Question about Dell Inspiron 4100 Cooling Fan - AD2005LB-G73 CD-ROM Drive
My dell inspiron 4100 cooling fan wont turn on
My dell inspiron 4100 runs pretty good but i have noticed that cooling fan doesnt run at all> It this ok? If not help me fix it please. thank you
  • 119 Answers
I would get a new fan. you can get a new fan and heatsink by clicking here
Really hope this helps you.
Posted on Jan 19, 2009
Car gets hot pretty quick and will overheat, noticed fans arent coming on when car is hot or if I turn a/c on. Have caught them running recently but didnt catch it again.
it could be the cooling fan relays or possibly the cooling fans. to check the fans disconnect the plug at the fans and run jumper wires to them both power and ground. if they don`t work then the fans are bad. check voltage and grounds at the plugs when they should be running, if they are good then the wiring is good. it could also be the coolant sensor for the fans that send the signal from the sensor to the computer so it knows when to turn on the fans. the fan that runs with the A/C when turned on could be the A/C relay.
Sep 10, 2015 | 2003 Dodge Intrepid
Dell inspiron D610 fan wont turn on
New cpu heatsinks use water in sealed tubing, and can cool for a long while. Idling computer may not need more cooling.
Mar 15, 2012 | Dell Lattitude D610
My DELL inspiron 1545 laptop keeps restarting itself. Wont let me on word and some of my short cuts wont appear.
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
If none of this solves the problem, or is not the case, then you might have a bad motherboard.
Sep 23, 2010 | Dell Inspiron 1545 Notebook
My computers cooling fan keeps speeding up and slowing down is that a good thing or a bad thing
I'm assuming your desktop has an AMD processor?
AMD have a process called "quiet and cool" this basically speeds up the fan when the processor is under load and getting hot or slows it down when the processor isn't working as hard.
Regards
Mike
May 26, 2010 | Dell Inspiron 531s Desktop Computer
Piercing, loud alarm when starting Dell Inspiron 4100 laptop
Most likely, the CPU cooling fan, as the system doesn't really start generating any heat until the windows video initializes. If you have the resource CD, run the diagnostic for the fan, see if the noise occurs during the test.
Dec 14, 2009 | Dell Inspiron 4100 Notebook
My laptop crashed because my cooling fan failed.
It is possible but not guatanteed but fans are pretty cheap anyways so it's worth a try
Sep 21, 2009 | Dell (6F858) Cooling Fan
Problem with overheating.
Hi Dear. Always Pick n Place notebooks very carefully. When need to pick with both hands you can pick it in any direction but when need to pick with single hand, always use vertical position, without pressing and forcing any area. Place it on any flat surface where you are sure that exhaust system of CPU's fan is well ventilated. Heating problem may occure due to many reasons. Verify CPU fan function in BIOS, Clean CPU cooling fan and exhaust system with Electric Blower. NEVER use continuous charging, plug out charger wire when battry is 100% full, charg again when low battry alerts. This will increase battry life & backup time.
Apr 15, 2009 | Dell Inspiron 1525 Laptop
Inspiron 5150 fan continously running
Dell Inspiron 5150, has overheating problems. The position of the fan is a problem.Also,don't press of the left upper corner of the laptop.Here's an excerpt from a wikipedia article: "The overheating problems on the Inspiron 5150 model was due to the position of the fan and fan-vent and the way in which it vents air through the CPU's heatsink.[citation needed] The fan draws air from underneath the unit and vents it through the rear after passing over the heatsink. However, the unit also sucks up dust from underneath it. Over time a buildup of dust constricts the airflow through the unit, reducing cooling. The airflow is perceptibly diminished. A simple test is to place a hand near the fan vent; when the fan is running at high speed there should be a good flow of warm air. Heat will also build up along the top of the unit near the LCD display and left toward the optical drive. Users may notice this while typing. Performance may also suffer, with jittery game movement and slow Windows performance. Some systems may experience jerky reactions where the unit goes into an almost slow-motion phase for short periods of time. Continued operation in this condition may lead to overheating and could result in permanent damage to the CPU, GPU, motherboard and other internal components. To remedy this the unit must be disassembled, the dust removed, and fan operation checked. This problem not uncommonly results in a CPU temperature-increase of between 15-20°C over an normally functioning unit. Further temperature increases may damage the casing of the unit."From Wikipedia article"Dell Inspiron" under problems Hope it helps -CG
Jan 20, 2009 | Dell Inspiron 5150 Notebook
Not enough video memory
The Inspiron 4100 has a 16MB video card built in to the motherboard. It is not upgradable. It appears that the system doesn't meet the minimum requirements for the program, so you'll have to get a more powerful system to run that application. sorry =(
Jan 01, 2009 | Dell Inspiron 4100 Notebook
Computers & Internet Logo
367 people viewed this question
Alun Cox
