Question about Toto Toilets ST784S 12 Sedona Beige Clayton Toilet with Traditional SoftClo
Flush Toto less than year old. Following flush (which is not quiet), remains ru nning for extended period of time. Then, on many occasions, following running, toilet makes a "hissing" sound then it physically "vibrates/shakes" for a few seconds. (The ice maker also rattles during this process). I am afraid it may be jarring the bolts loose, or doing perminent damage.
  • 44 Answers
It sounds to me as though its the ballvalve not shutting off properly & when it does shut off the noise you hear is a water hammer, and my guessing is you have a water meter with a back flow prevention valve fitted so when the ballvalve shuts off the pressure exerted on the valve cant go anywhere due to the back flow unit so the noise is the water reverberating through loose pipe-work, annoying but not damaging
Posted on Dec 15, 2008
Five year old Toto toilet has developed a very slow flush in the past few weeks. Plumber has found no clog in line and water from hose flows freely with no back up. We have two other similar Toto toilets...
This can happen if there is a hole (physical damage) inside the trap. Instead of the weight of the water during a flush causing it to drain right down suddenly and completely, it draws in air and loses the momentum. There could be a hole or a crack, which may be hard to find without removing the unit.
Feb 19, 2011 | Toto Ultimate One-Piece Toilet MS854114
HAve to hold the flush handle down for several
change and or adjust the flapper valve if the chain is to long flapper wont stay open long enough for the water to drain into the bowl
May 30, 2010 | Toto CST414M-11 Aquia Dual Flush Elongated...
When I flush the toilet does flush fine but it makes a gasping sound as it tries to refill the tank. Eventually (after 5 minutes) the tank fills and the gasping stops.
new quality flush valves are inexpensive. suggest you buy a new one at a big box store (Lowe's e.g.) . easy to install, just follow the directions.....a Fluid Master or Gorkie should work fine...$25 or less, probably less.....
Apr 20, 2010 | Toto CST743S-04 Drake Suite Two Piece...
Chain ripped through float connection.
hay just go to home depot or lowes take out the one that is broken and match it it cast only couple bucks less head ach
Sep 23, 2009 | Toto MS854114#03 Ultimate Elongated...
Toto Washlet weak
If you are using well water you might want to upgrade your filtration system.or add a mixing valve to the water supply of your washlet and add a filter there, you answer your own question you have very hard water.So the product is getting abnormal; wear and tear. Without making changes to your water supply you will continue to prematurely go thru fixtures,
Jul 02, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
Toto toilet - inadequate flushing
if this has been the case since the toilet was in stalled the problem is probably with the venting of the plumbing lines. try switching the toilets and seeing if it still happens with the "good" toilet.
May 27, 2009 | Toto Toilet Onepiece Ultramax ...
Kohler 81100 Pressure-Clean Flushometer Toilet
This type of flush system can be re presurised quickly by holding down the flush handle for about good 2 minutes, then release , wait for the tank to be refilled with water.
Now you can flush away your inner rotting mess down tube good-by...
Dec 26, 2008 | Home
Toto Toilets ST784S 12 Sedona Beige Clayton Toilet with Traditional SoftClo Logo
471 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
