Question about Avaya Definity 6408D Corded Phone
Have the 6408D+ phone. Got a Plantronics CS55 Wireless Headset.
How do I program the phone for a Headset button? So I don't have to pick up the handset every time to use the Headset?
  • 83 Answers
You can use an handset lifter accessory, such as the HL1 or HL10 to pick up the handset every time you need to use the headset.
Posted on Jul 18, 2009
Plantronics CS55 Headset
Office was wired that way i have one tried several ways to use it without the lifter did't work had to buy a lifter the next problem is the phone not all will work Cisco uniden will work good
Jun 18, 2014 | Plantronics CS55 Wireless Headset
Plantronics CS55 headset.
Greetings,
I also use a headset at work from the same company (Plantronics), If the battery is faulty it will not power and you can't use it.
The wiring has gone bad. Try re-connecting all wires.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Plantronics CS55 Wireless Headset
I was given a CS55 Plantronics head set. Looking for directions to set it up
If you click on the following page:
Towards the bottom of the page, click on the tab labeled ADDITIONAL INFORMATION. Within that section, you will see PLANTRONICS CS50/CS55 INTERACTIVE USERS GUIDE to click on. This will help you visually see how to setup and start using your CS55.
Good Luck from Headsets Direct!
Jun 15, 2011 | Plantronics CS55 Wireless Headset
I cannot here the phone ringing from my CS55 headset or another call coming in.
You will need the Plantronics HL10 handset lifter in order to have the CS55 ring, indicating an incoming call. The HL10 also allows you to answer remotely on most phones and hang-up remotely.
Plantronics HL10 Handset Lifter
May 17, 2011 | Plantronics PL-CS55 Wireless Headset
I am using a plantronics headset that I use normally everyday but yesterday while talking to a customer it made a click noise and then cut off I picked up the head set and finished my conversation. I then...
We're had customers call with similar issues. First, make sure your compatibility dial is set properly (located on the side of the base). If set incorrectly, it will make your headset inoperable. If that doesn't fix your issue, try disconnecting and reconnecting the battery and then perform a subscription. Both steps can be found below:
How to Replace your Plantronics CS55 Battery
How to Subscribe your Plantronics CS55 Headset
Apr 28, 2011 | Plantronics CS55 Wireless Headset
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Plantronics cs55 problem
Turn on the wireless headset as soon as the HL10 lifter picks up the headset. Remember to press the call answer switch. A steady green light should come on the base and the wireless headset should have a small green blinking light on, on its side.
* Make sure your hand receiver is off the hook when using the headset. Also check that you hear a dial tone on the handset/hand receiver before turning on the headset.
Aug 04, 2008 | Plantronics PL-CS55 Wireless Headset
Avaya Definity 6408D Corded Phone Logo
597 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
