Question about Mitsubishi VS-60607 TV
TV dark or dim
Evacuted for a Hurricane 6-9 mos ago and took my VS-60607 Misubishi TV with me. I don't guess we placed it very well in the back of the truck and the wind blew the screen inwards and 'love bugs' were splated all over it and in it. My sister and I took the front apart and cleaned it throughout. Since then, when the TV is turned on I have all the colors of the rainbow for about 45mins to an hour before it adjusts the color. But even then it is not perfect..the brightness control is adjusted all the way up and it still has parts that are dark...especially when whatever you are watching has dark areas of the movie/TV show. Could a bulb be out? Is my TV runined? Thanks in advance for any help.
    President:
  • 4,402 Answers
This model is famous for fluid leaks. each projector True True (``````````` (``````````` 0 95250 95250 TV dark or dim - clip_image002.gif tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
this depends on how bad the damage is in the tv. in most cases we can reseal the tube and clean up the fluid 400-600.
Once you
take the tube out you will see where it leaked. The problem is that the
frame on the CRT that the heavy screws with springs are mounted on (that
hold the lens coupled to the CRT) is weak and they can bend. We have seen
several that have leaked after the customer moved the set. You can only
tighten them down so much because the frame bends. It is just stamped metal
and not welded at the corners to support the bend.
We remove the CRT, clean it all up, add a very small amount of RTV sealer to
the gasket, reassemble, let the RTV cure thoroughly and refill with coolant.
The extra sealer should prevent future leaks. Haven't had a recall yet.
Mits says replace the CRT...too costly.
You msut check the yokes carefully as well. If any coolant gets into them
you can end up with shorts there and a mess.
or could be
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
Posted on Feb 11, 2008
I have a Mitsubishi VS-60607 Tv and it started out
Without going in with troubleshooting equipment it is hard to determine if the problems are related or not but it is unlikely since you seem to have a video problem and a convergence problem , which are two separate circuit(signal processing and deflection). Hope this help.
Please do not rate this answer(unless it helps)as it is only a suggestion.
Dec 03, 2009 | Mitsubishi VS-60607 TV
When i on the t.v it looks double and then off.VS 60607
Ur convergence is dead,U know how to solders?Buy a convergence kit,replaced what in that kit.Ur tv will be back to normal.This Website have that kit.Tv repair World.com.
Oct 15, 2009 | Mitsubishi VS-60607 TV
Does the VS-60607 have a digital tuner
No it does not. Only mitsubishis with a digital tuner are the ones that have a DM inside.
Dec 12, 2008 | Mitsubishi VS-60607 TV
Mitsubishi VS 60607 60" TV
From what i have been told the VS - 60607 was built in 2000 and i am not sure if it is HD or not.....
Aug 31, 2008 | Mitsubishi VS-60607 TV
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Vs-60607 brightness problems
This sounds like it is a problem with the tv. Mitsubishi does have a problem with filter caps in thier regulator circuits. A repair tech will have to fix it.
Mar 06, 2008 | Mitsubishi VS-60707 60" Rear Projection...
VS-60607 Dark screen when 1st turned on...
this model is famous for fluid leaks. each projector True True (``````````` (``````````` 0 95250 95250 tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
Once you
other wise this is common problem too.
http://www.hdtvoice.com/voice/index.php?s=
Apr 23, 2007 | Mitsubishi VS-60607 TV
Mitsubishi VS-60607 TV Logo
80 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
