Question about Hoover Soft Light Supreme U4262-930 Bagged Upright Vacuum
Motor and bursh spinning too fast
My name is Don.
This morning when I started to vacuum the motor started running super fast and the brush is spinning extra fast?
If I need a part where do I buy?
Thanks
Don
dirtwaterfox5@hotmail.com
  • 641 Answers
SOURCE: brushes won't spin
open unit's bottem cover and look for the following: - Motor works - Belt which transfer motor's movment to the brushes, in place and not broken (most frequent phenomenon). - No mess on brushes axis which prevent their free movement. Good luck
Posted on Jul 16, 2007
Funny, lots of Hoover steamvacs seem to have this exact problem. I just fixed mine today and it was a problem with the turbine that spins the brushes. It took me a while to get to the part without breaking the plastic housing. If you have the patience, you should have no problem figuring it out. When I got to the turbine part, I opened it up and found that the metal disc at the end of the shaft was rusted and that no grease was ever applied. I took a metal brush, cleaned it up, greased the wheel, and then closed it back up. After putting it back together, it worked great. It almost looks like they don't grease this part on purpose so that it rusts and fails in order for you to spend more (buy parts, extended warranty, etc.). There's tons of grease on one of the other wheels that doesn't even need it. The product works great other than this. I've had mine for about 1 and 1/2 years and this is the first problem I've had with it.
Posted on Jul 30, 2007
  • 9 Answers
SOURCE: brush won't spin
Dear Xana,I have had problems like yours before. More times then not the roller brush "belt" got damaged and needed to be replaced.
You should also check your roller brush and make sure it was not knocked out of alignment.
If neither of these solutions help,then it could be, your roller brush "Bearing Assembly"got damaged which would mean you need to either replace the "Bearing Assembly" if it is removable and if you can find that part.Or else you would need to replace the whole "Roller Brush".
You can normally tell if the "Bearing Assembly" is damaged by trying to turn the roller brush with your hands,if it takes a lot of force to make it turn,then theirs a good chance it was damaged!
These repairs are fairly easy to do, just read your Vacuum manual on replacing parts,also make sure you always have the vacuum unplugged while replacing parts or doing repairs.
I hope this info helps,EarlsOK
Posted on Dec 08, 2007
reddevil6
  • 1673 Answers
SOURCE: hoover u8147-900 upright vacuum
Either the brush rolls are bad, at the ends, or the gear/motor asm. is bad.
Posted on Jan 29, 2008
reddevil6
  • 1673 Answers
SOURCE: Hoover Vacuum Encore Supreme
You can try thehooverstore.com, or call a repair shop and I am sure they can order for you. Doubt that you will find a (#56511A01)manual tho. The hose part #43434268 and will sell for around $15 to $20. Dusting brush #43414145 $8 to $10. Extentsion tube #38634678 about $5. Furniture nozzle #38614029 about $5. Crevice tool #38617024 about about $5. Hope this helps.
Posted on Mar 03, 2008
What is causing the beater bar brush to spin extremely fast?
HI, it's Jim from Crucial Vacuum!
First thing is to be sure to unplug your vacuum. Once you begin smelling a burning smell it's essential to stop vacuuming immediately.
One of two things may be happing here:
1) Your brush roll may need replacing. It's possible that the sides where it attaches to the vacuum have been worn down with age. The bristles falling off is a clear indicator that it's time to replace the brush roll. Also, look for debris, or hair that's wrapped around the brush. Remove all of this with either a razor, or a scissor.
2) Check your vacuums belt. Is it wrapped around the brush roll at all, or is too loose? If so, this means there's no tension around your brush roll and it could be causing your vacuum to overwork the motor and overheat, hence the smell.
Clean this area out and then replace the brush roll and belt. You should be seeing a noticeable difference in both your vacuums suction, and a lack in the burning smell.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 30, 2015 | Vacuums
The spin brushes on my hoover steam And vac don't
Either the pin on the brushes that attaches to the motor shaft is broken, or the motor is dead. Did you check the switch on the front of the unit to make sure it wasn't turned off?
May 16, 2012 | Hoover Vacuums
With brush on, you lower the handle and bursh turns off
Hi Neil,
I'm sorry to hear you're having difficulties with your DC15. Please give us a call so we can run through some troubleshooting over the phone with you, and provide further assistance. You can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Dec 18, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Burshes will not spin, filter is clean
Drive belt missing or not properly installed on motor or brush/beater? Perhaps foreign matter caught in ends of beater brush that are holding the brush tightly in place. Clean the debris away and hit with a little WD40, but not much. Make sure it turns freely by hand prior to putting it back into place. If the belt is loose, make sure it is replaced with the proper belt and installed correctly.
Aug 28, 2010 | Hoover Vacuums
Hoover Empower Widepath, brush won't spin.
The belt needs to be changed, it's probably spinning in place which is causing the smell (burnt rubber).
Dec 04, 2008 | Sandia Plastics Super Hipster Power Hepa...
Took appart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=541327
Generic problem for all Vacuums
Took apart turbo brush and
Posted by kristinscull on Apr 24, 2008
Took apart turbo brush and don't know where to put belt to make brush spin...what two things should it connect?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 types of Turbo Brushes, the electric type driven by a power head or power nozzle most likely used on a canister type vacuum or a central vacuum driven by electricity and there is an air driven power head. In either case the belt should be riding on the brushroll pulley on the end or if it is an air driven power head, sometimes the pulley section is in the middle, and the other end would run off the motor pulley / shaft. If you have a flat belt it is suggested that you change the belt every 4 to 6 months, if you have a geared belt, suggested change would be one year or so. I am not sure on the Brand of turbo brush you have, but you can refer to your local vacuum cleaner dealer in your area or the yellow pages, or contact the manufacturer for a phone # or website address, some times if you have a air driven turbo power brush it may be cost efficient to replace the brush instead of repairing the turbo brush. Just a suggestion.
Example: www.turbobrush.com – this may or may not be the website address not knowing the brand name.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 24, 2008 | Vacuums
4296 Robotic Vacuum _ Brush quit spinning
i had the same prob. i contacted i-robot and was told the motor that turns the brush is shot. there is no replacement part. they offered to replace my i-robot with a new one from the 400 series. at about 60% of a new one. that's the only option that i know of.
Apr 09, 2008 | iRobot 4296 Robotic Vacuum
Motor not turning
Don't forget, the agitator bursh doesn't work when the vacuum is upright. Maybe that is your problem.
Apr 01, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover Soft Light Supreme U4262-930 Bagged Upright Vacuum Logo
316 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
