Question about RCA DIRECTV Satellite Remote Control
Explain function butons on remote
As you did chang someting in your signal,our remonte dont work the same.Explain how do I program and switch from canel to chanel.
example;
we are watching chanej 248 now in time of commercial we want to svitch just by pushing one buton to chnel 220.
how to program th control?
thank you
  • 905 Answers
The only way this will work is to be on one of the channels you want then push in the numbers of the other channel you also want to watch , then there is a last or back button on the remote that will switch back and forth to those channels untill you change the channel to another , then it will switch back between those last two channels
Posted on Dec 12, 2008
I have a p0laroidtv & the remonte that came with the tv is not working w/ the tv
Remote issues and answers:
1) If you are using a universal do not expect if it does program to have all the functions you had with the original remote.
2) If you are searching for codes to program Google model number of set and or remote. Some remotes have a search where you can try every code in the remote one at a time.
3) If remote does not work at all-have it tested first, most shops have a tester for this and also some digital cameras will react on the screen when the remote is pointed at them and a button pressed.
4) Check the batteries and the connection are clean and batteries not loose.-
Apr 04, 2012 | Televison & Video
My turn signals have been working on and off i changed the relay and worked for a day, what could it be
Hi, you dont explain if you mean they dont light, dont flash, if they dont light remove the relay
Aug 31, 2011 | 1989 kawasaki ZX 10
Remote stopped working all bar two buttons but no channel buttons on/off or volume. The red indicator flashes on TV when sending but no response on TV have changed batteries
If the TV is receiving the signal then it will not be the hand set batteries. It could be related to the IR controller inside the TV. this will send information to the Driver board to change something, e.i channel etc. if you can get to this, see if there is a connector loose. can you recall it being bashed or knocked?
Is it an authentic branded TV remote? or replacement? some replacement ones need programming. it might have lost it's settings? could explain why only a few buttons work..
May 11, 2011 | Televison & Video
Remote does not work on my 2007 GMC Yukon. I changed battery and I used spare remote, but no response. After I drive the vehicle, the remote will work, but after I few minutes, it goes back to not working....
I'm almost certain when you program remotes, they must both be programmed at the same time. This may explain why your spare didn't work. I think I would make sure both have good batteries and program them both at the same time.
Dec 29, 2017 | 2007 GMC Yukon Denali
How do you make the doors not lock when you start your car with a crime stopper remote start
That is a function of the security system. Are you sure you want remote start without locking the doors? I don't believe you can change the programming of that function but the user manual for your alarm should explain how if it can by done.
May 11, 2010 | 2-Way Remote Starter
Lost a tv remote in a fire. Bought a universal remote but cannot fine a code to program it.
read the directions at the part where it says manually program, you have to do certian functions then push the channel up and down until tv responds then its programmed, this is actually finding the code as you go, instructions will explain it all because ech universal is just a little diff in its manual process.
Dec 18, 2009 | Vizio L32 32 in. LCD HDTV
Need JVC (I-Art) 32" Television Remote Control Code
ok that remonte control must to have autosearch code,on the manual of that remonte control you will find the instruction how to do that and the remonte will do the job for u
Dec 10, 2008 | JVC AV27F476 27" TV
Code for Magnasonic TV
If the GE doesn't have a code scan function (similar to ExpressVu remotes) then you can always buy a programmable remote such as the Logitec Harmony. I tried it and it works fine on my Magnasonic GCT5501.
Sep 19, 2008 | Televison & Video
Running lights work but not the turn signals
You need a new Multifunction switch...Its very common. The switch controls those functions and more. Its hard to explain how it works but I am pretty sure thats what it is.....
Jul 22, 2008 | 1994 Jeep Grand Cherokee
RCA DIRECTV Satellite Remote Control Logo
125 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
