Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Leaking From the Door
My wife started a wash cycle and during the cycle the door opened up and the water just came pouring out ! Looks like the bottom corner is
not shut all the way, but cycle still starts.
Any Solutions ?
Thanks
  • 85 Answers
Possibly door lock not latching could be a bad wax mtr (within door lock asm) or control board
Posted on Dec 14, 2008
Fills with water between washes
try extending your drain hose up alittle higher
Sep 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    May tag Neptune showing codes
    Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
    Do
    Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
    FL
    The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
    Sd
    The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
    PF
    The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
    Nd
    The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
    LO
    The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
    Lr
    The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
    NF
    The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
    Od
    The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
    Other Codes
    * If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
    Hope this helps (remember to rate and comment this answer).
    Apr 03, 2011 | Maytag Dryers
    Maytage MAH6500AWW Overloaded washer now leaks when filling
    since you can drain it
    take off the back and watch what happens when u turn it on
    i believe you make have a loose drain connection
    Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
    We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
    TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
    Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
    Water drips out of front door
    There does obviously need to be water in the drum to wash or rinse the clothes, however it may be the water level is now higher than normal , check for any blockages and check any drain pump filter.If all o.k. it may be the door seal is leaking .If under g/tee call maytag for repair
    Jan 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Neptune Front Loader Washer
    Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
    Dec 29, 2008 | Maytag Neptune Washer
    The door will not open.
    This is usally a door lock problem, or control board(you can pull bottom panel off and reach up by door lock and pull on a little plastic ring to release the door, make sure there is no water that can pour out)
    Oct 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Door opens
    faulty catch or switch interlock
    Oct 18, 2007 | Maytag Neptune MAH6500A Front Load Washer
    Washer door pops open during wash cycle
    Start the washer in a cycle. When the door locked light comes on, before unit gets to full of water, see if you can pull door open. If so, you probably have a broken latch. The wax motor is activating the switch, but latch is not actually closing. There was a door latch upgrade for some of these models.
    Oct 06, 2007 | Maytag MAH6500 Neptune Front Loading...
    Maytag Neptune MAH5500B Front Load Washer Logo
    331 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
