Question about Maytag 24 in. MDB9150A Built-in Dishwasher
Dishwasher won't fill
I have an Maytag MDB9150AWW dishwasher. Initially it was not getting enough water to completly disolve the soap. If you ran it again, it would usually complete. After some research, the advice was that the two usuall problems were the water inlet valve or the float switch. I replaced both.
No luck, it still won't fill.
I did check to insure I have a clear water line (water comes through when is disconnected from the valve.
Thanks
  • 1 more comment
  • ernie15 Dec 12, 2008
    Thanks for the quick reply. The lines are not kinked and I have replaced the valve. When you start a cycle, I do not even hear any water running (the line to the valve never gets warm so no hot water is moving through it) so assume the valve is never opening.
    What is the best way to test the timer?
  • Anonymous Dec 12, 2008
    i have the same
  • lsue Jan 03, 2009
    I HAVE A DWC8240AW WATER WON'T RUN IN TO IT,CAN YOU HELP.THANK YOU!
  • 833 Answers
The only three things left are:
Is the flow to the fill valve adequate...kinked line...for instance.  Drain valve is partly jammed...letting water out early or timer is bad..I'd go with the valve.  You may be able to clean it out.
Posted on Dec 12, 2008
  • Robert Hirst Dec 14, 2008
    The only thing you can do is to look at the voltages coming to the various solenoids when they ought to be activated.  You should see line voltage.  You may also have a defective connector.  Many units have diagrams of the units pasted somewhere on the chassis.  Use caution near line voltage.  You can be hurt or worse.
Soap dispenser opens, but detergent doesn't disolve and runs down front of door. Have tried several different detergents with no result.
You may have a hot water problem. The water when hot will disolve
the soap or detergent. The dishwasher hasits own heater to heat
the water entering the dishwasher. Check the electrical connections
below the dishwasher to make sure your heater is working. It may be just
a loose connection.
If this is not the case, then a service repait man will need to be called,
to determine why it is not heating the water.
Feb 25, 2011 | Maytag Dishwasher
Our dishwasher is not dispensing the soap. I have tried using the cubes (stays in wells), tried powder (it turns to a cake of soap) and I have tried liquid but you could see it ran down the door. Some...
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Dishes are not clean if water is hard or when more detergent is used than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results. You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine. Hope this helps...
Please post back if more information is required.
Daniel
Jan 10, 2011 | Maytag Dishwashers
Soap does not disolve and residue left on all
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 17, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher only a couple of months old. Ran it
The water may not be hot enough. Increase the temperature of the incoming hot water or try this: put the tab in the open soap cup so it will start to dissolve during the pre-wash. Then it will finish dissolving during the main wash. If the dishes get clean using this method you may not have to increase the water temp.
Aug 25, 2009 | Dishwashers
Tablet falls to the bottom of tub but wont disolve
The newer Whirlpool dishwashers have little slots in the top of the soap dispenser to allow water to seep in during the first water fill. This design allows the tablet to begin to dissolve during the first fill then be usefull when the soap door opens. In your case, I would check to see if the soap dish is opening at all. Perhaps one of the racks are not allowing clearance or the soap door itself is sticking closed.
Let the dishwasher fill, drain, and then fill again. Open the door of the dishwasher and see if the soap door is still closed and if so, there is your problem. Also, at this time, check the water temperature. It should be at least 120 degrees F for the soap to be effective.
Hope this helps, Ken
Jul 17, 2009 | Frigidaire Dishwashers
HElp Dishes not coming clean
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Dishes not clean
water valve under dishwasher that let the water come in is not opening all the way causing either low water level or no water to come into the dishwasher. with out the proper amout of water the soap cant be disolved. replace water val to solve problem
Nov 20, 2007 | Maytag 24 in. MDB6100A Built-in Dishwasher
Kenmore built in dishwasher model # 665.16831792
timer is ordering draining. or solenoid is on and it drains non stop.
Oct 31, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
235 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
