My motherboard has been locked by some body with a password
    Problem Solver:
  • 15 Answers
Depending on weather this is a bios lock out or software lockout Ill try to help.
Bios-First in a bios lockout you will have to power down the machine unplug power cord to computer, find your jumper for cmos, set that to the re-set position, also for other reasons take out the on board battery, after doing all this put the batter back in and then plug the machine back in and power her up, you should be good to go.
Software- in this case The only way I know how is to wipe the hard drive and reinstall everything
I hope this helps,,,,,,,,Larry
Posted on Dec 12, 2008
    Problem Solver:
  • 4 Answers
I think you have to reset your bios to factory settings.The easiest way to do is to remove the battery from your motherboard for about 10 min and put it back.Should be unlocked.
    Problem Solver:
  • 16 Answers
Hi, First shud down your pc.Switch off the power. And open your motherboard's battery. Be carefull and don't rush. And again fix it. And start your computer. Then you will be asked by a message in a black screen that some BIOS Lost or somthing. You just carry on with new set up. Let me know the result
Keyboard replace
Forgive me, not advertising for these guys,
http://www.laptopkeyboard.com/Guides.php/Samsung/Q%20Series/Q430/KBSG5
(They say, "A picture is worth a thousand words")
As new as the Samsung Q430 series of Notebook PC's is, there should be only two different types of ZIF connectors on the motherboard, used for the Keyboard Cable. But may be three;
A ZIF connector is a Zero Insertion Force connector. The motherboard connector on a laptop, that the Keyboard Cable goes into, is a style of ZIF connector.
Usually composed of two parts; The bottom part is larger in size, and is Stationary to the motherboard. It is called the BODY.
The upper part is smaller in size, and is Movable. It is the Locking Bar. Uses the wedge principle when in the closed/locked position, to wedge the Keyboard Cable into the Body.
1) The newest style has no Locking Bar to release. The Keyboard Cable is gently, yet firmly, pulled on; and removed from the motherboard connector. To reinstall just line it up as it was originally, then push in.
2) I refer to this as the Flip-Up style;
Closed/Locked,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-13.jpg
Open/Unlocked,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/big/laptop-disassembly-14.jpg
3) And an older style. I refer to this style as the Slide style;
Closed/Locked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-10.jpg
Open/Unlocked;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/big-body/dismantle-laptop-11.jpg
All you can see are two 'Tab's of the Locking Bar, on each side of the Keyboard Cable.
These Tabs are EASED up with your thumbnails. Ease up on one side a little, then the other side; then both sides.
Moves approximately 2mm. That is a little more than 1/16th of an Inch, or about the width of this capital letter -> O <-
IF,....the Locking Bar is broken, or IF,...the Body is broken; you are looking at MOTHERBOARD REPLACEMENT, and why I am being so detailed.
Note that other motherboard connectors, may use a ZIF connector of one of the types stated above, also.
Touchpad Cable, etc.
When replacing a Keyboard, line the flat bar terminals strips on the Keyboard Cable, back up to the contact pins in the motherboard connector.
The Keyboard Cable MUST go back in the same position, as it was originally. Therefore look at the old Keyboard, and it's cable; to orient the new Keyboard Cable correctly.
For additional questions please post in a Comment.
Regards, joecoolvette
Apr 21, 2013 | Samsung Q430 Laptop
How to replace dell vostro 3500 keyboard ?
1) Remove ALL power. Remove the AC adapter, (Charger), and Battery.
2) Click on the Blue -
Dell Vostro 3500 Service Manual (8530KB)
[This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name it may take up to 30 seconds, before the first page comes up ]
In the Service Manual click on the blue -
Removing and Replacing Parts
Click on Keyboard in the right list.
NOTE*
The Keyboard Cable STAYS attached to the Keyboard. It removes from the motherboard connector.
There is NO plug connector on the motherboard side, of the Keyboard Cable.
The Keyboard Cable is a FFC. Flat Flex Cable.
This is a general example of a FFC,
http://en.wikipedia.org/wiki/File:Flat-Flex-Cable.jpg
Note the flat metal strips. These are Contact Strips. They mate up to Contact Pins, in the motherboard connector.
The Keyboard Cable MUST be reinstalled, as it was in the original position.
For this reason you may wish to make a mark, (Sharpee?), on one side of the Keyboard Cable; and a matching mark on the same side of the Keyboard Cable motherboard connector.
The motherboard connector is a type of ZIF connector.
Zero Insertion Force.
It is rectangular shaped, and composed of two parts, BUT does NOT come completely apart.
The bottom piece is the larger of the two. It is stationary, and mounted to the motherboard.
It is the Body.
The top piece is also rectangular in shape, smaller in size, and is movable. It is the Locking Bar.
The Locking Bar is designed to wedge the Keyboard Cable; in the Body, when in the Locked position. (Closed)
IF, the Locking Bar is removed from the Body, it is Broken.
