Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Horiantal line near top of screen
The picture has developed a dark horizontal line few inches from the top of the screen. It is present on all input sources. Color varies slightly depending on background so I am assuming that it is blank. Any ideas on the cause and probable costs to fix? Thanks, James
    Genius:
  • 1,153 Answers
Suspect the Light Engine part # 939P977020.
Posted on Oct 06, 2007
SOURCE:
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Vertical Bars Horizontal Lines on LED TV
Check the input connections. If Ariel connection, or other video input connection from any external source have loose contact, or wire broken, this type of interference can occur to picture.
Gopakumar Gopalan Google
Apr 23, 2014 | Televison & Video
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
HORIZONTAL LINES
You are seeing retrace lines, Either you have a bad picture tube or your screens control ( on the flyback transformer) is set too high.
On some sets the focus and screens control is accessible without taking the cover off. If so there will be 2 small holes on the back of the set labelled "screen" and "focus"
insert a small screwdriver into the screen control and turn the control until the lines disappear.
If the set does not have the access holes you can stil perform the adjustement, but you should make sure not to touch anything else as there is high voltage present and it could be very dangerous/Lethal to touch the wrong thing
Mar 12, 2009 | Sony KV-32TW67 TV
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Picture deterioration
Your whole problem my freind is dryed up capacitors. You should go, if you have the technical ability to replace these capacitors, to http://servicemanuals.net, download the schematic diagram, and start replacing the waveshaper capacitors in the vertical drive circuit.
Sep 23, 2006 | Sony KV-35V35 TV
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
157 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
