Question about Samsung Digimax i5 Digital Camera
Picture quality has become terrible
All our pictures now seem to have lines across them, this is generally only visible if you zoom in, but you don't have to zoom in very far to get them. Basically the picture is fine apart from thelines. I have lots of examples if it is of any help. Up unitl then it was working great, would a firmware install sort it out, or do I have to get yet another new camera. Any help would be great. Ed Walters
    Novelist:
  • 107 Answers
Ed, The shutter on your camera has become stuck open. This causes the lines across your pictures. If you take the camera outside or shoot in bright lighting conditions the pictures will come out over exposed. The fix for this problem requires complete disassembly of the camera to access the shutter assembly inside the lens. It is a fairly common issue due to the fact that the shutter is such a delicate component. Check with your manufacturer for warranty support or recalls. If they are unable to help you for free, there are repair providers which you can find online who will repair your camera for a reasonable rate. David Millier Advance Camera Repair
Posted on Mar 23, 2007
  • 36 Answers
My camera has the same problem, it worked fine but now it has terrible white lines on all the pics, but the video works fine, wich makes sense because the shudder has to stay open to film, i filmed about 200 videos all weekend at a car show, taking no pics, so i think for mine the shudder stayed open.
Posted on Aug 28, 2008
SOURCE:
I have a samsung hp5033 plasma for 18 months and is now having pixel problems. 3/4 of the picture is showing fuzzy tiny squares, this started 3 days ago and seems to get worse. I have tried to self...
Hello rqromero2,
I found this on HP's website. I hope it helps
Picture quality problems (such as lines, fuzzy image, or wrong colors)Check the cables and connections:
  1. Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
  2. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
    Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal.
    For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away.
    If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and .
    If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Open OSD to adjust the picture:
    Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed.
    If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
If this dosent solve your problem, letus know and we will find another solution,
Dahaka
Jul 22, 2008 | Televison & Video
Picture quality is not good. lot of lines in the picture, also photo becomes either too bright and nothing is visible,or too dark or with lot of lines
something wrong with your lcd screen. it will not display the picture clearly. you need exchange or send it to the maintance center in the local.
www.skiliwah.cn/
http://www.digitalcamera-parts.net/
e-mail:e-8090team@hotmail.com
Aug 26, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Picture too large for screen
mine did not fix, picture is still huge and pushed to bottom of screen so the top is black all the way across
/uploads/images/picture-large-screen-34901330-4-1.jpg
May 27, 2010 | Westinghouse SK-32H240S Television
Vertical and horizontal lines when printing photos - HP Photosmar
it sounds as if you may have the picture quality set to draft, its worth a check, especially if printing is ok. Does it print colour writing well too or just black, one of the colour inks may have a block or be low, go into printer settings menu and check what print quality its set for.
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Problem with recording the picture
See if your camera has an ISO setting. If it does, make it a lower setting. 100 is best and move up from there (try to use no higher than 400). The lower the ISO, the more light you will need but your images will be less grainy.
Apr 18, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Blurry zoomed in pictures
if you take pictures on digital zoom, the picture quality may not be acceptable. Try don’t use digital zoom.
digital zoom is not really zoom, it just enlarge a portion of the image, thus 'simulating' optical zoom. That is why you lose image quality on digital zoom.
Apr 07, 2009 | Kodak EasyShare C613 Digital Camera
Blurry pictures.
Check if everything is fine with mechanical zoom and do factory reset.
Dec 17, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
Casio exilim ex-z700
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Aug 06, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Dark circle in middle of picture
I had the same problem too! When zoomed in, those spots become very visible. I try hitting it off but it's still there.. can anyone help us???
Feb 08, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Samsung Digimax i5 Digital Camera Logo
222 people viewed this question
Top Samsung Cameras Experts
Jerry Z
Andy Bale
Andy Bale
Are you a Samsung Camera Expert? Answer questions, earn points and help others
