When I insert my graphic card Ati HD 4850,my system does not boot.I am getting post code error 52 -Test memory(clear all extended memory to 0).Also the fan spins to 100% and does not want to stop.Two lights on the back of the graphic card does not lit(D1601 and D1602).Tried different slots and the same problem.When I change graphic card for Ati HD 3870 I do NOT have any problems,everything is fine and system booting without any problems.The card was fine for about 2 weeks(no warranty ,the card is from e-bay)I tried also use my hd3870 to have a look what is wrong with hd4850,then I've inserted hd 3870(master)and hd 4850(slave) and system was fine but could not see hd 4850 in device manager and fan was 100% speed.For me it looks like overheating and voltage problem but I'm not to sure about post error.ANY ideas?Thanks.Vic
  • s_wasiak Dec 12, 2008
    yes, my system is quite powerful.
    I have 8.12 version but I will try with 8.11.
    Genius:
  • 1,605 Answers
Are your system meet the requirement???
ATI Radeon™ HD 4850 System Requirements
  • PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
  • 450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode)
  • Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
  • Minimum 1GB of system memory
  • Installation software requires CD-ROM drive
  • DVD playback requires DVD drive
  • Blu-ray™ playback requires Blu-ray drive
  • For a complete ATI CrossFireX™ system, a second ATI Radeon™ HD 4850 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per graphics card (included) are required
Posted on Dec 12, 2008
  • Frank
    Frank Dec 12, 2008
    try to install the new driver first. the insert the card.
Beep codes
AMI BIOS beep codes Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions 1 short DRAM refresh failure 2 short Parity circuit failure 3 short Base 64K RAM failure 4 short System timer failure 5 short Process failure 6 short Keyboard controller Gate A20 error 7 short Virtual mode exception error 8 short Display memory Read/Write test failure 9 short ROM BIOS checksum failure 10 short CMOS shutdown Read/Write error 11 short Cache Memory error 1 long, 3 short Conventional/Extended memory failure 1 long, 8 short Display/Retrace test failed Award BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary. Beep Code Description 1 long, 2 short Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information Any other beep(s) RAM problem. If any other correctable hardware issues is found the BIOS displays a message. No Power, Loose Card, or Short.1 Short BeepNormal POST, computer is ok.2 Short BeepPOST error, review screen for error code.Continuous BeepNo Power, Loose Card, or Short.Repeating Short BeepNo Power, Loose Card, or Short.One Long and one Short BeepMotherboard issue.One Long and Two Short BeepsVideo (Mono/CGA Display Circuitry) issue.One Long and Three Short Beeps.Video (EGA) Display Circuitry.Three Long BeepsKeyboard or Keyboard card error.One Beep, Blank or Incorrect DisplayVideo Display Circuitry. Phoenix BIOS Q3.07 OR 4.X Beep Code Description and what to check 1-1-1-3 Verify Real Mode. 1-1-2-1 Get CPU Type. 1-1-2-3 Initialize system hardware. 1-1-3-1 Initialize chipset registers with initial POST values. 1-1-3-2 Set in POST flag. 1-1-3-3 Initialize CPU registers. 1-1-4-1 Initialize cache to initial POST values. 1-1-4-3 Initialize I/O. 1-2-1-1 Initialize Power Management. 1-2-1-2 Load alternate registers with initial POST values. 1-2-1-3 Jump to UserPatch0. 1-2-2-1 Initialize keyboard controller. 1-2-2-3 BIOS ROM checksum. 1-2-3-1 8254 timer initialization. 1-2-3-3 8237 DMA controller initialization. 1-2-4-1 Reset Programmable Interrupt Controller. 1-3-1-1 Test DRAM refresh. 1-3-1-3 Test 8742 Keyboard Controller. 1-3-2-1 Set ES segment to register to 4 GB. 1-3-3-1 28 Autosize DRAM. 1-3-3-3 Clear 512K base RAM. 1-3-4-1 Test 512 base address lines. 1-3-4-3 Test 512K base memory. 1-4-1-3 Test CPU bus-clock frequency. 1-4-2-4 Reinitialize the chipset. 1-4-3-1 Shadow system BIOS ROM. 1-4-3-2 Reinitialize the cache. 1-4-3-3 Autosize cache. 1-4-4-1 Configure advanced chipset registers. 1-4-4-2 Load alternate registers with CMOS values. 2-1-1-1 Set Initial CPU speed. 2-1-1-3 Initialize interrupt vectors. 2-1-2-1 Initialize BIOS interrupts. 2-1-2-3 Check ROM copyright notice. 