I have an older Maytag washer model number LAT5000AAW which up until now has worked great.  Went to do a load of laundry this morning but it won't work.  It won't even fill up with water.  Please help!!  New baby and toddler so lots of clothes need washing!!
  • 833 Answers
First...check to see if the machine has power.  Plug a lamp into the outlet.  Move the machine through all cycles.  Something ought to work.  If still nothing...suspect the timer.
Posted on Dec 12, 2008
Maytag Epic Z washer won't spin
it could be the belt has come off or broken or the motor brushes are worn out you will have to take the back off the machine to check this
May 27, 2012 | Maytag Washing Machines
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
LAT5000AAW model Maytag washer will not spin or agitate and i dont know how to take the back or front of
I am not sure on this model, but see if you can take the top control panel off first. This should be held with a couple of screws, then tilt it back and this may give you acces to the screws holding the cover on. The outside cover should be one piece and it removes from the front. If this is correct on this model then you should only be left with a frame that holds the tub and the motor should be underneath the drum. I would check the coupling to the motor and make sure it is not worn out, this will keep the tub from spinning and agitating. You shouldn't even have to move it out or disconnet the water lines to do this.I hope I could help.
Nov 13, 2010 | Maytag PAV2300 Top Load Washer
Washer stops and the display shows Lr.
This is your control board that is going out on this washer. It is simple to repair and you can save a lot of money by making the repair on your own.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and let us know the brand and model number, and we will get the correct part out to you asap.
You can contact us from 7 AM until 9 PM CST Monday through Saturday.
We want to get you washing your laundry again soon.
Happy Holidays to you! Thanks, Ella
Nov 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Jun 14, 2008 | Frigidaire FEX831CS Top Load Stacked...
Error code upsidedown F followed by an e
whats the model number on the washer and whats it doing and when get the model number off the serial plate and the serial number
Mar 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Error code OE does not finish whole cycle
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Oct 11, 2007 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
164 people viewed this question
Top Washing Machines Experts
