Question about Garmin GPS
1)the unit won't switch on for more than about 10 secs. I can't see the battery meter, but it's teh same if plugged into teh car charger or teh USB pon my laptop. 2)My software is out of date, and tehy want £60 for a renewal! Is there a cheaper option?
  • 446 Answers
Leave the unit for a while until it replenishes its power, this is normal if the battery is fully drained, if it doesnt still after a period of time say 1-2 hours, then it is time to change the internal batt
Posted on Dec 12, 2008
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
Nobis 7 internet tablet when I plug in the charger it will not charge I have checked the charger and it works and tablet won't charger just shows a battery with a exclamation mark in it
get ur battery out frm ur mobile fr 10 secs then connect charger then aftr upto 10 sec aftr that put battery back and switch on. if that doesnt work make sure the voltage of ur charger is compatible with ur phone . if still doesnt wrk maybe problm with ur port
note: sometimes the charger knob gets lose try putting it correctly
good day :)
Mar 08, 2015 | Equus Nobi Slate Tablet PC - The...
I have mio s600 and during the travel the car charger has stopped working, so the navigation automatically started to use it's one battery. After I pulled out the charger, and sticked it in again,
If you are using the lighter plug for charging it may have a fuse inside the plug itself the plugs into the lighter socket,,,,,look for a fuse there or if have a volt meter check for voltage reaching the unit when plugged that way If voltage is good to the unit from the car source the battery may be bad, either not getting a voltage for charging or battery not holding a charge.
Dec 07, 2012 | GPS
Why won't my Garmin Nuvi 780 charge?
A couple part answer here. The USB pin out for the Garmin is strange. If it goes into PC mode, then the cable is got the wrong pin out for the unit. Try different cables until one works.
If you can get a full charge on the unit and the battery does not provide at least an hour + of battery use, then the battery needs to be replaced. Amazon sells replacement battery kits with instructions. You just have to make sure you order the right one.
Sep 18, 2017 | Garmin nuvi 780 GPS
I am trying to charge my cars battery but I am not sure where to put the 3 way switch.
Best solution is to use the Auto mode, since the unit will monitor the battery, and automatically switch to trickle charge when the battery is full. In the Auto mode, it won't overcharge the battery.
Feb 28, 2011 | Schumacher 10 Amp Fully Automatic/Manual...
Ipod touch 1st gen seems to drain its battery when plugged in or the battery meter goes down anyway, also once the meter hits 0% it reboots and does the same thing and when the charger is unplugged it...
Make sure that you are plugging your unit into the wall. Also make sure you are using a USB charger and not a fire wire charger. Fire wire is not a compatible charger with the itouch. The way you can tell is that if your charger plugs into your computer its USB. Also when you plug in your itouch you should see the battery come up if it is charging. If it is still having trouble then it can be a bad battery, or main board. Contact Apple and see if the unit is still under warranty with this site: https://selfsolve.apple.com/GetWarranty.do
The serial number can be found on the back of the unit toward the bottom. If you have any further questions feel free to contact www.wiredextreme.com.
Nov 18, 2009 | Apple iPod touch
Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
Mar 11, 2009 | Schumacher & Fast Charge Starter Charger
Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Oct 28, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Wii charger not charging
problem is either one battery is discharged and the other is full or corrosion on battery terminal tops or batteries are defective. the red lights flash when the unit sences that the batteries have a problem with the induction charge. simple test is to using a meter measure the batteries or discharge the unit with a wire and a 2.2 volt bulb (flashlight bulb) once discharged, unplug the charger unit for over 10 secs to reset it. then plug it in and try the batteries in the packs again. if still inop then they are done for.
Aug 15, 2008 | Nintendo Wii Console
GPS Logo
49 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
