | Mitsubishi WS-55819 55" Rear Projection...
TV wont stay on
you may have a convergence problum if your convergence ic,s are shorted, you will need to check the convergence fuses in the power supply.
May 06, 2007 | Mitsubishi WS-55413 55" Rear Projection...
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
