Question about 710 P Replacement Remote for Alarm
Keyless control not working
My keyless control would not open the door locks unless it was next to the door. I replaced the battery and it will not respond at all.
the red lite comes on very bright.
I even put it next to the antenna and still no responce.
Thanks for any help. Myron Janisch PSL Fl.
  • jason skovly May 11, 2010
    do you have 1 or 2 remotes programming is diff. let me know
    do you have one or two remotes need to know because the programming is diff. let me know thanks
  • 34 Answers
If you have one remote press and hold the #1 button (lock) for 10 seconds. and within 10 seconds press any of the buttons and the remote will be programed.
Posted on Jan 12, 2009
Battery is disconnected and keys won't open doors or trunk. Help!!!
Is the battery completely disconnected, and you closed the hood? Or, did you replace the battery, and now the key fobs don't work?
If it is the SECOND scenario, if you change the battery you will have to resynchronize the fobs. Stand next to the vehicle and press the lock and unlock buttons on the fob at the same time and hold for 7 seconds. That should synchcronize the fobs to the car again..
But seriously, can't you just use your key to unlock the drivers door to get in, then unlatch the hood?
If your car has keyless entry (I have never, and will never own a GM vehicle) and you have NO keys to open the doors, and the doors are locked because there is no battery installed to unlock them, you have two choices I can think of (legal ones).
1 Call a professional locksmith. (that deals with automobiles)
Many insurance companies cover this as part of your policy.
2. Call the police and ask for help. They usually carry a jimmy tool and if you are very very nice to them they MAY open it for you if you can first prove you own the vehicle.. (they are NOT required to help)
3. Bust out a window, open the door, pop the hood, install a new battery, synchronize the key fobs, test the door locks to make sure they work, then call the dealership to replace the window you broke.. (unless you know a good shade-tree mechanic, and can get a replacement window from a salvage yard.
Oct 31, 2015 | 1998 CHEVROLET MALIBU Roof Glass/Sunroof...
Why Brinks dead bolt keyless entry stays locked
If the bolt moves freely it should work with the correct combination. Test with door open. Reset the combination to be sure you have it correct. If it still won't work with good batteries, then the lock must have failed. Check for loose connections or broken wires. Unless it's under warranty, you'll probably need to replace it.
Jun 20, 2014 | Locks & Locksmithing
2008 HHR Remote Starter not working
Is this an issue with all 2008 HHR remotes??? Highly doubtful , probably the vehicles keyless entry system . Taking the vehicle to a qualified repair shop an having the keyless entry system checked for DTC'S - diagnostic trouble code's . Do you know what a DTC is ?
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the body control module (BCM) to remotely activate certain vehicle features. Keyless entry will lock/unlock the doors, or release the rear compartment lid when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message to the BCM. A low transmitter or vehicle battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following components:
• Door locks
• Liftgate lock
• Remote rear doors (Panel only)
• Vehicle locator/panic alarm
• Illuminated entry lamps
• Remote vehicle start
The keyless entry system has the following components:
• Keyless entry transmitters
• Keyless entry antenna
• 2 Way Advanced Remote Start RCDLR
• BCM
Guessing will not fix this .
Jan 12, 2018 | 2006 Chevrolet HHR
Keyless entry not working
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. Remove key from ignition switch. Close all doors. Open driver's door. Carry out the following within 24 seconds: Turn ignition switch ON and back to LOCK position 3 times. Remove key. Press and release driver's door courtesy light switch 3 times. Ensure doors lock and unlock. If not, wait 40 seconds and repeat procedure starting with driver's door already open. Press each remote control lock or unlock button twice. Ensure doors lock and unlock after each remote control operation. If not, proceed as follows: Press and release driver's door courtesy light switch once. Ensure doors lock and unlock twice. Repeat procedure starting with driver's door already open.
NOTE: A maximum of 3 remote controls can be programmed.
Mar 29, 2010 | 2004 Mazda 6
Ford F150 remote key does not work after car battery
cbridges2232,
Any luck with your keyless remote issue? I'm having the exact same problem with my Ford F150 CrewCab after car battery replacement.
Oct 07, 2009 | 2001 Ford F150 Styleside SuperCrew
Keyless entry on honda civic 2006 not working
The keyless entry is designed to work with the doors closed (closed - not locked). If the door ajar sensor thinks the door is open the keyless entry is disabled. When you manually lock the door it might tighten the door just enough to activate the keyless entry. I would try slamming all the doors closed and then see if the keyless entry works. If it still wont work have the wiring checked on the front door lock.
May 12, 2009 | 2006 Honda Civic Hybrid
Keyless remote works intermittently
replace the battery in your remote, or have it checked at autozone to make sure it's not just your remote.
Oct 24, 2008 | 1992 Buick LeSabre
1999 Honda Civic Remote Keyless Entry System
Hey .. i have a 99 civic also and i found my door doesnt lock unless u open the handel and then lock it and was talking to the shop and they told me things get gumed up inside and take it apart and clean it up with lub .. try that see if it works sounds like same problem
Sep 18, 2008 | 1999 Honda Civic
710 P Replacement Remote for  Alarm Logo
154 people viewed this question
Top Bulldog Security Vehicle Parts & Accessories Experts
John
John
baire
DROPNDEAL
DROPNDEAL
Are you a Bulldog Security Vehicle Part and Accessory Expert? Answer questions, earn points and help others
