Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing
Freezer isnt freezing and motor is running
  • 161 Answers
"motor is running" ?
Make sure the compressor is running and not just a fan motor.
Unplug the ref for 30 min or so then while your behind the ref plug it back in. Listen for the compressor to start running, if you hear a clicking noise and the compressor never starts running then the relay needs to be replaced. If the compressor is in fact running and it will not cool then you may be low on coolant.
Posted on Dec 12, 2008
  • 145 Answers
It may need cleaning
Model# FRT17G4BWO will freeze, but the fridge isnt staying cool. What will fix this?
Check to see if the fan motor in the freezer, if working ok, check for frost on the back wall of the freezer -probably a problem in the defrost cycle - defrost timer, heater, thermostat
Jul 11, 2014 | Frigidaire Refrigerators
Refrig is not cooling. freezer cold but not freezing. Already cleaned condensor
several potential problems
1) evap fan motor isnt running to circulate air into fresh food side
2) it isnt defrosting (do ya see what looks like snow on back of freezer)
3)depending on brand or model their is a damper which isnt opening to allow air flow into fresh food section
those are 3 possibilities all of which involve the air flow into the freshfood side to be blocked off
Jul 18, 2011 | Refrigerators
The motor on my frostfree fridge never stops running. Below the freezer isnt cooling. The freezer is cold but not freezing
Hi, seen this a few times when i did apartment maintenance,the most likely cause is a bad thermostat.
Mar 06, 2011 | Magic Chef CTB1722 Top Freezer...
Freezer is all deforsted. Fridge is 5 years old. We smelled a burning smell 2 nights ago and now everything is defrosted. We couldnt tell where the smell was coming from in our house. Motor is running....
If the evaporator (freezer) fan and the condensor (bottom rear) fan are both running but you have no cooling at all, the odor you smelled was probably the compressor start relay/overload device. It would be in your best interest to have a professional service technician look at it. Proper repair could mean the difference between a $60 part, or a $300 compressor. Prices are for the part only.
Dec 23, 2009 | Refrigerators
Freezer motor keeps freezing up
Sounds like a defrost timer.Also it can be a defrost thermostat.Try to adcance the defrost timer to a defrost and see if it melts the ice off.If so then i would say you need a defrost timer hope i helped:)
May 10, 2009 | Freezers
Hoypoint ffa9op.defrosted
hotpoint ffa90, I have fridge and freezer problem, non of them are keeping the required temperature though the fridge temperature is showing the right temperature but not cold and the freezer is not freezing as it is contstant between -2 to -5 but it should be
-22, the fast freeze bottom does not fridge either, it does not take instruction.
Feb 01, 2009 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge freezer
Check to see if the evaporator fan behind the freezer wall (remove wall) is running. If it isnt the air will not flow properly in the unit. Replace the fan motor and it will fix it.
Nov 19, 2008 | Freezers
it would apear the stat is the fault. the thermostat is monitoring the temperature of the inner liner and tubing. if the compresor isnt actuly staying on the only part controling it is the stat. if you have the knoledge i would sugest you bypass the contol with the unit unpluged and the plug it in to conferm the fault was the control. p/s you may have a friend who has some knoledge . the control is a simple switch. just enshure the unit is unpluged. hope this helped
Oct 19, 2008 | Freezers
GE (PSS26MSRSS) Side by Side Refrigerator Logo
134 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
