Question about HP OfficeJet D135 All-In-One InkJet Printer
HP J6480 error message insert 'solution center disk'
The printer is working otherwise, This message appears on start up.
also when I get ready to scan
  • 9 more comments
  • Anonymous Dec 25, 2008
    "The feature you are trying to use is on a CD-ROM or other removable disk that is not available. Insert the 'SolutionCenter' disk and click OK."... I don't have a disk.
  • elijackson Jan 04, 2009
    I have the exact same problem. It happens whenever I connect or disconnect the printer via USB.
  • Anonymous Feb 17, 2009
    Same thing Very annoying!!!!!!!!!
  • Anonymous Mar 05, 2009
    same here
  • Anonymous Mar 06, 2009
    same problem. how can it be fixed?
  • Anonymous Mar 08, 2009
    I have the same problem, using HP 6480
  • Anonymous Mar 09, 2009
    Exactly the same problem
  • Anonymous Mar 16, 2009
    same thing
  • detreid Mar 16, 2009
    SolutionCenter
    "The featureyou are trying to use is on a CD-Rom Drive or other removable disk that is not available.
    Insert the SolutionCenter disk"
    This message is constantly there and will not go away. Cannot be "X"ed out. If you click ok it just opens yet another window and another. Returns after restart. I also have an HP 6480 printer installed. It works fine.
  • Anonymous Mar 18, 2009
    same problem!!
  • Ashlley Mar 18, 2009
    I have the same issue with J 4680. I tried the proposed fixes from HP with no resolution. HP support person could not solve the issue. When I follow the solution, I get an error code 2732 and HP support does not know what this means.
When you get this error message again, insert the installation disc you used for the printer set-up. Then, click on "browse" and go to D:\Setup\SolutionCenter (D: denotes the drive letter of your DVD drive), and you'll find solutioncenter.msi there. Select it, and then click on "OK" ...it should then repair the installation and the issue should be resolved.
Posted on Mar 25, 2009
  • bbflanagan10
    bbflanagan10 Jul 13, 2012
    I did as you have said above and get this error:
    Soultion center:
    Module:
    c:\windows\system32\macromed\flash\flash9f.ocx failed to register. HRESULT - 2147220473. contact your support personnel.
    What next?
When I turn on my computer a message comes up saying the feture you are trying to use is on a CD-ROM or other removable disk that is not avalible. Insert solution Center disk and click ok. Like everyone elce i don't have one
Posted on Jun 08, 2009
I have same problem exactly
Posted on Jan 05, 2009
I currently have an issue with scanning to my PC, on the printer detailed Below
I suspect half a file may be missing.
Try reinstalling the printer software.
Mar 06, 2017 | HEWLETT-PACKARD Photosmart C4485 , Copier...
Hp photosmart 7200 and hp laptop are not communicating. wierless signal strengh is excellent. cancelled , documents cancelled and error message appears.
Click on the link to resolve printing issue on wireless network -> Link
Click on the link to find out if the HP Printer is on wireless network on not -> Link
To Setup the printer on wireless network, follow the steps below
1. Press the SETUP Button printer front panel
2. Scroll to Network - Press OK
3. Scroll to Wireless Setup Wizard - Press Ok
The printer will start searching for wireless router.
Choose the SSID ( Network ) and enter SSID ( network key if setup ) and Press OK
You should get a message as Printer Wireless Setup complete.
Run the HP Printer Software Disk and Choose Add a printer and Choose Wireless Installation and follow the instructions on the screen to complete the setup
You are ready to Print and Scan
Oct 12, 2010 | HP Photosmart C4580 All-in-One InkJet...
I have a hp psc 1410 all in one printer and when i starting to scan a document or a picture ,an error message appears that saying an error occurred communicating with the scaning divise. Please ensure that...
Try this simple step first,
Disconnect the Power cord from the back of printer (while printer is on)
Wait for 10 seconds,
Connect the cord back and wait till it initializes.
