Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
Stereo signal bleeds through
I can hear a local radio station through my tv whether the cable is on or not.
    Problem Solver:
  • 10 Answers
DO YOU HEAR IT ON ALL CHANNELS?, DOES THE SHIELD ON YOUR CABLE HAVE A CUT IN IT? HOW CLOSE IS THE RADIO STATION?
Posted on Dec 22, 2008
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
Sat nav and radio not working
Good Afternoon Michael
Sounds most likely to be an antenna issue. Most everything going into the radio needs an antenna to be picked up. Sometimes, a station or two might still be heard above the static if they are local and fairly strong signals.
If you can get normal sound from other inputs, like MP3 players or CDs, then the amp and output parts of the unit are fine, and it's an issue of getting an input signal to use.
If you have the tools, pull the stereo head unit from the dash and make sure the antenna input cable(s) are firmly in place. Likewise, depending on location, you can likely get to the base of the external antenna, where the other end of the cable plugs in, and make sure it's in snugly.
lacking the tools - you can talk to your dealer or a local car audio place. They'll likely have the tools, and a check for antenna cable connection would not likely be too expensive or time-intensive.
Good Luck!
Nov 18, 2015 | Mercedes-Benz C-Class Cars & Trucks
I have cobra 25 ltd and i,m picking up signals from hundreds of miles away can i tune it down to pick up more locally
Try turning down the RF gain. It is the 2nd knob to the left of the channel selector. This will limit skip stations and receive only local higher signal stations to come through. Do not turn it too low or you won't hear much of anything. Hope it helps.
Tom
Oct 01, 2012 | Cobra 25 LTD 40-Channels Base CB Radio
No Sound on AM or SW
Hello
If the set receives FM signals without any problem, and only fails to receive AM signals, the IC [integrated circuit] used in it is faulty. The number of the IC used with your radio is CXA 1376AS. It is a replacable type IC, and can be bought from most of the electronic spare part shops at your town. If you want further details about its service manual, get me by Fixya. OK.
Nov 11, 2011 | Sony ICFSW7600GR FM Stereo World Band...
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
Radio Interferance on my logitech computer speakers
You may be now living too close to a radio station. Sometimes when this is the situation, anything electronic gear plugged into a wall socket can act like an antenna, thus receiving signals from local radio stations.
Mar 10, 2010 | Logitech X-530 Computer Speakers
I have a 1995 camaro with a bose stereo, my problem is that the electrical ariel broke,so I replaced it with a new one , but now I cannot recieve the local stations.
Hello! The coax cable is either open or grounded between the new antenna and the vehicle's radio. Check the connection from the new antenna to the extension cable; Your vehicle has an extension if the distance from the end of the antenna cable to the radio requires it.
When you connected the new coax to the radio or the extension you may have bent the center conductor.
Examine the connections, insuring they are trouble free.
The center signal carrying conductor could be touching ground. If you have an ohm meter, set it on the X10 scale and measure between the signal wire to ground "at the radio"; Reading= open. Measure from the antenna itself to the signal wire "at the radio"; Reading= zero ohms...
Guru..............saailer
Jan 16, 2010 | Car Audio & Video
How to get hd picture through my insignia tv without digital cable
Unfortunately, at this time, you don't unless it is a powerful station local to you. In order to see which stations are available to you, you would enter the Setup menu of your tv, and then the section that allows you to scan for channels.
Also, digital cable alone doesn't guarantee you'll get HD signal. You would have to order an HD package from your cable or satellite provider. For example, Comcast touts their digital package as if it were vastly superior to the "standard" signal. Whether or not it is would be a matter of opinion, but the digital package is not HDTV. This misconception has disappointed many a subscriber, myself included (until I ordered the HD package). :^ )
Jul 03, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Bad reception
Try to swicth your settings to local,so you can pick up your local stations.
May 16, 2009 | Car Audio & Video
Mono/stereo flashes in upper left tv
The mono/stereo is an indicator of the audio signal that the TV is outputing. Like most car radios, they have an indicator that tells you when a station in coming in clear, which may be just an LED or a light. When the signal is weak or when your on a non-stereo station the indicator will not be on. What signal are you providing to the TV? Cable, OTA, STB output??? low RF signal level could be the cause for this.
Mar 18, 2007 | iLO 3200 32 in. LCD Television
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
59 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
