Question about Bose 3·2·1 II System
DVD stuck actually it is 2 problems: 1) many times DVD is stuck after playing about 75% of the movie 2) sometime the DVD tray will not open with the DVD disk inside. it will say Opening... but nothing will happen no matter what.
  • 2 more comments
  • Anonymous Nov 06, 2007
    dvd "froze up" after playing ok for 23 minutes. tried to fast forward, nothing. tried to stop, nothing. tried turning off then on, no luck. cannot eject the dvd. gets worse. now, when i push the power button to turn it on, the screen says OFF and then goes completely blank. Don't want to damage equipment by poking or prying. What to do?
    Kris
  • BOSEBRAIN Dec 27, 2007
    I have two bose 3-2-1's. Playing a new disk on one of them, it froze up on Chapter 14. Took Disk out, it was hot, put it back in went to same chapter FROZE. Took it upstairs to the new 3-2-1 again chapter 14 froze. Got BOSE on the line, when through rebooting, same thing on both. Bose is now sending me two new units. I went to the store bought another DVD same one, thinking it might be a DVD issue. Did the same think IT WORKED, just stopped at that point for maybe 1/10th of a second. So now I am thinking it was the DVD. I have had intermittent DVD freeze up, but that could be the DVD....
  • Anonymous Aug 02, 2008
    DVD stuck in tray.  Says it is opening, but nothing happens.
  • Anonymous Mar 30, 2014
    DVD PLAYER NOT OPEN DVD STUCK INSIDE RED LIGHT SLOW FLASHING
Replace the drivebay of the Bose AV3-2-1 If the drive sticks, or does not open, or If you receive an error of NO DISK, or any indicator that the disk is not properly recognized clean the lens and if still doesn?t work then the DVD drive is bad. You can actually use one for a desktop PC with a few part swappings. Check that the drive is a Toshiba SD-M1612 it is printed at the bottom of the drive bay. To use this SD-M1612 as a replacement you will simply have to swap three external parts. Remove the 3 parts from the bad Bose drive bay: Remove the 4 bottom bolts, lift cover, if the DVD bay door is locked then insert a paperclip into small hole in the front. Slide DVD tray out and remove the PC style DVD ROM tray facing. 2 clips hold it on pry them out and slide the facing up and off. Now remove the face of the drive bay. It has several clips. Save these three components (top cover, face, and tray facing) to add to the new Toshiba SD-M1612 DVD bay. Remove the old and installation is the reversed procedure above. also remove the small clear LED bezel from the new drive before adding the face. It works fantastic.
Posted on Apr 07, 2007
    Genius:
  • 1,074 Answers
Your problem is intermittent it seems that you are starting to have problem with your motor that move the mechanisim inside the set.it should be replaced take it to a tech if you do not know what to do.good luck.a check should be made on the gears also you could never tell thier condition.good luck.
Posted on Mar 26, 2007
How do I watch a movie?
You should be able to put the DVD in the tray and should automatically recognize it and go into the movie.
What type of media are you trying to watch. PS2's cannot play blu-ray movies.
Mar 09, 2011 | Sony PlayStation 2 (PS2) Console
How to play movie dvd in playstation 2 ?
open dvd case.
take out disc.
place disc on ps2 disc tray.
put disc tray into console.
enjoy.
Jul 08, 2010 | Sony PlayStation 2 (PS2) Console
Disk stuck in tray and start up screen displays multiple languages and says box requires service
replace the dvd drive or take apart the dvd drive and take the disk out that wayto take it the console apart remove the feet and there are screws under them and two und the stickers toward the middle.case pops off upward,two scres next to controller port 1 and 2. small screw on harddrive bay.take the dvd drive off casing and dismantle.take the disk out and put the connectors back in.test it with the same disk if not shattered.it works put the system back together if not leave it apart so that ou can replace the drive later.if you got anymore questions feel free to emal me at gamecrazy944@yahoo.com
Jul 15, 2009 | Microsoft Xbox Console
After approx 1/2 hour of play the movie gets stuck for few seconds, plays again for 2-10 seconds, then permanently gets stuck. Sometimes a smack to the machine works, ff does not work....we usually just...
Smacking the machine is a good way to destroy the DVD lens. Get a CD/DVD lens cleaner and make sure there aren't any marks on the disk. Dirt & smudges cause about 75% of all CD/DVD player problems.
Feb 27, 2009 | Toshiba SD-2150 DVD Player
Tray keeps opening and won't play dvd
no your son broke the loadi tray and now it will not aline properlycheaper to buy a new the fix!
Dec 08, 2008 | Toshiba SD-2715 Multi-disc DVD Player
DVD recorder model DBRH 197 will not play zone 1 DVDs, is there a solution for this.
1. Power on
2. Open DVD tray
3. Press HOME
4. Select/choose SETUP
5. Use arrows to move to LOCK icon
6. Press 0000000 (press the number 0 (zero) seven (7) times)
- You get the REGION FREE message
8. Confirm OK
OR
Insert a non compatible dvd disc, when the dvd player spits it out again press 0 seven times and the dvd player will congratulate you on making it regionfree.
Aug 08, 2008 | LG Televison & Video
Multizone code for dvd player. model no.DVP3144/75. PROD No. KX2B0812862785
Here you go, this works.
1. Turn the unit on and open the tray. Take out any disc from the tray, leave tray open.
2. Enter the code 98790 on the remote and press Ok.
Don't forget to rate this fixed when it works, thanks.
Worldvet
Jul 22, 2008 | Televison & Video
Playing a DVD and VCD Movie
maybe your unit is nid 2 reformat or nid 2 upgrade
Apr 10, 2008 | Televison & Video
Showing "Disc Error" While playing DVD's
the disc tray is not leveled properly, i had the same problem too and samsung repair centre just adjusted the tray.
Apr 29, 2007 | Samsung HT-DS100 System
Bose 3·2·1 II System Logo
1,917 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
