Question about Amana 24 in. ADB1500AW Built-in Dishwasher
Amana Dishwasher door will not open. Latch you grap is very loose
The cycle ran through ok but when it completed I can not get the door open.It apears the latch may have been broken and the door does not open. Where you grab the handle to open the door there is a a black plate which is loose.
We have the same problem and I bought the latch locally for $26.00 now trying to figure out exactly how to get the door apart to replace.
Posted on Mar 04, 2010
  • Kristen Lacey Oct 09, 2014
    I wonder if there is a recall on this? our latch is a pain. I can get it to shut if I slam it and mess with the latch a bit. now my control panel is out. It's a small dishwasher for a 1 bedroom-- but it's been a pain. and the warranty is up . seems like many folks have problems with it.
    good luck.
The cycle ran through ok.but when completed I cannot get the door open. It appears the latch may have been broken and the door does not open. Where you the grab the handle to open the door the latch is very loose.
Posted on Feb 07, 2010
SOURCE:
Kenmore Ultra Wash Dishwasher door won't open
It seems most likely door latch stock and you going to need buy new door latch as for stock one most likely you hsve to forceit to open and replace it with new one
Dec 09, 2013 | Kenmore Dishwashers
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I was washing beach towels and during the rinse/spin cycle the door popped open on my whirlpool duet ht (model GHW9400PL4). I haven't been able to close the door since it opened before the cycle was...
those have a 2 latch system, sounds like the second latch that engages during the spin cycle never quite completed the safety lock , you could try and jumper the latch to see if that would release it, But it seems the secondary latch wasn't working properly in the first place, even the heaviest loads shouldn't pop the door open,
Jul 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door will not open.cnnrwood@yahoo.com
The linkage,to the door lock is most likely off,or the door lock,in the latch is bad(broken).Sometimes the return spring on the latch will break.Some one good with a door unlock kit may can unlock the door.The door is locked,it just don`t apear to be,becouse the door lock button(tab,whatever)is disconnected.If and when ,this some one gets the door open,do not shut it back,unless it is for sure,fixed.Also when the door is opened,remove the inner door panel,so it can be got into,to fix it and test it.I hope this was some help.
Oct 06, 2009 | 2000 Honda Accord
Door won't open after self-cleaning cycle is complete
Turns out that the latch is attached to a plastic piece (made by the manufacturer) and the spring melted! To boot, the fuse in the back which aids in heating the oven went out also. Repair man said this was typical after several uses in cleaning cycle. He recommended using a gentle steel wool pad with soap built in to gently remove backed on food instead of using cleaning cycle. It is just too hot for too long, and there seems to be a domino effect with things that will go wrong. Nothing like the old fashioned way and a little elbow grease!
Mar 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
During the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Feb 25, 2009 | Dryers
Broken latch on dryer door
buy new latch and striker. cheap.
Jan 17, 2009 | Whirlpool LER4634J Electric Dryer
WAsher not working
FL means 'failed to lock' the door didn't lock, so it didn't complete the cycle. Sometimes it's just because the door didn't shut completely or you may have a bad door latch assembly, or worse case, a bad control board. First try unplugging it for 5 minutes, then try starting another load making sure the door is closed completely, if that doesn't help you'll need to open it up to test the door latch.
Jul 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door Lock won't release.
pull your wire in soap dispenser to open door. You may have crimped a wire at door latch assy. when lowering top.
Jan 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Amana 24 in. ADB1500AW Built-in Dishwasher Logo
2,002 people viewed this question
Top Amana Dishwashers Experts
Steve Allison
Steve Allison
Jose Pino
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
