Question about AOC CT720G 17" CRT Monitor
Hi...my AOC 17" CRT monitor display on the screen says NOT SUPPORTED OUT OF RANGE... i try to change the screen resolution by using other monitor but still nothings happen..
  • 1 more comment
  • wakashik Dec 18, 2008
    i have d sme problem!!!but ur solution did not work!!!!i think "not supported out of range" will be my screensaver!!!is thre any other solution?or i'd rather but a new 1?
  • jireh30 Mar 19, 2009
    it is not that.. when you open the computer..nothings appears from the start..when the motherboard loads.. the massage already appears..no image of boot up no image of system check.. it just display NOT SUPPORTED.. thats all..in short.. when the monitor is turned on the 1st thing will appear is the massage.. thats all
  • jesserhad Apr 12, 2009
    Yes me too.. I have the same problem NOT SUPPORTED OUT OF RANGE... No image of boot up no image of system check.. It has the same message when I transferred the monitor to another CPU. I have 10 monitor with the same brand AOC 771S silver black and there is only 1 monitor displaying that message.
  • 120 Answers
Change to the lowest settings you can on the other monitor, then connect the 17" CRT. If you can see anything, go to display settings and slowly bring the settings up. If you lose the display, press "n" (there is a dialog box asking if you want to keep the settings, y or n). Most likely it is a refresh rate that is set to high. Try setting this to 60 Hz for starters.
Hope this helps.
Posted on Dec 12, 2008
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
My monitor changes colors (e.g. normal then turns
Color changes on the display mostly occurs because of a faulty VGA cable or a loose connection of the cable to the VGA port at the back of your PC or Monitor. But if the cable is fixed securely at the back and the problem still persists, slightly move the cable's wire segment while observing its reaction on your monitor. Does it change colors while u do so? If it does even when the cable is securely plugged in to both the PC and the monitor, then u need to change the cable.
As for the visible display area size (technically called the Resolution) right click on an icon free area on the desktop and click Properties. At the top of the form click on the Settings tab. At the bottom of this form find Screen Resolution and adjust it to it your requirements and click Apply. On the confirmation dialogue that pops up click Yes if the displayed resolution suits u otherwise click No and try another resolution size. Hope this helps.
Nov 28, 2009 | AOC CT720G 17" CRT Monitor
"Not support Out of range"
You have to boot your PC in safe mode using press F8 key.
after that you decrease the resolution in the display setting section.
It will help you.
Nov 29, 2008 | AOC CT720G 17" CRT Monitor
AOC 17" Flat CRT Monitor
Could be problem of key switches!
Try replacing or check for leakage,high resistance across switches using ohmmeter.
Samir
Jul 26, 2008 | AOC CT720G 17" CRT Monitor
Out of Range error
in my experience lowering the resolution will fix "out of range error"
yes, you are correct
Jun 03, 2008 | Taxan Ergovision 735 TCO 99 17" CRT...
INPUT SIGNAL OUT OF RANGE
some how your screen resolution has changed above or below what your monitor can display. you need to boot your computer using another monitor that can work with the resolution your computer has switched to(i used a spare crt monitor when it happened to me) change your resolution in display properties to a normal level like 1027x768, and while the computer is on swap the monitor cables to verify the lcd is working.
It is perfectly safe to unplug the video cable and plug it back in while the computer is turnned on.
Dec 26, 2007 | Relisys TL775 17" LCD Monitor
AOC CT720G 17" CRT Monitor Logo
405 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
