Question about Frigidaire ATF6000ES Front Load Washer
Little water in Frigidaire front load washer
Washer fills with very little water for wash and rinse cycles. Cloths come out smelling musty and not clean, can only wash a few towels at a time due to such low water. Can the fill time for these cycles be increased to correct this problem?
    Sergeant:
    Champion:
  • 291 Answers
There is something you can buy to use in the machine that will clear up the odor and its called washer magic ,,,, pour it into the dispenser and let it run to clear it up ,,, if you cant find any let me know and i will see if i cant help you get hold of some / larry
Posted on Dec 12, 2008
  • Frigidaire Master
  • 19,396 Answers
If the machine does not fill properly, it is usually because of a defective water level switch. This is also the cause for smelly clothes.
See also : It's underfilling
You can find replacement parts here.
or here Find Parts .
Stagnent water smell while filling
I found that running about a quart of white vinegar through a cycle with hot water and no clothes or detergent takes care of the musty smell. Vinegar removes detergent build-up.
Nov 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My clothes have a musty smell after washing. What should I be doing?
Add 1/4 cup of white distilled vinegar to the rinse water. Helps to remove odors.
Apr 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Hi We Have a ge front load washer and dryer and it seems that our clothes smell musty at times. I've tried leaving the door open on the washer when not in use. Could there be another prooblem??
Try using vinegar, baking soda, or bleach in an empty load to counteract any residues left in onboard water. Also check for debris stuck in door baffle(rubber sleeve between door and tub).
Nov 17, 2009 | GE WSXH208A Front Load Washer
Smell
One downfall of the front load machine that it holds moisture causing musty smell in drum. Try leaving door agar between washes and use a cleaner specific for front load smells 1 every month.
May 29, 2009 | Frigidaire ATF6000ES Front Load Washer
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
My front loader doesn't use enough water.
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 20, 2009 | Kenmore Elite 45986 Front Load Washer
My washer has a really bad smell like musty if i leave the doors closed or if I leave clothes in for a couple of hours is this a probem with them
hi there,
the musty smell is from the door boot or gasket. deposit from clothes and detergent get trapped in there and have nowhere else to go. i would recommend purchasing Washerfresh tables to get rid of the deposits. they are available all over.
Dec 04, 2008 | Frigidaire ATF6000ES Front Load Washer
Our Clothes smell musty and the washer smells too
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
81 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
