Question about Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
Samsung SP0802N External Case?
Is there any External Hard Drive Cases (that work through the USB) that are compatible with the Samsung Spinpoint Model SP0802N?
    Problem Solver:
  • 16 Answers
Hi, try this. This will work with your HD. 2.5"/3.5" EN391-S2HC USB 2.0/eSATA SATA HDD Dock w/Card Reader & Hub
Posted on Dec 12, 2008
How do you take a internal Samsung SP0802N and set the pins to make it an external backup HDD HDD
well u dont have to do anything with the pins my friend there is a casing available in the market for sata as well as ide by which u can use an internal hdd as an external .... u can get it from a local computer shop
Feb 08, 2011 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung sp0802n hdd, failure is imminent back up data and replace. wont let me, just goes back to the BIOS screen.
The disk is about to fail and Windows is corrupted. Boot from a Linux Live-CD and copy all your data to an external hard disk. Then replace the hard disk with a new one and junk this one, reinstall Windows and copy all your files from the external hard disk in the new internal one.
Oct 16, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
The HDD is in a Mobile Disk external package. The external power supply is dead. I need the specs for a power supply ( voltage, current).
This will resolve your issue,
http://www.samsung.com/ph/consumer/monitor-peripherals-printer/hard-disk-drive/35-pata-hdd/SP0802N/index.idx?pagetype=prd_detail&tab=spec&fullspec=F
please remember to vote right if my recommendation resolves your problem,
regards
Mar 24, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung sp0802n HDD enclosure. I installed everything. The safe remove program detect the massage storage, but the hard drive icon does not show.
Has the hard drive been formated?
To format the drive, plug the external drive into the USB port - go to the Control Panel - Administrative Tools - Computer Management - Storage - Disk Management. The External drive should be listed as USB drive. On the lower panel, right click on the USB Drive and click on Format, and format it in NTFS.
After formating you will be able to use it as a normal hard drive.
Aug 01, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung sp0802n. s.m.a.r.t capable and status ok
please check if the data cable or the controller might be bad or it cud be even the hadd if alls fine then try doing a format reinstall
Jun 23, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Is Samsung sp0802n dma/ata-33(ultra) or ATA-133, what's different
can I buy yours and maybe your parts will work with mine, mine just wont spin
Apr 14, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
FOR CHECK WARANTY
12 months parts and labor based on the model you used in the listing of your question. A:
SP0802N
I guess you probably bought this from a retail outlet.
Best,
Worldvet
Jan 20, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Hard disk Warranty
Contact Samsung
Model: Samsung Spinpoint SP0802N
Call 1-800-SAMSUNG (1-800-726-7864)
Jan 10, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung 160gig hard drive printed circuit board
try ebay with the same model number. You can transfer the circuit boards, retrieve the data, then you have a spare backup. Otherwise you can try to identify the component and check if digikey or mouser has a replacement. Sometimes if you're lucky the component is a bias diode that is designed to burn out with reversed power. Sometimes the visible damage may not be the only damage and other parts have fried. Touch a grounded object (like the case of your computer that's plugged in) before touching the components, and retouch it frequently, or wear static dissipative wrist strap
http://www.digikey.com/
http://www.mouser.com/index.cfm?handler=home
Nov 30, 2007 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Samsung SpinPoint P80 SP0802N 80 GB Hard Drive Logo
322 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
