Question about Philips CDM-500 2-Disc CD Player
Cdm 500 not reading disk 1 - Philips CDM-500 2-Disc CD Player
    Scholar:
  • 103 Answers
First, try the disc that plays OK in deck 2 in deck 1. This will eliminate the disc as the problem. If the disc won't play in deck 1, then the laser pick-up is on it's way out. There is no easy fix for this, it will require the attention of an engineer.
Posted on Dec 12, 2008
Alpine CDM 7857 am/fm compact disk receive
The player is unable to read the CD.
Aug 07, 2016 | Alpine Car Audio & Video
I just bought an hour ago and the left disk drive is not reading the disk.
While this is likely to eb a simple repair, any "new" unit should work as expected. Your best bet is to return the unit to the place of purchase and request an exchange. Any attempt to repair this will void the warranty. The purchase location should not give you any trouble. Insist on an exchange.
Dan
Dec 28, 2010 | Gemini Sound Products Gemini CDM-3610 /...
I have a wurltzer CD 100 disk player. I think the
Either the CD player, CD control unit, or Selection & Credit Computer are defective. I can help over the phone with troubleshooting, please email tech@wurlitzer-ohio.com.
Jul 30, 2010 | Wurlitzer Jukebox CD Player
Chamberlain CG40 CDM 1/2 hp motor does not rotate
Here is the manual:
The fault it's reading is 'Motor overload'
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A3215.pdf
The motor could be stuck, check for free travel on chain drive and make sure nothing is stuck on door...
Sep 20, 2009 | Tools & Hardware - Others
No Disc
you may need to get a new player because this one sounds broken and can only b temporarally fixed.
Jun 30, 2009 | Philips Gemini CDM-500
My gemini cdm-500 comes up with a error wen trying to play a cd on one side
HI. i would try cleaning the lens with cleaning disc. if this doesn't produce results, the issue will then be a damaged optical lens assembly. you will need to replace this assembly in this case.
May 28, 2009 | Philips Gemini CDM-500
Does not recognize/play DVD - shows "NO DISK"
If you are good at repairs.dismantle the Disk drive unit carefully from the main carriage and if the Optical lens reading unit has got a drive P C B ,then desolder the PCB so that you have only the CD mechanism on your table,with a Digital Multimeter check the Ohmic values of both the Spindle motor and Sled motor. the resistance should read between 4.5 ohms and 8ohms any value beyond this means that the drive signal voltage is not enough to move /rotate the disc and optical-pickup in syncronisation.you can get the drive-motors replaced,or replace the CDM assly available off the shelf.
this should solve the problem.hundreds SONY DVD players are running with this remedy.
Nov 29, 2008 | Sony DAV-C900 System
Disc stuck in unit
Unplug power cord. Plug back power and keep pressing the eject button repeatedly while the unit starts up. Do this a couple of times, if you succeed in activating the eject before the system starts reading the disk, then it will eject.
If you do not get the disk out in this way, the only alternative is taking the unit apart, and removing disk from inside manually.
Oct 08, 2008 | Gem Sound CDM-150 Mixer
Philips CDM-500 2-Disc CD Player Logo
145 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
