Question about GE Lands Phones
2nd handset says unavailable and will not work
2nd headset will not work
You have to put the second headset in the main phone charging base( ie the base where the phone line is plugged in) for a while (at least 30 seconds) for it to register to phone then you can go on to use it and charge it in its regular charging base
Posted on Apr 25, 2009
Plantronics cs60 cordless headset not working properly with Mitel 5220 ip phone. Cant switch between handset and headset. When you lift the handset sound comes from the headset. The same headset works fine...
I'm sorry for being long on my answer here...
The bad thing here is that the CS60 is not a Mitel approved/supported headset. The only headsets that are approved for Mitel Superset or Mitel IP telephones are the Plantronics Polaris model.
BUT many other headsets do work with Mitel telephones. Since they are not "supported" by Mitel, you should contact the headset manufacturer for configuration guidance. Some have dip switches, or dials that need to be in certain positions to work with certain telephone models. This can be different from one phone to another.
Plantronics web site and their support people should be able to guide you to configuring this headset properly for each model phone.
How is the headset and handset connected? It sounds like the CS60 is connected to the handset port of the phone and the handset is connected to the CS60. When you go off hook with the handset, it sends the signal to the CS60 and depending on the switch on the CS60, it will send the signal to either the handset or the headset.
OR
The CS60 is connected to the handset port and the handset is connected to the headset port. To make the headset port work, you must have the CS60 connected to the headset port and the handset connected to the handset port. Set the phone to Headset mode.
Dec 13, 2010 | Mitel 5220 IP Phone
Handset 2 show unavailable
hello
there is some battery problem with your phone please service it asap.
Jun 21, 2009 | GE 25841GE3 5.8 GHz Twin Cordless...
Model tc25951ee3-a GE 5.8 cordless 2nd hand set states unavailable and have lost the manual for this phone. Can someone help me to solve this problem? thanks !
Try this.
Please the 2nd handset on the main base cradle for 20 seconds to re-register.
This should solve the problem.
vision05
Mar 12, 2009 | Uniden Cordless Phone
Unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Oct 28, 2008 | Jabra T5330 Wireless Headset
Call transfer problem between Philips VOIP8411B and Plantronics C65 headset
sounds simple in the manufacture hand book that came with head set
states on some models they have this particular compatible mode built in
depending on specs of phone and headset gotta make sure that they were built with these built in specs and not all dect/gap work with other sets
Jun 02, 2008 | Philips VOIP8411B/37 IP Phone
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Can't use the second phone GE model 25861GE3 5.8
You may have several problems. First, you should verify that the 2nd phone works. Unplug the battery from the "good" phone and place it into the "bad" phone. Then try to reset the "bad" phone by placing in the homebase charger for 2o seconds.
If this doesn't fix the 2nd phone, then it has an internal problem, possibly.
As far as the 2nd charger goes, please verify that it works by placing the "Good" phone in it to see if it will charge it.
Additionaly, you may need to "reset" the whole system. Do this by :
1 Unplug phone line, power to charger base, and remove the batteries.
2 Wait a couple of minutes.
3 Plug in battery first, then phone line, and finally the power cord.
Then try to set the phones in the basecharger. (If the new battery is not charged yet, then you will have to charge it first!)
Dec 31, 2007 | Uniden Cordless Phone
Logitech internet handset "UNAVAILABLE" error
Mine was working fine at one point. I had been using it the night before without issue. However later on when I went to make a call the next day the handset said Disconnected.
Any Skype functions said "Unavailable". Rebooting the PC, Restarting the Headset Software and Skype didn't fix the issue.
The fix for mine was to go into "Menu" then "System" on the Handset and do a reset. Soon as it was done, the Skype info popped backup on the handset and it was fixed.
For those who haven't changed it, the default PIN on these handsets is 0000 <-- Zero's
Oct 03, 2007 | Logitech Cordless Internet Handset Phone
2nd handset doesn't work
Hi Rayfatz,
I think your problem might be that the second handset is not registered with the base station. Take the second phone out of it's cradle and place it in the base station (where the first phone is), and leave it there for 20 seconds. Place it back in it's own cradle, and it should start working. Hope this helps! Hal
May 27, 2007 | GE 26938GE1 Cordless Phone
Phones Not working
I have the same problem, I have the same model and sometimes I have to put the 2nd Handset on the main base and let the main base "rocognize it" before I can use it. That usually fixes the problem for me.
Apr 02, 2007 | GE 25861GE3 Phone
Lands Phones Logo
227 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