2-1-2-4 Initialize manager for PCI Options ROMs. 2-1-3-1 Check video configuration against CMOS. 2-1-3-2 Initialize PCI bus and devices. 2-1-3-3 Initialize all video adapters in system. 2-1-4-1 Shadow video BIOS ROM. 2-1-4-3 Display copyright notice. 2-2-1-1 Display CPU Type and speed. 2-2-1-3 Test keyboard. 2-2-2-1 Set key click if enabled. 2-2-2-3 56 Enable keyboard. 2-2-3-1 Test for unexpected interrupts. 2-2-3-3 Display prompt Press F2 to enter SETUP. 2-2-4-1 Test RAM between 512 and 640k. 2-3-1-1 Test expanded memory. 2-3-1-3 Test extended memory address lines. 2-3-2-1 Jump to UserPatch1. 2-3-2-3 Configure advanced cache registers. 2-3-3-1 Enable external and CPU caches. 2-3-3-3 Display external cache size. 2-3-4-1 Display shadow message. 2-3-4-3 Display non-disposable segments. 2-4-1-1 Display error messages. 2-4-1-3 Check for configuration errors. 2-4-2-1 Test real-time clock. 2-4-2-3 Check for keyboard errors 2-4-4-1 Set up hardware interrupts vectors. 2-4-4-3 Test coprocessor if present. 3-1-1-1 Disable onboard I/O ports. 3-1-1-3 Detect and install external RS232 ports. 3-1-2-1 Detect and install external parallel ports. 3-1-2-3 Re-initialize onboard I/O ports. 3-1-3-1 Initialize BIOS Data Area. 3-1-3-3 Initialize Extended BIOS Data Area. 3-1-4-1 Initialize floppy controller. 3-2-1-1 Initialize hard disk controller. 3-2-1-2 Initialize local bus hard disk controller. 3-2-1-3 Jump to UserPatch2. 3-2-2-1 Disable A20 address line. 3-2-2-3 Clear huge ES segment register. 3-2-3-1 Search for option ROMs. 3-2-3-3 Shadow option ROMs. 3-2-4-1 Set up Power Management. 3-2-4-3 Enable hardware interrupts. 3-3-1-1 Set time of day. 3-3-1-3 Check key lock. 3-3-3-1 Erase F2 prompt. 3-3-3-3 Scan for F2 key stroke. 3-3-4-1 Enter SETUP. 3-3-4-3 Clear in POST flag. 3-4-1-1 Check for errors 3-4-1-3 POST done - prepare to boot operating system. 3-4-2-1 One beep. 3-4-2-3 Check password (optional). 3-4-3-1 Clear global descriptor table. 3-4-4-1 Clear parity checkers. 3-4-4-3 Clear screen (optional). 3-4-4-4 Check virus and backup reminders. 4-1-1-1 Try to boot with INT 19. 4-2-1-1 Interrupt handler error. 4-2-1-3 Unknown interrupt error. 4-2-2-1 Pending interrupt error. 4-2-2-3 Initialize option ROM error. 4-2-3-1 Shutdown error. 4-2-3-3 Extended Block Move. 4-2-4-1 Shutdown 10 error. 4-3-1-3 Initialize the chipset. 4-3-1-4 Initialize refresh counter. 4-3-2-1 Check for Forced Flash. 4-3-2-2 Check HW status of ROM. 4-3-2-3 BIOS ROM is OK. 4-3-2-4 Do a complete RAM test. 4-3-3-1 Do OEM initialization. 4-3-3-2 Initialize interrupt controller. 4-3-3-3 Read in bootstrap code. 4-3-3-4 Initialize all vectors. 4-3-4-1 Boot the Flash program. 4-3-4-2 Initialize the boot device. 4-3-4-3 Boot code was read OK.
http://www.computerhope.com/beep.htm
Jul 09, 2014 | EliteGroup GeForce6100PM-M2 Motherboard
Tip
A list of the compatible PCI-Express 16X Graphics cards for a PCI-Express...
Having trouble finding out which graphics card will work with your PCI-Express motherboard? Here is a list all PCI-Express graphics cards for AMD/ATI Radeon. This list is in descending order. (The top graphics cards from each manufacturer are more recent, have greater memory and are faster while the bottom are older, have less momory and are slower).
If your Motherboard supports PCI-Express X16 then here is a list of compatible ATI/AMD Radeon Cards.
AMD Radeon 6000 Series - (AMD Radeon HD 6870 and AMD Radeon HD 6850)
ATI Radeon 5000 Series - (ATI Radeon HD 5970, ATI Radeon HD 5870 Eyfinity 6, ATI Radeon HD 5870, ATI Radeon HD 5850, ATI Radeon HD 5830, ATI Radeon HD 5770, ATI Radeon HD 5750, ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5870, ATI Radeon HD 5550 and ATI Radeon HD 5450)
ATI Radeon 4000 Series - (ATI Radeon HD 4870 X2, ATI Radeon HD 4890, ATI Radeon HD 4870, ATI Radeon HD 4850, ATI Radeon HD 4830, ATI Radeon HD 4770, ATI Radeon HD 4600, ATI Radeon HD 4550, ATI Radeon HD 4300 and ATI Radeon HD 4200)
ATI Radeon 3000 Series - (ATI Radeon HD 3800, ATI Radeon HD 3600, ATI Radeon HD 3400)
ATI Radeon 2000 Series - (ATI Radeon HD 2900, ATI Radeon HD 2600, ATI Radeon HD 2400)
ATI Radeon X Series - (ATI Radeon X1950, ATI Radeon X1900 and ATI Radeon X1800)
If your Motherboard supports PCI-Express X16 then here is a list of compatible Nvidia Cards.