Close HP Director or HP Solution Center,
Try to Scan, It should work.
Jul 06, 2010 | HP Office Equipment & Supplies
HP J4580 error message insert 'solution center disk'The printer is working otherwise, This message appears on start up. also when I get ready to scan
kindly uninstall the printer driver and software restart the system and don’t connect the usb cable 1st install the driver cd and when it prompt you for connect the usb cable then connect it and follow the instruction. It will resolve your problem.
Nov 10, 2009 | HP OfficeJet D135 All-In-One InkJet...
HP Photosmart Plus B209a-m scanning problems
  • Click the Start button , click All Programs, and then click Windows Fax and Scan.
  • Click Scan at the bottom of the left pane.
  • On the toolbar, click New Scan.
  • In the New Scan dialog box, click the Profile list, and then choose Documents. The default settings for scanning a document, which you can use or change, are automatically displayed.
  • To see how your document will appear when scanned, click Preview.
  • Click Scan.
  • Nov 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
    How do i get my hp officejet j6480 all in one to scan to my computer?
    If you're already set up to print with J6480, you can use the drivers built into Windows XP or Vista.
    For Windows XP
    For Windows Vista
    Sep 22, 2009 | HP J4680 Office Jet All-In-One Printer
    Scanner doesnt work
    Step one: Verify that the Digital Imaging Monitor is ready The Digital Imaging Monitor must be running in order for the Scan To function to work. The Digital Imaging Monitor icon normally appears in the system tray at the lower-right corner of the computer screen, and the monitor is ready when a check mark appears on the icon after Startup is complete. If the Digital Imaging Monitor is in the system tray, proceed to Step two. If the Digital Imaging Monitor does not appear in the system tray, follow these steps. Windows 98, Me, and XP
    1. Click Start , and then click Run .
    2. In the Open text box, type msconfig .
    3. Click OK .
    4. In the System Configuration Utility window, click the Startup tab.
    5. Search the list for HP Digital Imaging Monitor . If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. Proceed to step three to uninstall and reinstall the software.
    6. Select the HP Digital Imaging Monitor check box.
    7. Click Apply , and then click Close .
    8. Click Yes to restart.
    Windows Vista
    1. Click Start .
    2. In the Start Search text box, type msconfig and press Enter .
    3. On the User Account Control window, click Continue . The System Configuration Utility window displays.
    4. Click the Startup tab.
    Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
    1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
      • On the Windows desktop, double-click the HP Solution Center icon.
      • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
      If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
    2. Click Settings .
    3. Click Scan Settings and Preferences .
    4. Click Scan to... Setup .
    5. Click the Destination List tab. NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
    6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
    7. Click each program to include on the Scan To list.
    8. Click the Add arrow.
    9. Click OK .
    10. Scan a document using the Scan To button on the front panel.
    11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, proceed to Step three to uninstall and reinstall the software.
    Step three: Uninstall and reinstall the software
    1. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
    2. If the software installer does not automatically start, complete the following steps.
      2. In the Open text box, type X:\setup , where X is the letter of the CD-ROM drive.
      3. Click OK .
    3. On the installer screen, click Uninstall . If there is no Uninstall option, the software installation is incomplete.
    4. Insert the software CD into the CD-ROM drive of the computer. The software installer should automatically start.
    5. If the model supports custom install, install HP Imaging Device Functions to scan from the printer. The recommended install will install this feature automatically. It must be manually selected during a custom install.
    6. Follow the onscreen instructions until the printer software is completely installed.
    7. After successful installation, scan a document.
    Step four: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Aug 14, 2008 | HP Officejet J5780 All-In-One InkJet...
    Printer is not working
    Hold set-up button and , still while holding set-up button, press the option button, should be ready to go now!
    Nov 07, 2007 | HP PSC 2210 All-In-One InkJet Printer
    HP OfficeJet D135 All-In-One InkJet Printer Logo
    12,667 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
