Question about Kodak EasyShare DX4530 Digital Camera
Down button worn out
I use the up/down/left/right arrows on the ok button alot, now the down arrow won't work at all and the left arrow is only working part time. Is there any way I can fix this or repair it myself? The camera is only 2 years old and I'm not real "digital friendly", if you know what I mean..This one is my first. Thanks for any help... Delilah
    Genius:
  • 2,985 Answers
Check out Kodak for repair costs
Posted on Jul 31, 2007
SOURCE:
Button to scan in channels
The CT-90326 remote was included with several Toshiba televisions, including the 42HL800A. You can't directly scan for channels with a single button on the remote. First make sure that the TV is set to the TV input. (Use the Input button on the remote (top left) or the TV (lowest button on the left side as you face the screen).) Next press Menu (the second lowest button on the TV or the button at the lower left of the Left arrow button). Use the Left or Right arrows to select Setup (with the gear icon) and press OK. Use the Up/Down arrows to select Auto-Tuning and press OK. Use the Up/Down arrows to reach the line to select the type of channels to search for a signal. Then use the Left/Right arrows to select Digital channels, Analog channels or both. Go down another line to set the bandwidth of your broadcasts. Again use the Left/Right arrows to select the correct one. Go down one more line to Start Scan and press OK.
These details are in the manual for your TV. The manual for the 42HL800A is available from Toshiba's product support download page: http://www.mytoshiba.com.au/support/televisions/led-backlit-tv/hl800a/42hl800a/download . The direct link to the manual is http://www.mytoshiba.com.au/file/download/resource/file/19610/toshiba_32av80032%2040lv80026%2032el80032%2042hl800_om%20(au).pdf .
I hope this helps.
Oct 02, 2016 | Toshiba CT-90326 Remote Control
Up and down arrows on my ti-84 work as left and right arrows on the main screen! how do i fix this?
Remove one of the AAA batteries.
Press and hold CLEAR while reinstalling the AAA battery.
Continue holding CLEAR button and press ON.
Release buttons and press CLEAR again.
Feb 03, 2013 | Texas Instruments TI-84 Plus Silver...
"how can i put a
Press Menu - If you see a Setup tab , press the right arrow button to highlight the Setup tab. - If you dont see a Setup tab, press down arrow button to select Setup, then press OK button. -If your camera doesn't have a Menu button, press the Review button then choose Settings.
Press the down arrow button to choose Date & Time the press OK button.
Press the Right/Left arrow buttons to move between year, month and date.
Press the Up/Down Arrow button to scroll through the year. month and date.Use the same procedure to set the Time.
When finished press OK button.
Hope this helps. Rate if it works. Thanks
May 04, 2011 | Cameras
Projector does not stay on more that 10 minutes. Some said it could be the bulb or lamp.
hi,
Its because you projectors lamp have to replaced. It is notifying that you have to replace the lamp. if you wish to use the same lamp then you have to reset the lamp hour timer. it is recommended that you have to reset the lamp hour only after replacing the lamp. do the following for reset you projectors lamp hour.
(1) Press the MENU button to display a menu.
(2) Point at the ADVANCED MENU in the menu using
the up arrow/down arrow button, then press the right arrow button.
(3) Point at the OPTION in the left column of the menu
using the up arrow / down arrow button, then press the right arrow button.
(4) Point at the LAMP TIME using the up arrow / down arrow button, then press the right arrowbutton. A dialog will appear.
(5) Press the right arrow button to select "OK" on the dialog. It performs resetting the lamp time.
ok
Apr 29, 2011 | Hitachi Cpx2510 Projector Cpx2510 Xga...
LHow do I increase the volume as the phone is very quiet
Hello there,
Adjusting the volume on an HP Officejet All-in-One
Follow these steps to adjust the volume of the various fax sounds.
Adjust the rings and beep volume
1.Press the Setup button P(wrench).
2.Press the arrow buttons (Left and right) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right) to select Rings and Beep Volume , and then press OK .
4.Press the arrow buttons (Left and right) to adjust the volume, and then press OK .
Adjust the phone line and monitor volume
1.Press the Setup button (wrench).
2.Press the arrow buttons (Left and right ) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right ) to select Phone Line, Monitor Volume , and then press OK .
4.Press the arrow buttons (Left and right ) to adjust the volume, and then press OK .
Adjust the handset volume
When you receive a call, pick up the handset of the product, and then press the arrow buttons (Left and right ) to adjust the handset volume.
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 22, 2011 | HP J3680 Officejet All In One Printer
How do I change the date on my ViviCam 5385 digital camera?
