Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Scandisk cruzer problem please help
I have a scandick cruzer micro 2g everytime i put it in the light stays a solid color doesnt blink and it also freezes my computer no matter what while its in he drive everything will stop but if i take it out it goes back to normal it wont let me install or do anything please help
    Brigadier General:
  • 6,966 Answers
Re: scandisk cruzer problem please help
Hi. You may want to check FAQ on SanDisk site. Apparently, there it is a known issue if you have Nero7 installed - your PC will lock when a cruzer is plugged in.^p_host=304~p_supplier=5096~p_parm=PSHFAQ~p_subcategory=2416~p_product=16114~p_citizen=~p_lang=en&p_ebox_tabs_url=/pls/ps/ps_psh.tabs^p_host=304~p_supplier=5096~p_parm=PSHFAQ~p_subcategory=2416~p_product=16114~p_citizen=~p_lang=en&p_ebox_lang_url=/pls/ps/ps_ebox_search.language_selector^p_supplier=5096~p_host=304~p_parm=PSHFAQ~p_subcategory=2416~p_product=16114~p_citizen=~p_lang=en&p_ebox_page_url=/pls/ps/ps_faqdb.view_faq^p_host=304~p_supplier=5096~p_parm=PSHFAQ~p_lang=en~p_subcategory=2416~p_product=16114~p_faq_id=6205&p_ebox_page_type=PreMain&p_pkg=ps_ebox_stuff&p_proc=view_one_graphic&p_page_name=PSHFAQ&p_citizen=&p_lang=en&p_show_privacy=TRUE. Hope this works for you. Cheers.
Posted on Apr 09, 2007
0 characters
3 Points
ScanDisk 4 Gb flash drive not responnding
try connecting it t different computers. if it reacts the same. well im sorry i think your 4gb sandisk flashdrive is damaged. and im sorry to tell you if that so, there is no way u can get your files back.
Aug 16, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a Scandisk Cruzer Micro 2.0 GB that when
sorry but you have suffer a electric surge that resulted for your drive to not to work, and im sorry it's busted... try formatting it but if this doesn't work the it is already gone south....
Jun 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk cruzer micro code 10 error
This can be due to a internal problem,,,also can be avirus
The light should be in solid state i it's working right...and blinking only when a transaction is happening
Please don't forget to rate me "FIXYA"...thank you!
Mar 19, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Scandisk Cruzer micro 1.0 problem - three blinks, three blinks, etc
It means a problem in vista
I'll post if I find the solution , working on it right now
the good news is , it's not broken , it's just vista being a pain.
Aug 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Scandisk cruzer micro 8Gb
Don't mess with that , microcircuits are not to be tampered with unless you know exactly what you're doing and have all the nessessary tools and a clean room.
if it's not broken don't fix it.
Jul 25, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
ScanDisk 2GB Cruzer
try formating the Pen drive once in windows , as the software that comes with cruzer may cause problems sometimes..
Apr 08, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
ScanDisk U3 2G i can not get into it... it is asking me for a password.
Work through My computer once putting the disk in the USB port. It should read "removable device". Click back and forth from c: drive to my computer to make the computer recognize it faster. Let me know what happens.
Jan 04, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can't detect my scandisk cruzer micro
hi mate, what os are you using on your notebook
it it in't xp its a driver problem, not your sandisk 2gb card
here are the specs for it,
  • Retractable USB connector
  • Brilliant amber LED
  • U3 smart enabled
  • Loaded with the following U3 programs
    - CruzerSync synchronization software
    - SignupShield password manager
    - SKYPE "Make video calls from PC to PC"
    - AVAST antivirus software
  • Hi-Speed USB 2.0 certified (backwards compatible with all USB 1.1 ports)
  • Compatible with Windows 2000, SP4 and XP*
  • Certified Windows 2000 and XP*
  • upgrade your notebook to xp
    Nov 05, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    Stopped working COMPLETELY!!!!
    Had same problem.
    I wiggled back and forth the part that goes into the USB port and the drive was recognized and I could copy my files onto my hard drive.
    I had this problem with a different make USB flash drive and used the same procedure to get the files back.
    I think that some connection inside the flash drive works loose after a while.
    I am not going to trust these drives for files storage, but only to transfer files.
    Jul 27, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
    198 people viewed this question
    Top SanDisk Hard Drives Experts
    Brian Sullivan
    Brian Sullivan
    Are you a SanDisk Hard Drive Expert? Answer questions, earn points and help others
