Paper light blinks no paper jam and tray is full HL 2040
  • arthurb748 Dec 12, 2008
    thanks- worked ready to toss the machine
  • ramelvin Mar 17, 2009
    Fourth LED to the right blinks steadily, indicating NO PAPER IN TRAY. I have plenty of paper and even us the singel sheet manual feed and get the same thing. LED blinks constantly no matter if I have paper in or out.
    Problem Solver:
Check the back side of the printer to make shure no paper jam, if its clear take the paper tray out unplug your machine for about Two minutes, reinstall the paper tray make sure pick up roller is free located at the front of the printer that feeds the paper, plug your machine see if it works,
If not unplug your machine again for two minutes
hold down Key ( 3 ) & ( # ) plug in your machine while you are holding both keys tell reset, It might take sometimes up to 4 or 5 minutes.
Good Luck.
Posted on Dec 12, 2008
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
Brand: Brother Model: HL-2040 Problem: cannot print, paper error, red light blink, did not feed paper. What should i do? thanks.
pull tray out load a couple sheets look underneath and see if paper is lifted up when closing paper drawer. If the paper is not raised to the up position you have broken the tray lift mechanism and it is not worth fixing. You can jam an eraser underneath the tray to manually raise the tray to do a dodgy fix.
Feb 28, 2011 | Brother HL-2040 Laser Printer
Paper light keeps blinking, paper full, won't print
Paper light blinking could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 12, 2010 | Brother HL-2040 Laser Printer
Paper light blinking, but is full of paper. I turned it off for a day, reloaded the paper. No luck. Can you help.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Mar 26, 2010 | Brother HL-2040 Laser Printer
PAPER LIGHT BLINKS RED
Lots of potentials here.
The corona wire may have become dirty in the jam. That will cause it. Both the front and back door have to be shut. See to it that their respective switches are activated when they are shut. Read your owners manual. It is full of suggestions for this issue.
Oct 07, 2009 | Brother HL-2040 Laser Printer
Will not pick up paper from tray. Red light blinks indicating a paper jam. Prints fine if single sheet thru bypass slot.
Not picking up paper indicates either a worn nip roller (rubber on feed spindle) or you have a broken gear in the feed mechanism.
Aug 14, 2009 | Brother HL-2040 Laser Printer
Paper led light wont stop flashing
Pull the tray out and make sure the back guide is pushed against the paper. The back guide tends to move easily on these models
Jul 15, 2009 | Brother HL-2040 Laser Printer
Printer prints from manual feed but not from tray.
you need ot open up the papper tray and more the laser down then it should work
please rate my helf i need you to i am a exert
Apr 20, 2009 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 Flashing Paper LED
Try send one paper manually, then it will pick up paper from the try automatically.
Feb 06, 2008 | Brother HL-2040 Laser Printer
248 people viewed this question
k24674
