Question about Xerox Phaser 6110 All-In-One Laser Printer
Blck ink(only)is faint in two lines dwn left of pge -rollers?
Hhhhhhhheeeeeeeeeeeeeelllllllllllllllllpppppppppppp!
It looks like the rollers are taking off the black ink when it is printing!?
    Problem Solver:
  • 16 Answers
Try to change Imaging Unit.
Posted on Aug 03, 2009
How do I fix HP LaserJet P1606dn printing issue? it continues to print vertical line/ smudge on the far left of the printed document. Does anyone have any suggestion regarding this issue?
The smudges on the side of the paper is most likely a piece of something rubbing against the paper just after the printer puts the ink on the paper. Inspect as much as possible the path that paper takes. Look at rollers. Anything that grab the paper. Look for ink and dust build up. As for the vertical lines. Could be several things. I you haven't used you printer for awhile the ink in the nozzle could of dried up. Most new printers have a nozzle cleaning function. Try that it a couple of times. See if that helps. If it shows any sign of change after that, it dried up ink. It's a hassle to try to get the ink flowing again. I normally just to replace the cartridges. Let me know if this helps or not.
Aug 05, 2015 | HP LaserJet Pro P1606DN Laser Printer with...
I get a black line about 3mm from the right hand edge and faint specks which look like they have been created by a wheels but are much more concentrated on the lower left hand side. Do I change the fuser...
Vertical lines and evenly spaced marks are typically caused by damaged drum. The drums are usually in the toner cartridges. If you think its coming from a a roller or wheel you should be able to just clean off the roller/wheel. The fuser is simply what melts the toner into the paper so I doubt that is your issue.
Try cleaning the rollers and wheels. If that doesnt help replace the drum/cartridge if they are combined.
Sep 03, 2011 | Lexmark C510 Laser Printer
Faint line when printing a letter
hi this may be the toner roller or supply drum for the toner cartridge . if it scratched or worn it leaves marks on the drum or the roller, which in turn fills with toner and leaves an imprint on the page, you can check these , just remove the toner cartridge and look at the green roller and also look at the black roller, it might be a simple case of changing it or cleaning it....hope this helps
Feb 25, 2010 | OKI C5250n Printer
When I print there there is a blck strak on the backside of printed sheet. How do I get rid of that?
The streak on the back is from ink coming up on your exit rollers. You need to have the machine taken apart, ink cleaned off the rollers, and a mylar shield put in to stop the ink from coming up on the rollers. Canon makes an absorber kit that includes the mylar.
Jul 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I get a faint gray line down the left margin of the paper when printing on my Aficio CL35000N. This just started happening and I cannot determine why or how to fix it
the faint grey line is probably from teh fuser belt being worn you can check this by going to rear of printer open up door and look at the surface of the fusing roller it probably has a build up of toner or worn belt thais makes the lines sometimes.. if the fuser is clean you need to open up the side door and look at the drum and transfer belt sections.. Good Luck
Jun 28, 2009 | Ricoh Office Equipment & Supplies
Print outs are having blck lines , what is required to be done
Its probably due to the roller, which are supposed to be changed every so often anyway.
With use, the rollers become scored/worn in places. The excess toner powder that is not used in the printing process is removed by a rubber blade. When the roller becomes worn it isn't wiped clean by the blade ... and you get that characteristic black line down the paper.
Change the roller. You'll probably pick one up on ebay.
May 18, 2009 | HP LaserJet 3050 All-In-One Printer
How to ink Casio FR 1211 Printing Calculator
I have a Casio FR-1211 Printing Calculator and I have the same problem. I removed the roller and tried inking the roller with "Sanford's Roll-On Stamp Pad Inker". It works beautifully ! I don't know how long it will last, but for now the print is dark and clear.
John
Apr 05, 2009 | Casio Office Equipment & Supplies
I have a line over the whole page of my printoput
You might need a new drum. This usually happens when the drum roller needs cleaning. Try your luck and see if there is any spot (clogged ink) on the drum roller. Otherwise, change the drum kit.
Feb 16, 2009 | Dell 3100cn Laser Printer
Black ink is faint
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Dec 12, 2008 | Xerox Phaser 6110 All-In-One Laser...
Xerox Phaser  6110 All-In-One Laser Printer Logo
222 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
