Question about Canon DM-XM2 Mini DV Digital Camcorder
External stereo mic into camcorder not recording audio
We have just bought the Canon XM2 camcorder and an external Hama DM-65 stereo mic that has a 1/4" jack. The camcorder has a 3.5mm input. I bought an adapter and when we tested it, occasionally the sound was great, sometimes buzzing then it cut out altogether. A friend suggested that those audio adapters are notorious for breaking all the time. So I bought an XLR to 3.5mm lead, thinking this would be better than some lousy adapter. With it, the sound levels go up and down as if the audio coming in is fine, but no sound records at all. I also tried a 1/4" to 3.5mm Monster cable from the iStore together with the original 1/4" Hama mic lead, and nothing. I have looked in the manual and it doesn't say anywhere that should change anything in the setup when I put in an external mic, as when a mic is plugged in, the internal mic automatically cuts out. We have done some filming already and the built in mic is fine when recording. Is it because I am not using Canon products, I wonder? It is driving me nuts!
You cannot simply attach a mike with a 3.5mm jackplug by using an XLR adaptor, the connections are all wrong. The only way to connect an XLR mike to the XM2 is by using an adaptor like the Beachtek XLR adaptor which is a superb bit of kit. I can't be certain of your problem but may I suggest possibilities? I wonder if the adaptor you bought was a stereo adaptor. If it looks like a larger version of the original plug then fine, if it has only the one long metal contact along the pin and then the tip separately, it is a mono adaptor. Using this on a stereo mike would work but it would be combining both channels into one which would degrade the sound and could give rise to your noise issues. If you have got an adaptor that is stereo, is it just the push in type? You can get adaptors that have a threaded barrel to screw the adaptor to the normal plug to lock them together tightly. If it hasn't got that, I would try putting the adaptor on the mike's 3.5mm plug and then taping it together to hold them very tightly together. This will stop minute movements between the two causing buzzing and other noises. I hope you find that of some help, my apologies if not. Rob
Posted on Apr 25, 2007
Canon DM-XM2 Will not record or play back
Clean Idler unit it is magnetism and clean sensor it will work
Mar 08, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
Where can I find a replacement mains and charge lead for a canon DM-XM2
XM2 is the PAL version of the GL1 and 2, should be able to get it from any Canon parts provider (maybe even e-Bay/craigslist)... by mains do you mean battery? it is the same for the GL1/2 XL1/2 XM1/2 (Canon Part # BP-945)
Feb 25, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
Need charger
The replacement DM-XM2 replacement battery charger is @ http://www.ebuybatteries.com/product/battery_chargers/Canon/Canon-BP-941-AC-charger.htm , note it is an extern battery charger, not a power adapter.
Sep 12, 2009 | Canon DM-XM2 Mini DV Digital Camcorder
I have xm2 canon, and I can't find the night vision mode on it.
I do not believe XM2 or GL2 does not have night vision mode. You may achieve little using video gain control. We all know Sony has the night vision modes which have been popular feature. James
Mar 26, 2009 | Canon DM-XM2 Mini DV Digital Camcorder
Can't get the external wireless mic to record...
This camcorder will record audio from an external STEREO mic plugged into the top connector on the right side of the unit (under the plastic cover). I find it works EXTREMELY well with the various Sony microphones traditionally sold for MD recording (I use a mid-size one: model #ECMMS907). Some microphones may have too low an audio level for these camcorders. Other microphones may not have a stereo plug, but most of the ones that do (and have a high output level) should work You simply plug in the mic. No fussing with settings should be necessary. The camcorder has an onscreen audio meter that can be enabled. I leave it on all the time, so I am sure the external mic is working (mine has an on/off switch as well as an AA battery -- so I really want to make sure!).
Mar 22, 2009 | Canon HV20 HDV Digital Camcorder
Canon XM2 Chewing tapes
This seams to be the problem, all the time, plus the sound goes off on most of theses camcorders, and the only way they will work is with an boom, mic.
Could I use an tape clearer when it says eject?
Aug 02, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Dv out no longer deems to work on dm xm2
Sounds like the DV Port has suffered a short circuit. Unfortunately, the only way to fix this, is to take it to a reputable camera repair shop, or send it to cannon if it is under warranty.
Feb 07, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Camcorders audio
if you have a mic hole in it it should work if knot take to a repere shop in town
Sep 30, 2007 | Canon DM-XM2 Mini DV Digital Camcorder
Canon XM2 -Audio Trouble
hi first: http://www.fixya.com/user-guide/p394384,m11809,gm57/Canon-GL2-Mini-DV-Digital-Camcorder.aspx yes you need to connect to the input jack: http://www.fixya.com/user-guide/p394384,m11809,gm75/Canon-GL2-Mini-DV-Digital-Camcorder.aspx if it wont work there is probeblya burned capacitor from the boosting good luck
May 05, 2006 | Canon GL2 Mini DV Digital Camcorder
Canon DM-XM2 Mini DV Digital Camcorder Logo
159 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
