Question about Whirlpool MH7140XF Microwave Oven
Plastic fan cover
The fan cover that sits on the inside of the microwave is broken due to pins missing. Can the microwave still be used until we fix the problem?
  • jlee6 Jan 04, 2009
    My fan cover is burnt and I am having difficulty replacing it...
    Is it necessary to have one at all if I cover the food to prevent it from going up into the fan??
    Genius:
  • 1,605 Answers
The fan inside of the microwave is to draw out the hot air during cooking. you can use the microwave as is. but woould be nice to the cover, just incase some food gets pull up into the fan.
Posted on Dec 12, 2008
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 26, 2013 | Sanyo Microwave Ovens
I have a Samsung SMH9187ST microwave, it is about 2 years old. The door won't stay closed. It is worthwhile to try to fix it or should I just replace it?
If you can lift the plastic door latch catches with no resistance, it is most likely the spring/plastic connector. I removed the door by lifting up, pulling the bottom forward, and lowering. I removed the inside black plastic bevel with a jewelers flat screw driver, prying from the latch side's external edge. Once it was started, I could pull it of with a gentle lift. I took out the black plastic latch, drilled a hole near the broken piece and all was good. Samsung is not on my radar for any future purchases. This is the 3rd major purchase that barely made it past warranty or not even thru warranty.
Dec 31, 2010 | Samsung SMH9187ST Microwave Oven
NEFF H5430NOGB Integrated oven - door won't close, the ;hooks on the door itself seem to have gone loose so they ill not clikc inot place when trying ot close, door just flops open.Amy ideas???
I had this problem. The spring inside the door which pushes the the latches down had broken (plastic peg had broken off).
I managed to fix it by attaching the broken end of the spring to the door frame using a small nylon cable tie using the small hole in the plastic fingers which was already there. Note you need to remove the inside door surround.
See the following link to remove the plastic cover on the door
http://www.fixya.com/support/t1267577-replace_front_glass_door_neff_microwave
I had an interim solution which was to tie some thin string to the latch and feed it under the door and pull on the string when closing the door (when it should be latching.
It was
Dec 06, 2010 | Neff H5430 Convection Microwave Oven
We take turns replacing microwave ovens where I work. The latest one, a GE JES1358WL, stopped working after opening the door while running on a one-push (1 minute) start setting, and the control panel is...
Sounds like part of the peg broke off and is left inside the recepter slot area where the sensor switch is. If it is the lower door plastic hook thing (inside bottom) that broke off, it is possible to re-attatch it to the door if you save the broken piece. Drill a small hole the size of a small wire or nail you have lying around to make a splint - Cut the nail or wire to about 1/2" to use it as a hidden "bone" or skeletal support inside the broken plastic. Glue the nail half way into the broken plastic using modelers glue. Closely align the nail peg to where the plastic broke off and mark it for drilling. Drill carefully making sure you are centered so that your wire "bone" will allow proper alignment of your plastic. Insert the pinned piece into the newly drilled hole checking for alignment, if it looks close enough you can glue it in place and you should have a strong enough repair. Dangerous to use a wooden peg to fool the internal switch. As it will be running even when the door is open and you don't want to get zapped.
Nov 04, 2010 | GE JE1235 Microwave Oven
Hello I have a LG Microwave/grill/convention oven. I caught my bracelet on the bottom lug thing that is attached to the door and now the microwave runs all the time? Please help is this something i can...
Nov 04, 2010 | Microwave Ovens
I have a ge above range spacemaker xl1800 it seems to work fine except their is a rattling noise when its running it sounds like a bad fan or something comeing loose it seems like its comeing from under...
The noise you are hearing is due to the fan. The fan is used to cool the magnetron during cooking, and because this fan is not working the magnetron is overheating and the thermal protector is opening, killing power to the unit. All you need to fix this is a new fan blade. The fan blade(look for part #80) is slipping on the motor shaft ( the noise you are hearing).
GE XL 1800
If the blade is broken then you can buy a new one from---
GE FAN BLADE
Please ask for further clarifications.
A Fixya rating would be appreciated if you find it useful.
Thanks
Rylee
Feb 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave (inside on right hand side wall) has a plastic cover. Behind this cover while popping popcorn there was bright yellow/red flashing/light, it started to melted the plastic cover within seconds....
You don't say which make/model microwave you have, but on every model I have ever seen the thing that sits behind the plastic cover is the magnetron - the bit that actually generates the microwaves.
Unless the microwave was a fairly top-end model, you might well be cheaper to just buy a new one.
Hope this helps,
Matt
Mar 27, 2008 | Microwave Ovens
Broken door hook
The plastic cover on the inside of the door is purely push fit.
To force it off I used 2 strong stainless steel dinner knives.
By easing one knife between the internal glass and the plastic cover I managed to spring one corner by using the other knife on the external bottom edge of the plastic cover.
Try concentrating on one end and once this springs out it is easy to free the rest without having to take it off completely.
The hook is simple to do but be careful with the spring.
All in all it took 3 minutes!
Jan 13, 2008 | Neff B7740N0GB Microwave Oven
Fan cover reinstall on inside of microwave
Oddly enough, Whirlpool calls these fasteners "nails". They hold that waveguide cover ("inlet cover") in place.
You can find helpful exploded view diagrams and order needed parts by entering your full model number here: http://tinyurl.com/gv383
See diagram number 6 on the resulting parts list.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 10, 2008 | Whirlpool MH7140XF Microwave Oven
Whirlpool MH7140XF Microwave Oven Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
