Storing channels without remote
Hello there! i have an old samsung cb 3312z portable tv,but no remote.is it possible to find,and more important,to store channels,whats the trick? thanks!
    Sergeant:
  • 306 Answers
I suppose u need to get a universal remote to switch video options .... some televisions use channel 00 others have video selections on the remote itself....
Posted on Dec 12, 2008
  • 470 Answers
Hello also, you can use a universal remote my dear in order for you to allow storing of any channel, just find to the store the model that you have, then ask for the remote, you can purchase on it,, but my advise much better to buy a UNIVERSAL REMOTE of samsung portable tv.
regards JAN_yuanjia
    Sergeant:
    Champion:
  • 291 Answers
You can buy a univeral multi-band remote from about any where they sell tv's and it comes with instructions to program to work with your tv ,,, you can even buy them at a wal-mart / larry
  • 734 Answers
Hi,I would suggest you to first trying unplugging/ switching off your device for 5 minutes. This restores and refreshes the device. Go for it
Let me know if this works, if it doesn’t then I’ll provide some other alternative solution.
Thanks
  • futureloginn
    futureloginn Dec 12, 2008
    sorry i miss the part
  • futureloginn
    ok,
    purchase it from ----
    http://www.google.com/search?client=oper...
    Thanks
Bought this tv without remote, need to get to AUX/AV channel. How do I do it?
you cant , you will need remote
or the code stored in a device that can send it by infared
May 03, 2015 | Samsung CXJ0932 9-Inch ACDC TVVCR Combo
Hello.... and H-E-L-P please ! 11 month old Samsung ua60f8000 connected via coax to antenna, suddenly "no signal".... have reset, retuned (now no channels) and tried all except a new coax (waiting for
It is possible that the cable to your antenna is broken somewhere. You have the right idea to start there.
It is also possible that your TV is looking at CABLE instead of AIR, or visa versa.
Nov 15, 2014 | Televison & Video
Need code for sky remote control for samsung model ps51d450 51inch plasma tv
Hello
Sky remote codes for Samsung TV are:
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 30, 2011 | Samsung Televison & Video
How to fix a sylvania 6413tg that is stuck on one channel
Hello
Your Sylvania 6413TG model is capable of storing 181 channels in its memory; by frequency synthesised tunig process. Just connect external antenna or cable to its antenna socket and make it autotune first. To autotune it, get into 'Menu' select 'Channel set' select 'Auto preset CH' and press 'Vol up' button once. The set will search and memorize all the channels transmitting at that time and will hault an the end and show the first channel received. You can then select your favourite channel by channel select button at the remote control.
If this process is not going on; that is; channel search is OK, but no channels are stored, and the set struck in one channel only. the memory IC inside the TV is faulty and should be replaced. Memory IC can be located very near to the main system control IC, having 8 soldering leads. It can be desoldered and replaced. It will have a number printed on it and should be noted well. This number is very important, and the replacement also must be the same. OK.
Jun 25, 2011 | Sylvania Televison & Video
How do I get it off of Line 1 and back to TV mode without the remote.
On some sets you can press the Up and Down channel buttons to get back to the Menu.
You could also buy a new remote:
http://www.remotes.com/store/samsung/cxj1352.html
Jul 26, 2010 | Samsung CXJ1352 13 in. TV/VCR Combo
Old Samsung Tv Problem CT-5029v - Channel Auto Program
You might try a oneforall remote instead of a whatever :) They support a lot of old and new tv's.
Jan 15, 2008 | Televison & Video
Portable Samsung TV - Model No. CB-3312Z - About 17 yrs old.
You need to get a universal remote to switch video options .... some televisions use channel 00 others have video selections on the remote itself....
Jan 08, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