IF, the Locking Bar is broken, or the Body, you are looking at MOTHERBOARD REPLACEMENT, and why I am being so detailed.
Use your thumbnails, or fingernails, to EASE open the Locking Bar. (Unlocked)
Metal tools have the tendency to slip, and break the motherboard connector.
There are Three types of Locking Bars used, to my knowledge.
(Forgot about one in the past)
The Slide type, and the Flip Up type.
I can't make out in the Service Manual what style is used. I think it is the Flip Up type. However;
Slide Lock Bar,
Closed; (Locked),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-11.jpg
The Brown tabs pointed out by the Yellow arrows, are the sides of the Locking Bar. These are what is eased forward by the thumbnails.
The distance is 2mm. That is a little more than 1/16th of an Inch, or about the width of this capital letter -> O
Slide Lock Bar,
Unlocked; (Open),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/body-big/disassemble-toshiba-c655-12.jpg
Flip Up Lock bar,
Locked; (Closed),
Flip Up Lock Bar,
Unlocked; (Open),
Regards,
joecoolvette
Nov 20, 2012 | Dell Vostro 3500 PC Notebook
Keyboard sticking
Replace Keyboard.
1) http://www.laptopskeyboard.com/toshiba-satellite-keyboard/2373-toshiba-satellite-m30-keyboard.html
Just an example. Search for the best price, and a reputable dealer.
2) http://www.irisvista.com/tech/laptops/Toshiba_Satellite_M35/take_apart_notebook_1.htm
A) Remove ALL power. Remove the AC adapter (Charger), and Battery.
B) In the Irisvista link above, click on the photo shown in Step 6.
Look at the Battery Compartment area at the top.
Note the two rubber 'feet' on each side.
The 3 screws that are circled in Red, and are to the inside of the rubber feet, should be removed. I think they hold the Keyboard Securing Strip on.
C) Follow Steps 8 through 12 on the Irisvista link above.
(You are on Page 1.
Page 1:: Page 2:: Page 3:: Find another model, is on the top of the page, and bottom of the page in White.
A note on the Keyboard Cable;
The Keyboard cable STAYS attached to the Keyboard. It removes from the motherboard's connector.
The Keyboard cable is a FFC. Flat Flex Cable. This is one general example of a Flat Flex Cable,
The thin metal strips on the end of the cable, (Will be motherboard connector side), are contact pins.
This end of the cable slides into the motherboard connector. It is on the opposite side of the Keyboard.
Before removing the Keyboard Cable from the motherboard connector, you may wish to make a mark on one side of the cable; and a matching mark on the Same side of the motherboard connector. (Sharpee?)
Even if the cable was twisted from the factory, it MUST go back the same direction it was removed.
It is rectangular in shape, and is composed of two parts.
HOWEVER, it does NOT come completely apart.
The bottom piece is the larger of the two parts. It is the BODY.
The upper smaller rectangular piece is the Locking Bar.
The Locking Bar moves. The Body is stationary, and mounted to the motherboard.
The Locking Bar works on a wedge type of principle, and when it is in the locked position, it wedges the Keyboard Cable in the Body.
There are two types of Locking bar used at present, to my knowledge. I cannot discern in the Irisvista photos, as to which type is used.
1) Sliding Locking Bar;
A) Locked; or can be said as Closed,
B) Unlocked; or can be said as Open,
Here you can see the Body is White in color, and the Locking Bar is Brown.
You can also see that there are essentially two 'tabs', of the Locking bar showing; on either side of the Keyboard Cable.
One uses their thumbnails to Gently ease the Locking Bar forward; and towards the LCD screen.
The Locking Bar ONLY moves about 2mm. That is a little more than 1/16th of an Inch, or about the width of this capital O.
2) Flip Up Locking Bar;
A) Locked,
B) Unlocked,
IF, the Locking Bar is broken; and/or the hinge pins for the Locking Bar on the Body, are broken; you are looking at -
I do not have access to my Toshiba laptop Service Manuals, anymore.
According to the Irisvista link there are NO screws, that come up from the bottom of the laptop; and screw into the bottom of the Keyboard.
However I wish you to look FIRST, before trying to remove the Keyboard.
If present these screw/s will be in an area under the laptop, that corresponds with the area of the Keyboard.
Generally are in the Battery Compartment, and can be seen when the Battery is removed.
May also be situated as stated, in the area of the Keyboard.
Usually they/it will have a K next to them/it, or Keyboard, or a Keyboard symbol.
Regards,
joecoolvette
Nov 18, 2012 | Toshiba Satellite M30 Notebook
How do you remove the keyboard on a Sony Vaio laptop PCG-7192L
Let's see if this helps Tom,
1) http://laptoppartstore.weebly.com/replace--remove-sony-vaio-vgn-nw-keyboard.html
2) http://www.youtube.com/watch?v=8BEcX_0KYIE
It disconnects FROM the motherboard's connector.
