Question about Panasonic DVD-S25
Panasonic DVD-S25 This problem literally started overnight. When the unit plays a DVD it freezes. Usually the movie will play normally when you first start it, then every few minutes the image freezes and stays that way for about a half a minute then moves on. Just before it unfreezes you can hear the disk start spinning. I bought a lens cleaner disk, but it has not helped. Any ideas about what is going on and how to fix it? The unit is not that old. Purchased new in 2003.
  • 4 more comments
  • Anonymous May 15, 2008
    DVD will play for about 30 minutes, sometimes less, then the picture will freeze. The player spins off and on, makes clicking noises, the motor whirs and grinds as it does whatever it's doing -- lots of mechanical noise -- then it will spin up again and the movie will continue for 5-10 minutes before it goes into grind mode again. Just gets progressively worse. Tempted to just chuck the whole unit into the street.
  • Npotamus May 21, 2008
    Same thing happens with mine. I have had it work fine for almost the entire movie, then it will just freeze about every 5 minutes for 30-45 seconds.
  • dvdbugger Jun 10, 2008
    playing a dvd and it works fine for 10-1 minutes. the picture freezes for 10-40 seconds and the resumes playing for 5-10 minutes and then freezes again. very frustrating. i've cleaned several different dvd's and have the same issue.
  • gtperry Dec 29, 2008
    Mine is about 3 years old or so, and has just started doing exactly the same thing. Has anyone found any solution for this?
  • Anonymous Feb 14, 2009
    Mine started doing the same thing just recently - in the beginning it would freeze up toward the end of the movie but its now doing it in scene 3 or 4. Makes the whole thing unwatchable. Will probably throw it off a cliff but maybe someone has a simple solution
  • ray717us Apr 08, 2009
    Panasonic DVD S25 started to freeze towards the end of movies and is now freezing towards the start of movies. Will restart on its own occasionally or with prompting but it isn't possible to finish a movie anymore. I haven't noticed the mechanical or whirring noises others have mentioned.
5 Suggested Answers
  • 12 Answers
SOURCE: Can I burn to disk a movie from my hard drive "avi file format"and play it in a dvd player
you cant play avi on normal dvd player,but you can convert avi to dvd format by use free softwere ( filmMachine )
Posted on Aug 10, 2008
petraman7
  • 1175 Answers
SOURCE: Panasonic dd-s25 won't play dvd.
HI...
Have you tried reg.CDs to see if those have trouble too?
I would say that the lens assembly has got debris or a filmy substance over the lens.
If you're not the least bit technical , dont open the unit.
It will require that the cover gets removed and the top DVD spinner plate gets removed so that the Lens can be cleaned.
The chrome rails that the DVD reader runs on would need cleaing too.
Posted on Mar 04, 2009
  • 60 Answers
SOURCE: Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Posted on Dec 09, 2009
  • 112 Answers
SOURCE: My 3 year-old got a
Posted on Mar 25, 2011
My panasonic dmr-ez48v freezes intermittantly when playing dvd's.
perhaps broken gear that moves the laser CARRIAGE contact avsystemparts.com
Feb 25, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Panasonic DVD player problems - switches to
get the dvd player len cleaned using a len cleaner.
are you operating the unit with the remote when find the mentioned issue try manually.
Jul 31, 2008 | Audio Players & Recorders
Hello!!! i have dvd player ht-tz212 and when i play dvd-s it start normal but on half of every film it start freezing picture i tried to play original movies and copies,i even tried cleen dvd players lens...
Your Laser assembly (pick up) is weak, must be replaced. I don't know what you spent for your unit but it might be worth investing in a new one.
Dec 19, 2010 | Televison & Video
Dvd player tray keeps opening and closing.
The tray position switch is disconnected or bent from disassembly. I expect one plug wire is off when you put the unit back. The tray switch is mounted so the tray strikes the switch when fully in and fully out.
Apr 03, 2010 | Panasonic DVD-S25
My dvd player do not play. it says no disc, no matter what I do
I just removed the top part and clean the laser beam with Q tip and after that it started to work back again.
Mar 19, 2009 | Panasonic DVD-S25
HI...
Mar 04, 2009 | Panasonic DVD-S25
RDVD won't record
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You,
Panasonic Consumer Support
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/CustomerSupport?storeId=11251
Nov 26, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Picture freezes
caribjim were you able to fix the problem
Jan 28, 2008 | Panasonic DVD-LS90 Portable DVD Player
Panasonic LA95
You bought it on Ebay ! ! Why did the seller move it on...
I suspect that the decoder is getting 'hot' - same principle as the processor on your PC.
If you are able - I would suggest opeing the unit up (so that the main board is visible) but still able to power up.
Obtain a hair dryer that has a 'cool' blow on it. Start your unit up, while blowing with cool air - this will identify if this is thermal related...
Sep 07, 2006 | Panasonic DVD-LA95 Portable DVD Player
Panasonic DVD-S25 Logo
91 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