Assuming the camera is working, with the camera off, rotate the mode dial so that the icon with the wrench lines up as the active mode. Then press the Power button and turn on the camera. Press the right arrow to select Custom Menu. Then press the down arrow to select Date and Time. Then press the OK button. Use the left and right arrows to select a part of the date to change and use the up arrow to increase the value and slide the zoom lever to down button to decrease the value.Press the OK button when the date and time (24 hour clock) is properly set.
The manual for the 5385 is available at retrevo: http://www.retrevo.com/support/Vivitar-5385-Digital-Cameras-manual/id/200bh836/t/2/ . You'll need to enter a code to access the PDF.
I hope this helps.
Mar 06, 2011 | Vivitar ViviCam 5385 Digital Camera
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
I bought me camera off ebay and the software didn't come with it
Easy, just change the camera's USB connection to the DSC mode. You don't need any software when the camera is in DSC mode, it looks like a memory stick or card reader to your computer.
Enter the picture viewing mode, press the "menu /OK" button, arrow down to menu "2",
arrow down to "Set",
right arrow to the sub menu,
Arrow down to menu "3",
arrow down to "USB",
right arrow and arrow up to change from "Pict Bridge" to "DSC", left arrow out and press "menu/OK" button.
Nov 06, 2010 | Fuji FinePix S5200 / S5600 Digital Camera
Want to change language settings
press the "setup button" press down arrow to "preferences" press right arrow then press right button then scroll to ENGLISH hit OK then OK again then scroll down to your country (or closest one to it) and hit OK again then the left arrow button a couple of times to exit
Apr 17, 2009 | HP Photosmart 2575 All-In-One Printer,...
HPL7780 and Linksys WRT54GS V7
That usually happens when you are going to connect the printer PRO using the wireless. To avoid that problem, try connecting the Printer using the Manual Setting of the IP.
Solution
NOTE: If the router has an outdated or firmware that was not supplied by the manufacturer, update the router to the latest manufacturer-supplied firmware. Set a Manual IP address on the HP All-in-One
  1. Change the IP settings to Manual from the HP All-in-One.
    1. On the front panel of the HP All-in-One, press Setup .
    2. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Network , and then press OK .
    3. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Advanced Settings , and then press OK .
    4. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select IP Settings , and then press OK .
    5. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Manual , and then press OK .
  2. Set the IP settings from the Manual IP Settings menu using the following instructions. For this item... Do the following... IP Address Type a manual IP address on the same subnet, but outside of the DHCP range. Choose an IP address with the same first three digits as the assigned IP but a much higher fourth digit (between 1 and 254). For example, if the original IP was 192.168.0.1, assign the static IP to 192.168.0.200. Subnet Mask Do not change the Subnet Mask. Default Gateway Do not change the Default Gateway.
  3. Run the Wireless Setup wizard and try to associate the HP All-in-One to the wireless network.
Workarounds Connect the HP All-in-One via a Wired Network
  1. Disable Wireless Radio. Follow these steps to turn off Wireless Radio.
    4. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Wireless Radio , and then press OK .
    5. Press the left arrow button (c01135026.jpg ) or the right arrow button (c01135027.jpg ) to select Off , and then press OK .
  2. Connect an Ethernet Cable to the RJ-45 connector at the back of the HP All-in-One.
  3. Connect the other end of the Ethernet cable to one of the LAN ports of the router.
  4. Turn off the HP All-in-One by pressing the Power button. Turn on the HP All-in-One again.
Connect the HP All-in-One via Ad Hoc Wireless Network
  1. On the HP All-in-One control panel, press Setup .
  2. Use the down arrow button (c01155210.jpg ) to highlight Network , and press OK to display the Network menu.
  3. Use the down arrow button (c01155210.jpg ) to highlight Wireless Setup Wizard , and press OK . The Setup wizard searches for available networks, and the color graphics display shows a list of detected wireless network names (SSIDs).
  4. Use the down arrow button (c01155210.jpg ) to highlight your wireless network SSID, and press OK . If any encryption is configured in the computer, the wizard will prompt for the WEP key.
  5. Highlight the letter or number on the visual keyboard, and press OK .
  6. Highlight Done on the visual keyboard, and press OK .
  7. Press OK again to confirm the settings. The HP All-in-One will try to connect to the wireless network. Once the wireless network is successfully setup, a message should appear stating that the connection has been successful.
  8. Press OK .
Source: www.hp.com
To get the technical document click here ==>> Document
Please let me know if the issue wont resolve the problem so that we can go ahead and do another workaround.
thank you.
adonscott
Aug 21, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Kodak EasyShare DX4530 Digital Camera Logo
62 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