The Keyboard Cable has NO connector on the end. It is a FFC.
Flat Flex Cable.
One example of a Flat Flex Cable,
The flat metal terminal bars MUST be aligned back in the SAME position, as they were originally.
For this reason you may wish to take a Sharpee marker, and make a mark on one side of the cable.
Then make a matching mark on the same side of the motherboard connector, BEFORE you remove the cable.
It is composed of two pieces, but does NOT come completely apart!
The bottom part is larger, rectangular shaped, and is stationary to the motherboard.
It is the BODY.
The upper part is smaller, rectangular shaped, and is movable.
ACCORDING to the video the Locking Bar is the Slide/Wedge type.
DO NOT use a metal tool as shown. One slip, and you can damage the motherboard! Geez!
Use your Fingernails, or Thumbnails.
The Locking Bar slides up. Up towards the LCD screen, or away from the Body.
It ONLY moves about 2mm. That is a little larger than 1/16th of an Inch.
-> MOTHERBOARD REPLACEMENT!!
Hence why I am being so detailed.
More detail on unlocking this type of motherboard ZIF connector,
A) Locked position;
B) Unlocked position;
There is another style of Locking Bar used, however.
The Locking Bar flips up to a 90 degree position, or also can be stated as Straight Up.
Just to make sure I'm going to include info for it too;
A) Locked position
Regards,
joecoolvette
Oct 28, 2012 | Sony VGN Computers & Internet
Open the asus ul50v case
No hints. Just a disassembly pictorial guide that is real close,
http://www.insidemylaptop.com/how-to-disassemble-asus-ux50v-laptop/
Okay, maybe a few...............(lol!)
1) Always remove ALL power remove the AC adapter (Charger), and Battery.
2) Use a multi-compartment container for the various screws you will remove. Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
As you can see viewing down the various photos in the pictorial guide, the Top Cover, along with the Display Assembly, is removed.
Has to be removed in order to access the Power Button Board.
In order to remove the Top Cover, the Keyboard is one of the items to remove first.
Look at Step 4.
The Keyboard Cable STAYS with the Keyboard. It removes from the motherboard connector.
Again,....Removes FROM the motherboard connector.
It has NO connector on the cable. The connector is on the motherboard, and stays on the motherboard.
The connector on the motherboard is made of two pieces.
It DOES NOT come completely apart!
If it is in two pieces it is broken, and you are looking at motherboard replacement.
Hence why I am being so detailed. Do not break it!
The motherboard connector has a larger bottom rectangular piece, which is the BODY.
It has a slimmer rectangular top piece, which is the Locking Bar.
The Locking Bar is wedge shaped. When locked into position in the Body, the wedge shape wedges the Flat Flex Cable, and locks it in.
The Locking Bar is Brown. All you will actually see are two tabs of it.
One tab on one side, and one tab on the other side.
Use your finger/thumbnails, and ease the tabs towards the cable itself.
(Away from the Body of the motherboard connector)
If you look close at Steps 4 and 5, you can see the brown tabs of the Locking Bar have been moved forward, and away from the Body.
The Locking Bar ONLY MOVES about 1 to 2 Millimeter's.
[2mm is a little larger than 1/16th of an Inch. 1mm is a little larger than 1/32nd of an Inch. Use a tape measure to compare, or another measuring device ]
I just searched to find a replacement Power Button Board. No luck on this end, hope you have better.
Regards,
joecoolvette
Jul 01, 2012 | ASUS UL50Vt Notebook
Laptop is locked for no reason, hitachi hdd is locked not sure why it happend is there a factory password
You did not notice the company name and the model NO,however ,there are some spacial tip for BIOS RESET and Off line NT/VISTA/XP reset .
Follow the bellow link.
http://repair4laptop.org/laptop_and_notebook_bios_password_reset.html
http://www.technibble.com/how-to-bypass-or-remove-a-bios-password/
But sorry to say you ,no body can reset hard disk password ,it has been programed in the hard disk chip. I will give you two link for the HDD reset you can try.
http://hdd-tools.com/products/rrs/
http://www.hddunlock.com/
Hope it will help you.
Jan 03, 2011 | Computers & Internet
Is Nokia E55 can be password protected so that no body can
yes you can password protect the mobile .
for that you have to enable and set the phone lock .
the default phone lock code is 12345
Go to settings >security to set the password
Mar 30, 2010 | Nokia E55 Smartphone
I have forgotten my lock code of Nokia 6630
My brother had put an lock code on my 6630 mobile, but now he has forgot the password. i want to format my mobile, i tried it by *#7370# code, but it asked the lock code and i don't know the code, can any body please help me regarding my problem.
Aug 16, 2009 | Nokia 6630 Cellular Phone
My memory card is locked
Hi, I did a Google and this page looks very promising for your password locked 6600 memory card. http://www.s60tips.com/2006/12/04/how-to-unlock-password-protected-memory-card/ Good luck and kind regards.
Aug 28, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
