More problems lol
When i turn my computer on it loads up but it show a breif message sayin ide channel 1 no 80 conductor cable installed and wehn i go into my bios it will just suddonly crash and if i press the restart button on the front of my computer i will jst stay on the load up screen telling me about my cpu and nothing else but it will freeze up when i restart aswell
  • 4 more comments
  • ashley hunter Dec 12, 2008
    no it just freezes telling me about my cpu
    and i installed a ne dvd drive
    also when i go into my bios it just freezes
    mycomputer is a pain in rhe arse lol
    Comment posted on Dec 12, 2008
    and i installed a ne dvd drive.
    it just tells me what speed its being clocked at and what make and model it is
  • ashley hunter Dec 13, 2008
    no i never got it fixxed because everytime i go into the bios it just crashes a voted because you said you wanted to get to guru so i voted fixya all the time haha
    a i see you got to guru
  • 340 Answers
Hy Ashley,
First up,
Your channel 1 no 80 conductor cable,
tell me that you have mounted a new HDD to your computer,
If there isn't a 80 wire cable, then the drive that came with the box was not a speedy one.
If you only have a 40 wire cable the drive will be limited to 33MB/s transfer versus 100 or 133MB/s that's possible with the 80 wire cable.
With the 40's, all the wires are signal carriers (potentially). With the 80's, there is a ground wire between each signal wire to prevent bleed over. Bleed over can affect signal integrity, cause errors, and slow down performance.
you can fix that in one of two ways(or maybe both):-):
1. Go into your BIOS, and set it to run the hard drive auto detection to make sure its not holding on to any old hard drive settings.
2. Make sure that all connections are tight. You might want to try a different cable and if you do make sure it is the 80 wire type. The connectors on the 80 wire are colored (black,blue and gray)
The part with it telling you about your CPU is just a part of the testing procedure.
kind regards
/Teis
remember to vote
Posted on Dec 12, 2008
  • Teis Thomsen
    Teis Thomsen Dec 12, 2008
    Hi Asley,
    I suppose you got it fixed as you voted?
    else, let me know!
    /Teis
Maxtor hard drive settings for a 53073H4
Before doing anything, the user should completely shut down and unplug the computer to prevent electrocution or computer damage. Remove the computer's side panel so that the hard drive is displayed in order to find the jumpers on the IDE drive. Disconnect the power and IDE cables from the hard drive to access the drive better. The hard drive's jumpers are the small, black pegs on the back of the drive. These pegs fit over small metal conductors and assign the IDE drive's role. The user can remove the jumpers by prying them off of their current conductors with his/her fingernails or a small screwdriver. The jumpers can then be relocated to other conductors in order to assign a role to the IDE drive. The user should be very careful while handling the Maxtor jumpers as they are fragile and very important.maxtor-jumper-settings.jpegEach IDE drive model is different but most have three basic settings: Cable Select, Master, and Slave. Each setting is described below.
Cable Select
Cable Select is a Maxtor jumper setting that is the default for virtually all IDE drives. Cable Select allows an IDE drive to naturally become either a Master or Slave depending on the cable used. Cable Select is a neutral setting and is also often used when a user only has one IDE device installed or when a device is neither a Master or a Slave, such as a Floppy Disk drive.
hope this helps
Jun 22, 2012 | Maxtor Hard Drive
How to install 80 conductor cable? because when i turn on my computer it displays no 80 conductor cable installed
It means you're still using the 40 conductor cable from the MB IDE to the
hard drive. The 80 Conductor Cables are used to take advantage of the newer
Ultra/ATA-66 and up IDE drives. (They will still work with the 40
conductor cable, but slower.)
Jun 01, 2010 | Microsoft Computers & Internet
Not able to install windows xp
cable conductor number will only decrease performane not cause problems, check it for damage try diff cable and/or cd drive / windows CD.
Aug 08, 2009 | Computers & Internet
REPAIR
Hello Benjamin2663,
Your error could be several things, but here is what to do to make it work....Listed in order so do them and then see if you get the error and if you do then do the next fix....
FIRST:
Load the set up defaults in the BIOS Setup. This may get it all to work.
SECOND:
Use an 80-conductor cable connected in the Primary IDE socket on the motherboard with the other end connected to the hard disk. You see you may be using an old type of cable and/or it may be connected to the secondary IDE channel. Installing the right cable in right socket will solve your problem.
THIRD:
Double check your cables and jumper settings. As long as you have confirmed them to be in their
correct positions, you go straight to the BIOS and enable Smart Drive capability for your hard drive.
Set all your drives to be Auto detected and reboot the PC.
IF the message and problem still appear you must now go to Device Manager and go to System. Open Systems and go to IDE ATA/ATAPI Controllers, and you will now see primary and secondary channels. Click on the primary channel first and open the properties box.
Next go to the advanced settings and make sure the transfer modes on device 0 and device 1 are set to DMA if available. Do the same for the secondary channel as well and allow the PC to reboot.
If all that fails, go and have your motherboard checked out for faults.
Hope this help you.
Sep 12, 2008 | Intel Motherboard
Cmos checksum error
That warning (and it's just a warning) is telling you that the IDE port can handle an 80-pin cable, but you've only got the standard 40-pin cable attached. There is no problem, but that message will always come up unless you use the faster cable. (cheap item)
The title says something about a CMOS checksum error, so i'll answer that too. That usually happens when someone has reset the BIOS back to defaults either by shorting the reset pins or by removing the battery (which looks exactly like you described).
You'll probably want to go into the BIOS and set things back up... date and time etc.
Aug 22, 2008 | Computers & Internet
MS 6712 motherboard
check the cables, and if all connection pins are on the drives or on the motherboard. Not all the needed communication routs between the drives and the motherboard are working....
U can also try another IDE slot (if more than 1)
If all checks ok, try a BIOS reset... (but most probably is just the cables ...)
Jan 20, 2008 | Intel Motherboard
Installing a ata hard disk.
I dont quite get how you've got them connected so I'll tell you how I'd do it.
First of all, it is kind of standard to put the primary drive at the end of the cable but it doesnt really matter. I go with what ever physically works best.
Connect your 2 IDE devices to the same IDE channel (cable) unless you have 2 IDE channels then put each on their own channel or cable. Make sure you are using 60 conductor cables for each.
If both are on the same cable:
Set the dvd's jumper to slave.
Set the hard drive jumper to master
OR
vice versa.
*Some DVD burners do not like to be slave, or even on the same channel as another device.
The following is the ideal set up
If each is on their own channel (cable):
Set each to master
Be sure bios is set to auto detect for all channels, master & slaves.
** If this doesnt resolve your problem, please post a comment before rating.
Oct 17, 2007 | Seagate Barracuda 7200.10 500 GB SATA Hard...
MSI P4MAM2-V BIOS
Check your Ide data cable it seems 40 pin conductor cable .
Replace them with 80 pin conductor cable.your problen\m has gone.
Oct 13, 2007 | MSI P4MAM2-V Motherboard
Dvd-rom icon missing
Check: 1. if on pressing the eject button on the drive, the DVD loading arm comes out. 2. if yes, replug your IDE cable. 3. If it does not work try using another IDE cable. 4. If still the same problem, connect it to anothet IDE port. 5. If the problem is still there get your DVD drive checked. I assume you have not fiddled with the jumper settings.
Sep 30, 2007 | Computers & Internet
E602
Turn on holding down 1 and 9 keys. will go through a long complete format. If blocks do not fall down through screen left to right, HDD is completely gone.
Nov 23, 2006 | Canon imageRUNNER 8500 Copier
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