GeForce 500 Series - (GeForce GTX 580)
GeForce 400 Series - (GeForce GTX 480, GeForce GTX 470, GeForce GTX 465, GeForce GTX 460, GeForce GTS 450, GeForce GT 440, GeForce GT 430, GeForce GT 420)
GeForce 200 Series - (GeForce GTX 295, GeForce GTX 285, GeForce GTX 280, GeForce GTX 275, GeForce GTX 260, GeForce GTS 250, GeForce GTS 240, GeForce GT 220, GeForce GT 210)
GeForce 9 Series - (GeForce 9800 GX2, GeForce 9800 GTX+, GeForce 9800 GTX, GeForce 9600 GT, GeForce 9600 GSO 512, GeForce 9600 GSO, GeForce 9400 GT)
GeForce 8 Series - (GeForce 8800, UltraGeForce 8800 GTX, GeForce 8800 GTS (640 MB, 512MB and 320 MB versions), GeForce 8800 GT, GeForce 8800 GS, GeForce 8600 GTS, GeForce 8600 GT, GeForce 8500 GT, GeForce 8400 GS)
GeForce 7 Series - (GeForce 7950, GeForce 7900, GeForce 7800, GeForce 7600)
GeForce 6 Series - (GeForce 6800 Ultra, GeForce 6800 GT, GeForce 6800 GS, GeForce 6800, GeForce 6800 XT)
For a list of compatible AGP8X Cards for an AGP8X Motherboard click on this link to take you to my other tips page. http://www.fixya.com/support/r6784133-list_compatible_graphics_cards_agp8x
on Feb 10, 2011 | Computers & Internet
Ati hd 4850 x2 graphics card will not boot I
either you have an nvidia motherboard, or your power supply needs upgrading
Nov 14, 2009 | Computers & Internet
After the most recent HP update, my ATI 4850 now has registry issues. It no longer recognizes my second monitor and the PC only allows for basic video settings. Here is what appears when I run a check...
Yoy can find the sections in the registry with regedit from the 'run' command. That takes experienced users to deal with. Alternatively, use the device manager in 'System' and delete the display device. On re-booting it will go through the found hardware wizard and re-load the drivers.
Oct 06, 2009 | ATI RADEON HD 4850,, PCI Express Video...
Amibios post code on a gigabyte board, 8 beeps 2 beeps 1 beep on GA-6rx board, no video output, have changed cpu, memory, video card, keyboard, hd etc, still no boot----help!
Hope this helps ... from the Ami BIOS website ....
8.2 POST BIOS Beep Codes
Number of Beeps
Description
1 Memory refresh timer error.
3 Base memory read/write test error
6 Keyboard controller BAT command failed
7 General exception error (processor exception interrupt error)
8 Display memory error (system video adapter)
8.2.1 Troubleshooting POST BIOS Beep Codes
Number of Beeps
Troubleshooting Action
1, 3 Reseat the memory, or replace with known good modules.
6, 7 Fatal error indicating a serious problem with the system. Consult your system manufacturer. Before declaring the motherboard beyond all hope, eliminate the possibility of interference by a malfunctioning add-in card. Remove all expansion cards except the video adapter.
• If beep codes are generated when all other expansion cards are absent, consult your system manufacturer’s technical support.
• If beep codes are not generated when all other expansion cards are absent, one of the add-in cards is causing the malfunction. Insert the cards back into the system one at a time until the problem happens again. This will reveal the malfunctioning card.
8 If the system video adapter is an add-in card, replace or reseat the video adapter. If the video adapter is an integrated part of the system board, the board may be faulty.
Copyright 2008
Sep 26, 2009 | Gigabyte Computers & Internet
Make my wicked system WICKED. Sound hd issues palit hd4850
try these options:
1. try adjusting the main volume of your digital output(tab) under your hd audio manager.
2. try changing your cable(s).
Jul 06, 2009 | Palit Microsystems RADEON HD4850, PCI...
Radeon HD 4850. I get a blue screen every time I turn my PC on. It says something `atikmdag.sys` and it's counting to 100 and then the computer restarts. This blue screen it only happens after I install...
Blue screens are software related errors. You would need to try to start the PC in protected mode and remove the drivers from the registry and/or the startup. If possible, run the system restore and put it back to a prior date before you tried installing the drivers. It's possible you may have a card that will not work with your system.
Jun 13, 2009 | Computers & Internet
Cannot boot Leopard or Tiger
Can you pleasr post more information on when how this was started I had this problem once with bootcamp but now it was resolved. Can you still get in somewhere?
Jan 03, 2009 | Apple ATI RADEON 9600 XT for Macintosh G5...
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
