Question about Microsoft Computers & Internet
Cant get in to own computer
I was using computer, switched it off due to battery when put it back on says it is in use and has been locked
i dont have a password
so i dont know why i cant get in to it, its got all my work on
    Sergeant:
    Champion:
  • 334 Answers
Try removing cmos battery and then putting it back in.If that don't work check the cmos battery and see if thats good
God Bless Greg
Posted on Dec 12, 2008
I have a 99 dodge van and the alarm is on so cant start it dont have the remote ..dont no why it did this
You could try locking and unlocking the driver door with the key to attempt to disarm the system.
Feb 16, 2015 | Dodge Cars & Trucks
Escalade troubleshooting
check all fuses if that dont fix it undo the battery and touch the two cables together dont worry as long as there is no battery nothing bad will happen hold it for 10 secs this will clear all codes and put the computer back to stock settings
Jul 05, 2014 | 2003 Cadillac Escalade
Get pass lock screen forgot code
If this is a ford the code will be on the computer. I had the same problem.
Jan 28, 2014 | Car Audio & Video
My 1999 oldsmobile alero will not turn over i had the starter checked and its good i put a new battery in it and it still wont turn over what else could be the problem or is the engine locked up
BAD BATTERY CABLES.CABLES WORN WHICH CAUSES POOR GROUND.TO CHECK TO SEE IF ENGINE LOCK UP.TAKE A 1/2 SOCKET WRENCH AND 15 METRIC 1/2 INCH SOCKET.TURN CRANKSHAFT BOLT TO SEE IF ENGINE TURN OVER..IF NO ENGINE LOCKED UP OR NOT ALL THE WAY IN PARK OR YOU COULD HAVE FAULTY SAFETY CLUTCH SWITCH FOR MANUAL TRANSMISSION OR YOU COULD HAVE FAULTY TRANSMISSION NEUTRAL SAFETY SWITCH.CHECK THE STARTER RELAY.MAKE SURE ENGINE ALL THE WAY IN PARK.IF YOU CANT TURN ENGINE WITH A SOCKET WRENCH TURN ENGINE CLOCKWISE IF YOU CANT ENGINE LOCKED UP DUE TO CONTAMINATED OIL.OIL COULD HAVE LOTS GAS OR COOLANT IN IT.THIS WILL HAPPEN IF OIL NOT BEEN CHANGED OR YOU HAVE LEAKING INTAKE GASKET.FAULTY FUEL PRESSURE CAUSE GAS GET IN THE ENGINE OIL.
Jan 04, 2011 | 1999 Oldsmobile Alero
Which screwa to remove from bottom of sterring column when changing out an ignition switch
YOU HAVE TO REMOVE THE STEERING WHEEL TO REMOVE IGNITION SWITCH YOU HAVE TO REMOVE IGNITION SWITCH INSIDE THE STEERING COLUMN.YOU NEED A STEERING WHEEL PULLER AND A LOCK PLATE TOOL TO COMPRESS LOCK PLATE TO REMOVE THE LOCK PLATE RETAINING RING.DONT KNOW WHAT YEAR VECHICLE YOU HAVE.BUT DUE TO AIRBAGS MAKE SURE YOUR VECHICLE FRONT WHEELS POINTING STRAIGHT AHEAD.TURN OFF RADIO TO KEEP FROM LOCKING IT OUT.REMOVE NEGATIVE BATTERY CABLE WAIT 20 MINUTES BEFORE REMOVING STEERING WHEEL AIRBAG.DISCONNECT AIRBAG ELECTRICAL CONNECTOR.WHEN REMOVING AIRBAG CARRY AWAY FROM BODY CAREFULLY LAY AIRBAG FACING UP PUT SOMEWHERE SAFE FROM CHILDRENS AND PETS. YOU NEED A HAYNES REPAIR MANUAL TO LOOK AT AIRBAG CLOCKSPRING MAKE SURE IT CENTER.BEFORE REMOVING OR CLOCKSPRING WILL BE DAMAGED.IF YOUR TRUCK OR CAR DONT HAVE AIRBAGS NO NEED TO WORRY ABOUT THE AIRBAG REMOVING PROCEDURES. YOU JUST NEED TO REMOVE THE STEERING WHEEL.
Oct 24, 2010 | Chevrolet C3500 Cars & Trucks
I just switched back to my n73 and cant figure out how to put it
remove the back panel of your mobile and take the battery out you ll find place to keep your sim and clip it.Thank you
Oct 13, 2009 | Nokia N73 Cellular Phone
Comes on then shuts off
Sounds like your battery may be at fault, or if you rely on the usb to charge, then maybe it's not charging it due to power settings on the pc.
Try charging from the mains without the player being turned on, for about 20-30 mins. Then turn on and if the problem is still there, then it's the battery.
Jun 18, 2009 | Philips GoGear SA3020/37 MP3 Player
I have the polaroid i830..cameras locked i think
Remove the memory card from the camera (it is next to the batteries). On the side of the card is a little switch, set this to unlocked. You will then be able to write to the card again.
May 12, 2009 | Polaroid i830 Digital Camera
Password is on and i cant remember it on start up
well if it is a desktop then you have to short the bios. facing the back of the computer remove the panel on the right. there is a jumper next to the cmos battery. it looks like a watch battery. switch the jumper to next pins and power up the computer. note: it will not come on but the fan will be running. turn of computer and put the jumper back. the computer will start and you have to reset information in the bios.
Apr 19, 2009 | Computers & Internet
No power i cant swich it on i would like help
remove the battery to reset then put it back on. Happened to me once. At that time my unit was running extremely low on free memory. Free up some memory and problem solved
Dec 30, 2007 | Garmin zumo 550 GPS Receiver
Open Questions:
What is Microsoft office applications? Microsoft office is a set of interrelated desktop applications, servers, and services, collectively referred to as an office suite, for Microsoft Word: a word processor included in Microsoft Office and some editions of the now-discontinued Microsoft Works Microsoft Windows and macOS operating systems. Microsoft Excel: a spreadsheet. Microsoft released the first version of Excel for the Mac OS in 1985, and the first Windows version (numbered 2.05 to line up with the Mac) in November 1987. Microsoft PowerPoint: a presentation program used to create slideshows composed of text, graphics, and other objects, which can be displayed on-screen and shown by the presenter or printed out on slides. Microsoft Access: a database management system for Windows that combines the relational Microsoft Jet Database Engine with a graphical user interface and software development tools. Microsoft Access stores data in its own format based on the Access Jet Database Engine. Microsoft Outlook: a personal information manager that replaces Windows starting in Office 97, it includes an e-mail client, calendar, task manager and address book. Microsoft OneNote: a notetaking program that gathers handwritten or typed notes, drawings, and audio commentaries. Notes can be shared with other OneNote users over the Internet or a network. Microsoft Publisher: a desktop publishing app for Windows mostly used for designing brochures, labels, calendars, greeting cards, business cards, newsletters, website, and postcards. Microsoft Project: a project management app for Windows to keep track of events and to create network charts and Gantt charts, not bundled in any Office suite. Microsoft Visio: a diagram and flowcharting app for Windows not bundled in any Office suite
Dec 28, 2017 | Microsoft Computers & Internet
Computers & Internet Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
