Question about Epson Stylus CX6600 All-In-One InkJet Printer
Epson CX6600 takes up to 2 minutes from when Print pressed to Print
We recently had new drive put in computer. So everything had to be reinstalled including the print program. Prior to this when print was pressed, it printed the page instantaneous. Now it takes 2 minutes before it will start to print. Printing is fine and computer seems fine. Would you know what the problem is?
  • Epson Master
  • 705 Answers
Hey Zitta, Check to see that you have the latest version of the Printer Driver installed on your new drive. Go to www.epson.com and you should find your way through to your local site. Then head for the support area and look for the driver download.
Posted on Mar 15, 2007
Unable to use Memory Card with PC VISTA
The scanning software for your printer must be installed separately from the printer software on Vista systems. The following link will take you to the page to download the scanning software....just find your model number and select it:
http://www.epson.ca/cgi-bin/ceStore/support/supAdvice.jsp?BV_UseBVCookie=yes&noteoid=86150&type=highlights
May 03, 2009 | Office Equipment & Supplies
Epson CX6600 printer does not print
Make sure the tape is removed from the cartridges and that they are the correct ones for your model printer.
Jan 17, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Open ink cartridge holder
Here are some T/S steps for your problem:
Press the fontx1.gif Color button and open the scanner unit. Follow the messages on the LCD panel to replace the empty cartridge. See :
http://files.support.epson.com/htmldocs/cx66__/cx66__rf/ink_4.htm#replacing%20an%20ink%20cartridge%20a
Running a printer operation check
If you are unable to determine the source of the problem, performing a printer operation check can help you determine whether the problem comes from the CX6600 or the computer.
To perform a printer operation check, follow these steps.
r_1.gif Disconnect the USB cable from your computer. r_2.gif Make sure that Letter-size paper is loaded in the sheet feeder. r_3.gif Press the fontp.gif On button to turn on the CX6600, and make sure the ! Error light is off. r_4.gif Press the Setup Mode button to enter Setup Mode. r_5.gif Press the A or the fontl1.gif/fontr1.gif Select button repeatedly until 3.Nozzle check appears on the LCD panel, then press the fontx1.gif Color button. The CX6600 starts printing. The CX6600 prints an operation check page that includes a nozzle check pattern.
Compare the quality of the printed test page with the sample shown below. If there are no print quality problems, the CX6600 is fine and the problem probably lies with the printer software settings, the application settings, the interface cable (be sure to use a shielded cable), or the computer itself.
If the test page does not print satisfactorily, there is a problem with the CX6600. For example, if bands appear in the check
Please remember to rate Techs who assist you for free :)
Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 05, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Won't print
printer will photocopy but will not print from my computer.
I have changed the inkjets.
Mar 27, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Cx6600 printer problem
if you left your printer for two weeks or more without using, the print heads may be stuffiness. In this case (aparently yours cases) you must take your printer to a authorized service, they will can clean (with a proper fluid) or replace the ink heads, if cleaning is not possible.
Mar 16, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Changing Cartridges
I inspected the users manual, there it writes:
The steps below to replace an ink cartridge: Caution: Leave the empty cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. To ensure good results, use genuine Epson ink cartridges and do not refill them. Other products may cause damage to your CX6600 not covered by Epson’s warranty. 1. If an ink cartridge is empty: Look at the LCD screen to see which cartridge is empty, then press the x Color button. If an ink cartridge is low: Press the Setup button to enter Setup Mode, then press the green button next to the LCD screen until Replace Ink is displayed. Then press the x Color button. 2. Lift up the scanner 1314127a0e502194c0d970046a123efc.png 3.Wait for the ink cartridge holder to move over, then open its cover.
4. Identify the cartridge you need to replace. Press in the tab at the back of the cartridge, then lift it straight out. Dispose of it carefully.
5. Before unwrapping the new cartridge, shake it gently four or five times. Then remove it from its wrapper.
6. Insert the new cartridge into the holder. Press down firmly until it clicks into place.
7.
Close the ink cartridge cover.
8.
Lower the scanner.
The CX6600 begins charging the ink delivery system and “Charging . . .” appears on the LCD screen. Wait for charging to finish before using your CX6600.
Caution: Never turn off the printer while “Charging . . .” appears on the LCD screen, unless the CX6600 hasn’t moved or made noise for more than 5 minutes.
Jan 23, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Cx6600 plenty of ink but none on the paper ?
since u just got it, consult the manufacturer immediately for more warranty options
Jan 21, 2008 | Epson Stylus CX6600 All-In-One InkJet...
After replacing the black ink nothing prints
Before taking out a new ink cartridge from its package, shake it four to five times. Are you sure you have the proper ink replacement cartridge.The following Epson ink cartridges should be used in your device: * Black: T0431 (high capacity cartridge) or T0441 (standard capacity cartridge) * Cyan: T0442 * Magenta: T0443 * Yellow: T0444 How did you discover the ink was low? Did the machine prompt you or was the printer not printing properly? The other colors should blend together to give you atleast some form of black. If the printer alerted you to change the cartridge...Go back through the procedure to install a new cartrige. Follow the steps below to replace ink cartridges. Make sure the CX6600 is on. When the ink is empty: Refer to the LCD panel message to see which ink cartridge is empty, then press the Color button. When the ink is low: Press the Setup Mode button to enter the Setup Mode and press the A button repeatedly until 5.Ink cartridge appears on the LCD panel, then press the Color button. The ink cartridges move to the replacement position. Make sure that the document cover is closed, then open the scanner unit. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the CX6600. reinstall the same cartridge. (Try shaking it a few times again) If none of the above works uninstall the printer. Download the newest drivers from epson and the should straighten it out. Good Luck. Tim
Feb 20, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
