Question about Dishwashers
Got problem with dishwasher as it wont start - Dishwashers
  • oablo Apr 20, 2009
    start on kenmore 65516032401 does not work,cycle lights work when pressed and come on in random order without being touched??
Thanks for the assist. My voltage detector said that there was power in the plug, but when I checked it with a volt meter, only a trickle was going through. Plug replacement -> good to go.
Posted on Mar 07, 2010
    Master:
  • 479 Answers
My dishwasher will not start: Most common d/w power is 120 volts, check for 120 volts with a volt meter at the main power harness where it enters into the dishwasher, you will have to remove the lower access panels to get to the power box. Dishwashers also have at least one and most newer dishwashers have two door switches that must be checked. You will find then behind the console at the door latch area. Each manufacture has different designs but this is a picture of what some of the newer dishwasher switches look like.
Posted on Dec 12, 2008
Dishwasher wont start
there is a switch on the dishwasher were the door shuts and u hear a click that switch tells the dishwasher when the door is shut and can start check the switch
Jul 24, 2012 | Dishwashers
Wont start or take in water
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jun 03, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
My miele wont wash it starts up then stops an wont drain out then the water intake light comes on
Hi If appliance fills then starts to wash then stops and starts. Then most likely cause is debris in circulation motor. This will require appliance and motor to be removed
May 21, 2010 | Miele 24 in. G643Vi Plus Built-In...
Clean light flashes and dishwasher wont start
HI, this is a dirty filter alert. it could also be a control fault as well. clean the filter and, disposal as well. if this alert cannot be cleared, replace the control board or, timer.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Frigidaire portable dishwasher wont start
check the outlet where you plug this dishwasher into make sure you have power to it you may have a popped breaker. reply back if this is not the cause.
Nov 18, 2008 | Frigidaire 18 in. FDR252RB Built-in...
Wont start wont let me change the cycle it flashes at 45degrees
poured a kettle of hot water down the drainage part tried 20 mins later and worked think it was a possible build up of grease
Oct 04, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
What model& serial number is this>??
Jan 22, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
128 people viewed this question
Top Dishwashers Experts
