Blown power transformer
I have a blown power transformer in a marantz 1070 that I would like
to replace. I can not find the part anywhere. Any ideas?
part number on the transformer is ts19602080
also has 10v4z..
can this be replaced with a transformer that is not original equipment.
if so, how do i spec the transformer?? thanks.
  • 1,512 Answers
Hi
What has happened to the transformer. Does it have an open circuit primary?  Get back to me if you want a fix.
regards robotek
Posted on Dec 19, 2008
Marantz PM7200 Stereo Amplifier: Can a production fault with an amplifier cause it to keep blowing the speaker on one side, while the other side's speaker is fine?
It could be the amplifier but most likely it’s going to be either the connections or a power supply issue. Do you have anything plugged into the same outlet? What type of power strip are you using. The amp will usually go into a protect mode as to not damage anything before it would create the environment to cause a blown speaker. I know that with your model, along with multiple others, have had issues with the power board needing replacement.
Jan 13, 2018 | Marantz Audio Players & Recorders
How do I check the internal wiring for input voltage on a Marantz 4060 Quad Amp?
The only way would be a voltage selection switch on the back of the unit, or changing pigtail leads on the primary side of the power transformer.
Apr 30, 2014 | Marantz MA-9S1 2-Channel Amplifier
Marantz amplifier PM68 replace fuse
You don't see any glass fuses? There is also a non replaceable fuse in the power transformer.
Apr 06, 2014 | Marantz PM-68 Amplifier
Plugged marantz sr8100 into 230V outlet without transformer. Did this likely cause irreparable harm to receiver?
Hello
If you have plugged in to 230AC with voltage settings was 110VAC, the transformer has been damaged already [opend winding]. If the voltage settings was 230VAC itself, there will be no harm to its internal transformer. Anyway, open it, anc check the fuses. In some cases, fule only will blow out, preventing from furhter damages. I'm not sure about it, but check it. If the fuse only has blown out, and there has no harm; you are lucky I should say. OK.
Apr 07, 2011 | Marantz SR8001
Amplifier lack of power supply
there is short circuit check the transformer and big capasitor for tanrsformer
Mar 21, 2009 | Jl Audio E1200 Car Audio Amplifier
Marantz 1070 transformer
Hi..
Are you sure?. The DC resistance on a primary winding is VERY low
( less than 4 ohms)
What happens if you disconnect all the secondary windings and plug the AC in?
If it's really broken I'd try the audiokarma.org blog /users group
Jan 09, 2009 | Audio Players & Recorders
Buzz in amplifier power transformer. The amp is a Marantz Model 240. It functions perfectly well, and there's no noise from it in the speakers, but the transformer buzzes whenever the unit is plugged in...
All transformers buzz though you cannot hear it normally. The big transformers on power lines like to buzz for all to hear. When a transformer in a stereo amp gets old and deteriorates or gets hot and  expands the coils, melts the coil varnish and epoxy coatings then rattles at 60 times per second.    You can ignore it or change the transformer. There are too many layers of windings to try to stick anything in there.  Disconnecting a transformer results in inductive kickback -that's not money. It's a big, whopping electrical gotcha! Be careful! Good luck, Steve Medley
Nov 09, 2008 | Marantz Audio Players & Recorders
Baumatic hood bt82.1 lamps blown..
Hi johnnyi6,
I'm Harvey the Master Plumber.
Your problem is: had a crackling noise then pop..looks like transformer has blown,replaced
but still no lights ..fan o.k...don't appear to be getting any power to transformer via switch?...how do you get push button switch out?...
bypassed light switch and lights o.k with new transformer..any ideas..
Yes, I agree, the switch went bad. It snaps in so you will break it during removal. I recomend you get the replacement switch first so you don't have a wire hanging out while you wait for the new one.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 15, 2008 | Baumatic F60 Stainless Steel Kitchen Hood
Marantz pm 7200
Could be a power supply failure or a Power "On" switch failure.
Kev
Feb 23, 2008 | Marantz PM7200 2-Channel Amplifier
Marantz mm9000 has died
The main power transformer may not have the correct voltages coming out of it. I would check the output volts at the terminals. I would also check the out puts from the solenoids.
GOD LUCK
BIG RED
Jan 25, 2008 | Marantz MM9000 5-Channel Amplifier
268 people viewed this question
 Grubhead
Grubhead
