Question about Brother GX-6750 Typewriter
GX 6750 the striker will not move and strike the daisy wheel
Everything else works but the striker that hits the daisy wheel to make the letter print does mot move so no printing
  • 7 more comments
  • EFF121208 Dec 12, 2008
    the striker is not stuck it was working ok but then stoped we reset with code reset and the striker worked for a few strike the stoped and will not work again
    the striker is not stuck we were typing and it stoped we reset with code reset and it worked for a few letters then stoped and will not work again
    the striker moves freely when moved by hand but on gears move with manuel movement. the daisy wheel moves and the gears all move when a key is depresed but the striker does not move when a key is depresed. spraied with wd 40 no change
    we replaced the daisy wheel with a new wheel did not salve the oriblem
    we have tryed all the things you all have said to try and it did not fix the problem
    we replaced the daisy wheel with a new one did not fix the problem
    when the striker is moved manuley it hits the daisy wheel letter exactly where it should. when a key is pressed the daisy wheel moves to the letter it is suposed to
    my problem is not fixed i hit the wrong key when i excepted the last solution as the on that fixed my problem
    none of the solutions have fixed my problem
    Master:
  • 623 Answers
The gears you cleaned may be dry and sticking, spray a little WD40. or that gear on the right side is still out of time.. One secret to repairs is to perform the same actions that you want the typewriter to do by hand and watch closely.
Posted on Dec 12, 2008
    Genius:
  • 1,447 Answers
Hi
check for the platen gap its inside the printer itself. look for a switch or a knob that will bring the roller closer so that whenever you strike the wheel will hit the roller. look as well on the sides of the typewriter for the platen gap, its somewhat a switch or a knob.
Hope this helps
    Sergeant:
    Champion:
  • 291 Answers
I researched your info and everything i came up with was to replace the daisy wheel ,,,, hope that helps / larry
  • Larry Youngblood
    Larry Youngblood Dec 12, 2008
    it shows there is a adjustment screw inside to move the gears closer together to make contact
  • 470 Answers
Kindly check the inner root of the daisy wheel, im sure there's such thing that get rid of it, that's why it will not move, or manually pull it by your finger one of them then pull it up, down, up, down, up, down, then try it on another striker,, if it is smooth to pull, it means LACK of oil inside...
regards JAN_yuanjia
    Sergeant:
  • 306 Answers
I suppose mostly in the   Brothers typewriter, If the keyboard is not locked in place under the catches, it will not complete the home cycle. In other words when the carriage returns to the left it will cycle and then beep usually continually. The reason the carriage stop time switch is attaced to the keyboard not the side frame. You might look at that....Could be other problems too.and also try to check whether the dailsy whell properly installed or not tat is Has the lever been pressed firmnly.. & Have you run out of ribbon or have you pressed the 'spider web' key with + // keys after replacing cassette ribbon, correction tape or daisy wheel?.. so chek out these facts too..
  • AbdulRahiman S Dec 12, 2008
    else u have to turn off machine. Unplug machine for at least 1 minute. Plug back in and turn machine back on. If it still doesn't work, check to see what typing mode it is in, and change it if necessary...hop tis may help..
  • 734 Answers
Make it sure the cover of typewriter was lock ,self lock no movement of cover means good operation of typewriter.
  • futureloginn
    futureloginn Dec 12, 2008
    Sounds like the gears you cleaned may be dry and sticking, spray a little WD40. or that gear on the right side is still out of time. I think there is a spring clutch in the gear train which may be bad. One secret to repairs is to perform the same actions that you want the typewriter to do by hand and watch closely. You may see something not movving, or moving slow that under power you won't see.
  • futureloginn
    follow the following link ----
    http://www.geocities.com/wbd641/repair.h...
    hope helpful
    Thanks
  • 3,037 Answers
Sounds like the gears need to be cleaned as they may be dry and sticking, spray a little WD40. or possibly a gear may be out of time. I think there is a spring clutch in the gear train which may be bad. One secret to repairs is to perform the same actions that you want the typewriter to do by hand and watch closely. You may see something not moving, or moving slow that under power you won't see. So give this a try and let me know what you find and we can work from there
  • Brother Master
  • 19,396 Answers
Check if the striker or any other mechanic part is stuck, if you do not find anything abnormal, the device must be disassembled, in this case is better to contact a qualified repair centre.
  • Ginko
    Ginko Dec 12, 2008
    Try first unplugging the power cord for ten minutes.
    On some model there is also a combination key that reset the machine, refer to the manual.
    If the resets do not work, then there is a fault.
    Check the small black part that turns the ribbon, if that part is broken, the wheel wont move.
How do i change the font on my GX-6750 Typewriter
The Font or letter size is depends to your printing fonts or daisy wheel. Buy a different Font size of daisy wheel or printing wheel.
Jul 07, 2014 | Brother GX-6750 Typewriter
When you type, each character you strike actually types another letter.
first try turn typewriter off, (button on left panel toward the back), then turn it back on, and while hold down the CODE button, press RESET key, the whole print head will move and reset
if that doesn't work, power off again, open the cover, release the lever to the Daisy Wheel, and inspect that Daisy Wheel - mine has a bent forward letter, and another letter was kinda stuck to the side of another letter... I gently fix both letters, put the Daisy Wheel back in, firmly lock it in place with the lever, close the cover... and voila, it works like a charm.
While you have it open you might want to dust (use the cleaning spray can duster)... You wouldn't believe what I found in my typewriter... Good luck!
If that doesn't work, I would replace the Daisy Wheel.
gkt
Jan 12, 2011 | Brother GX-6750 Typewriter
Where is the daisy wheel?
The daisy wheel is the part with all the letters on it, Remove the ribbon, pull back on the usually black lever next to the print solenoid and lift the daisy wheel out.
DickyO
Dec 02, 2010 | Brother GX-6750 Typewriter
My typewriter (Brother GX-6750) does not print correct letters
look for bent or broken spokes on daisy wheel .turning unit off for 20 seconds and back on should reset the daisy wheel home position. probably the daisy wheel.
Oct 26, 2009 | Brother ML-100 Typewriter
Its not typing the correct letter. When you type. U can hit letter ''t'' and may type a ? mark.
if turning off for 20 seconds doesn't fix it look closely at the spokes and letters on the daisy wheel for bent or broken spokes or letters. replace daisy wheel if bent or broken about $35.00.
Sep 24, 2009 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter printing problem
have you tried chaging the daisy wheel with a known good one? If yes, have you checked to see if the hammer is in a good condition?
Jun 02, 2009 | Brother GX-6750 Typewriter
Does not type
Throw away and purchase a Nakajima typewriter.
May 02, 2008 | Brother GX-6750 Typewriter
Brother GX-6750 Daisy Wheel
Install wheel, turn machine on and off this resets the printer and home timing. If it still does not correctly, adjustments needed..
Apr 23, 2008 | Brother GX-6750 Typewriter
My GX-6750
The print whell may be rubbing on something....exp ribbon....check and make sure there is nothing blocking the free movement of the wheel.
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Brother GX-6750 Typewriter Logo
76 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
