Question about Xerox Phaser 6110 All-In-One Laser Printer
Black ink is faint
OK our Xerox Phaser 6110 is printing perfectly well in colour but when it prints black the ink is faint running in two lines down the left hand side of the paper. It looks like the rollers are removing the ink?? Help!!! we have tried other cartridges etc. Does something need cleaning? If so how???
Cerys
  • costi0n Jan 08, 2009
    well, me too have the same problem...
  • 679 Answers
First I would suggest performing any head alignment functions with your printer's menu to be sure you have the stepper motor feed adjusted properly. Use the paper you are currently printing on for this procedure so that the thickness of that paper is factored in.
If you stil see the banding after doing this, you can use the Advanced Media Control button under Printer Settings in ColorBurst to fine-tune the paper feed adjustment. Print out the "Media Advance.tif" target (located in the ColorBurst/images & Targets folder) to use as a guide. For white bands, you'll need to enter a negative number (to shorten the paper feed).
Posted on Jan 07, 2009
  • energyman58 Jun 22, 2011
    Err its a LASER printer
Even when all properties are set to 'black & white' our Phaser 8550 won't print without all ink colours LOADED. How do I bypass this need so we only need/use black ink?
Only loading black ink and printing monochrome only is not an option on this machine. It must have color cubes installed to keep printhead purged and operating normally.
Sep 03, 2013 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 6180N Laser Printer printing a faint but noticable blue line when printing in color - not an intentionalline. The lines are 3
Most likely replacing the cyan print cartridge will clear this right up. The part number is 113R00719 for the standard capacity. Iteminc.com has this in stock and ships same day for $99. Good luck, and thanks for using fixya!
Nov 21, 2011 | Xerox Phaser 6180N Laser Printer
Printer is printing the black color as light grey. Toner is already exchanged.
When you print something from a website and the print box comes up, click on preferences tab, and when it comes up click on color . Then click on print in grayscale and change the setting from High Quality to Black ink only, click apply at the bottom, then OK. It should print in black ink.
Jan 11, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
When printing, the colour black is too light. Other colours are ok. what to do ?
it happen when the black ink is low or ink outlet get block;just replace your black cartidge it will sove your problem;]
let me know if it's helpful to you
Dec 05, 2009 | Xerox Phaser 6125 Laser Printer
I have not used my Phaser 6110 for about 3 months, and now print quality is bad. It appears to be only the black that is affected. print quality is faint although slightly darker down one side. I have...
This sounds like the doctor blade within the black developer unit inside the image unit has become contaminated. This means that not enough black toner will be attracted to the developer roller. This usually manifests itself as feint thin lines of print running vertically through the text being printed. This can be repaired and is a known issue with this image unit.
If the printer is in warranty tell them you want it replaced, if not then take the image unit back to the supplier you bought it from and demand a replacement.
Nov 24, 2009 | Xerox Phaser 6110 Laser Printer
I have a Xerox Phaser 8400 with image problems. After power up it prints a Startup Page - That page is black text which faded and slightly distorted in some areas and in areas that are in Color only...
What you are describing is a bad print head. You can try running the eliminate light stripes several times, and jet substitution, but most likely the print head will have to be replaced to remedy your problem.
You can try googling. Phaser printer print heads or phaser printheads.
There seems to be a secondary market appearing for those print heads. I can tell you from Xerox, if you have no maintenance agreement, they cost $750 per print head.
Honestly, having worked on about every type of color printer known to man, the new solid ink phaser printers, produce a dry ink image of 2400 x 2400 dpi with ink particles that align end to end. The resolution of those printers are remarkable and can be purchased for less than the price of one of those new print heads.
Now for reliable, albeit somewhat not as sharp a color image, but still exceptional, you really can not beat an HP.
The ink stick technology really no longer has the color vividness advantage it initially had. The inks that align end to end, have ended that advantage and are sure a lot cheaper to operate per page.
Feb 27, 2009 | Xerox Phaser 8400 Laser Printer
XEROX PHASER 8550
Do you have the operators manual? Run it through a cleaning cycle. Also Xerox's website will guide you through some maintenance steps. If you are using generic wax, you may have clogged the jets.
Aug 02, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser  6110 All-In-One Laser Printer Logo
793 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
