Question about Pioneer XV-HTD520 Multi-disc DVD Player
Pioneer xv htd520 won't play dvds
It plays cds fine but when playing a dvd it reads dvd, loading, play, makes a soft whirring noise then opens. Have tv set right and have cleaned the inside of player with alcohol and a q tip.
  • 1 more comment
  • cjmcoff Dec 13, 2008
    Thanks for your quick response. I suppose my best bet is to take it to a service center. Now I'm off to find one in my area. Thanks again...cjmcoff
    Hope the better rating went through. I am VERY grateful for your help........I would appreciate the part number and again thanks so much
  • geraldoga Feb 23, 2009
    sometimes play, some times says "no disk". I just de-energize, open de case, energize to open de tray, de-energize with the tray open (to keep the tray open) ans clean the lent with a q-tip wet on alcohol. buualaa..now works fine.
    President:
  • 624 Answers
This is a common problem for this model. It has a memory IC that must be replaced. This is a surface mounted IC that requires exceptional soldering skills to replace. I work at an authorized Pioneer service center and have repaired a good number of these for this exact problem. Unless you have great soldering skills it is not something that should be attempted to do yourself, it can cause permanent damage to the board if not done perfectly.
If you have the proper skills and soldering equipment I will be happy to give you the Pioneer part number so you can replace it yourself. If not, then you really should just take it to a service center and have a professional do this.
Let me know if you would like that part number.
Dave
Posted on Dec 12, 2008
  • Dave DeGain
    Dave DeGain Dec 13, 2008
    I glad I could help, but did you have to give me such a bad rating. After all, it was the best answer you could have gotten since it is accurate. The ratings are a little difficult to understand at first, but a "Thanks for Trying" rating means that I did not help you with your problem and it affects my overall rating in a very negative way.
    Since I did identify what the cause of your problem is, it should have rated higher. A "FixYa!" or "Helpful" rating would have been more appropriate since you now know what the cause is and you know what you need to do to get it fixed.
    Most authorized Pioneer service centers should know exactly what this repair is about. A service center that is not authorized for Pioneer may not have seen this problem before and could mean that they would end up charging more in labor because it could take them longer to figure out. If you would like, I can tell you the part number and you can let the service center know what part needs to be replaced. You can tell them that you got the information from Pioneer's tech support and they said it was a common problem for this failure. It could help to save you some money.
    Dave
  • Dave DeGain
    Thanks so much for the higher rating, it is very much appreciated. This is the only reward we get here at FixYa! for helping people with these free problems and a good ratings makes it really worth my effort.
    Here is the reference number, part number, part name and the board that the part is located on. When you take it in for service, see if they will give you a accurate estimate for replacing this part. The part will cost between $45 and $55, depending on the service centers mark up (all shops mark up the cost) and the labor for the repair will also depend on the shops rates. My shop would charge $90 for the labor, but we are one of the cheaper labor rates around. Be sure to tell them that Pioneer Tech support told you that this was the fix for this problem. That way they should believe you about it. Some places don't like the customer telling them how to fix something, but if they believe that you have spoke with the manufacturer and this is what they told you, it may help keeping the price down. I don't want to say that repair centers are not honest, but I have seen many times when they will overcharge for some things because most customers have no idea what the actual problem is and what it takes to replace it.
    This part number I have given you is the substitute for the original because the original is not available. According to the Pioneer authorized service centers website, this part is available right now and this is the correct part number. The service manual will show a different part number, but as I stated above, it is no longer available and this is the part that Pioneer issues as the proper replacement for it.
    Ref # = IC14
    Part # = K6T1008V2E-TB70
    Part name= SRAM IC
    Board= DVDM Board
    Original part number that is no longer available = KM68V1000CLT-7L
    Every one of these unit that I have repaired with the same problem you have has been fixed by replacing this part (about 30 to 40 of them in the last few years), but it is always possible that the cause could be something else although that is highly unlikely.
When playing a dvd ,on you remote dont press open or close butten on the top of the remote reads dvd/cd press this when you and the tray will close and play your dvd i had the same problem belive me it works
Posted on Sep 24, 2009
We have two Pioneer DVD V7400s that won't play DVDs. They can, however, play CDs. Bad laser?
Hi, My guess is that the DVDs are not compatible with the DVD player. They must be windows compatible. WMA or WMV (MP4 format) or (avi) Make sure the your DVD player is indeed a DVD player and not a CD player. Good luck.
Jul 26, 2011 | Televison & Video
Pioneer xv-hdt520 stereo dvd/cd player cant get it to play cd,s works fine on the dvd part of it and all discs are read by the same reader it just tries to start then boots the cd out no matter which...
I would guess this model is over two years old. not sure how much you paid, but target sells a decent surround sound blue ray system for just under 300. i got it. it works great, streams netflix movies an even has an internet radio system in it.
if you dont wanna do that, and have made sure that you have tried brand new cds, another option is to play cds on a cheap cd player hooked into your surround sound. it can go in any input on the back with an adaptor you can buy at radio shack, or many of them have an input in the front.
they used to make a cd lens cleaner, not sure if they still exist. it was a tiny brush hooked onto a cd that you put in and it cleaned up the lens.
bottom line is that it makes little to no sense to me that it would play dvds and not cds. i would assume that they both use the same lens to read the device.
Nov 22, 2010 | Pioneer Audio Players & Recorders
I have a pioneer dvd/cd receiver player,,, xv-htd540 and the timer light is on,, and the unit wont turn on..
i don't have a solution , sorry . but i am looking for a user manual for the xv-htd540 . do you have one ?? dennis
Jun 01, 2010 | Pioneer XV-HTD520 Multi-disc DVD Player
Plays cds but not dvds
If the lens is clean (clean with cotton swab and alcohol), then the optics are failing. DVDs require more power and accuracy to be read than CDs. The ability to read CDs but not DVDs is usually a good indication that the optics are starting to fail.
Dan
Feb 18, 2009 | Televison & Video
Help getting sound from New Sony LCD Television Model XV HTD520 DVD Player with Surround Sound S HTD520
While I could not find it in the manual, I found that you must
go to the menu, open Sound Options and set Speakers to "Fixed".
Note: If you turn off the Surround Sound or DVD player combination you must then go back to the menu and turn the speakers back to Televsion.
Jul 21, 2008 | Audio Players & Recorders
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Dvd playback freezes or is choppy
Get a cleaning disk and run it through the machine. Could be a dirty lens on the laser.
Jan 22, 2008 | Pioneer XV-HTD520 Multi-disc DVD Player
Plays CDs but not DVDs
try it on diff plug or open it must be sme wire has been broken
Aug 01, 2007 | Pioneer DV-444 DVD Player
Will play dvds but not cds
your DVDneeds to be adjusted take out the tray turn over the lens there are two shiney screws to the bottom of the lens the one to the right is for dvd and the one to the left is for cd turn to adjust. good luck.
Apr 02, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Pioneer XV-HTD520 Multi-disc DVD Player Logo
973 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
