Question about Maytag Performa PAV2200
Dryer wont heat
My maytag dryer quit heating yesterday
I had a gas dryer. It not heat this morning, I notice that the gas is not come out in order to heat the clothes. Please let me know what I can do or I need a repair Technician come to my house to repair this problem ? I am living in Anaheim, California.
Thanl you very much.
Manh NGuyen
Posted on Dec 13, 2008
  • 71 Answers
Check your heating element with a ohm meter.
Posted on Dec 12, 2008
3 Suggested Answers
sclarke7
  • 222 Answers
SOURCE: Maytag Dyer model # MDE9700AYW wont heat it blows cold air
Ohm out the thermal fuse, if it is ok, then you can ohm out the heating element, be sure to visually check the element as well becqause it could just be shorted out internally giving you a reading, but first and foremost check your voltages be sure you are getting 240 across the outer plug spades and 120 volts from left to common and right to common, unplug this thing before you get into the element area or you could end up with a smokin fro !
Posted on Apr 07, 2009
tbirdfan1
  • 3051 Answers
SOURCE: I have a maytag performa dryer wont heat up sometimes
Hello there:
If there is no heat or heat sometimes please try these solutions
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Jul 14, 2010
Matag dryer not heating
Here is a link to maytag dryer repairs http://apcoappliancerepair.wordpress.com/?s=maytag+dryer . The most common problem is the thermal fuse. My question is. Does the heating element start to light. If not...... and you have changed the ignitor and thermal fuse. Then check the flame sensor to see if there is continuity threw it. Power to the gas coils and ignitor runs threw the flame sensor. CLICK HERE to see a flame sensor on a GE dryer. They are the same on most units but Maytag will be on the opposite side of burner chamber.
Apr 30, 2013 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
I have a Maytag Neptune Elect dryer MDE9700, that won't heat. It worked fine until yesterday. A breaker kicked off, I reset the breaker and now dryer will work it just doesn't heat up. There is no error...
Your heat strip has burned out, shorted against the frame, and kicked the breaker. Take off the back, it is not hard to replace. Be sure all breakers are turned off.
Apr 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Clothes Dryer quit heating?
unplug the unit and take the back off.
Apr 13, 2009 | Dryers
Apr 07, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Washing Machines Logo
380 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
